[AVR单片机] atmega16的ICP1引脚不能得到霍尔开关传过来的值
2101|0
 楼主| lei1926 发表于 2012-12-26 17:18 | 显示全部楼层 |阅读模式
我用的是atmega16的芯片,用来测量速度的,传感器用的是霍尔开关,我但我把霍尔开关的输出接到ICP1上没反应,这是为什么,单片机不能读到值   下面是程序 哪位大神帮我看哈  我用protues仿真 没问题 但自己焊了一块板子 就没用了
#include<avr/io.h>
#include <avr/interrupt.h>
//#define BIT(x)        (1 << (x))
//#define CLI()        asm("cli")
//#define SEI()        asm("sei")
int point=3;
char  led_7[13]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0x39,0x00};
char  position[4]={0xfe,0xfd,0xbf,0x7f};
char  dis_buf[4]={0};
int v_ok=0;
unsigned int f_time=0,l_time=0;
float time=0;
double v;
#define sec   3906.25
#define R  0.5
void port_init()
        DDRA=0xff;
        PORTA=0x00;
        DDRB=0x30;
        PORTB=0x80;
        DDRC=0xff;
        PORTC=0x00;
        PORTD=0x04;
        DDRD=0x03;
void time1_init()
        TCCR1B=0x00;
        TCCR1A=0x00;
        TCCR1B=0xC5;
void time0_init()
        TCCR0=0x00;
        TCNT0=0x00;
        OCR0=0x7D;
        TCCR0=0x0B;
void init_devices(void)
        //CLI();
        SREG=SREG&0x7F;
        port_init();
        time1_init();
        time0_init();
        MCUCR=0x00;
        //MCUCSR=0x40;
        GICR=0x00;
        TIMSK=0x22;
        SREG=SREG|0x80;
        //SEI();
//#pragma interrupt_handler timer0_ovf_isr:20//刷新速度
ISR(TIMER0_COMP_vect)
        //TCNT0=OCR0;
        static char i=0, j=0;
        if((j++)==0)
                {v_ok=1;}
        PORTC=~0xff;
        if(i>=4)
        {i=0;}
        PORTA=~(led_7[dis_buf[i]]);
        PORTC=~position[i];
        if(i==point)
                PORTA&=~(0x80);
        i++;
//#pragma interrupt_handler timer1_capt_isr:6//上升沿触发
ISR(TIMER1_CAPT_vect)
        //value=ICR1L;//先读低字节
        //value|=ICR1H<<8;//读高字节并移位到高字节
        f_time=l_time;
        l_time=ICR1;
void to_buf()
        int i=0;
        double tem_v=v;
        if(v>=1000)
                point=3;
        if(v>=100&&v<1000)
                  point=2;
                 tem_v*=10;
        if(v>=10&&v<100)
                point=1;
                tem_v*=100;
        if(v<10)
                point=0;
                tem_v*=1000;
        for(i=0;i<4;i++)
                        dis_buf[3-i]=(int)tem_v%10;
                        tem_v/=10;
void main(void)
        init_devices();
        while(1)
     if((PINB&0x04))
                 v_ok=0;
                 PORTA=0x00;
                 PORTC=0x00;
                 PORTB&=0xfc;
                 SREG=SREG&0x7f;
        else
                SREG=SREG|0x80;
                if(v_ok)
                        v_ok=0;
                        time=((l_time)-(f_time))/sec;
                        if(time==0)v=0;
                        else v=1.57*(1/time)*R;
                        if(v>10&&v<15)
                                PORTD|=0x0;
                        else if(v>15)
                                PORTD|=0x01;
                        if(!(PIND&0x04))
                                {v*=3.6;}
                        to_buf();
