SPI操作AD7799无法读出数据
5185|6
 楼主| l_a 发表于 2013-1-7 01:12 | 显示全部楼层 |阅读模式
示波器查看NSS、SCK、MOSI波形正确,就是在MISO上没有数据输出
大大们帮我看看,是否有哪儿配置错误或者写得不正确
真是衰,就没有用SPI调通过一个东东。
#include "stm32f10x.h"
#include "platform_config.h"
#include "AD7799.h"
#include "Init.h"
/* Exported macro ------------------------------------------------------------*/
//#define SPI_MODE
#define AD_CS_HIGH()                GPIO_SetBits(GPIO_AD_NSS, AD_NSS)
#define AD_CS_LOW()                        GPIO_ResetBits(GPIO_AD_NSS, AD_NSS)
#define AD_SCLK_HIGH()                GPIO_SetBits(GPIO_AD, AD_SCLK)
#define AD_SCLK_LOW()                GPIO_ResetBits(GPIO_AD, AD_SCLK)
#define AD_MISO_HIGH()                GPIO_SetBits(GPIO_AD, AD_MISO)
#define AD_MISO_LOW()                GPIO_ResetBits(GPIO_AD, AD_MISO)
#define AD_MISORead()                GPIO_ReadInputDataBit(GPIO_AD, AD_MISO)
#define AD_MOSI_HIGH()                GPIO_SetBits(GPIO_AD, AD_MOSI)
#define AD_MOSI_LOW()                GPIO_ResetBits(GPIO_AD, AD_MOSI)
* Function Name  : AD_Init
* Description    : Initializes the peripherals used by the SPI ENERGY (CS5460) driver.
* Input          : None
* Output         : None
* Return         : None
void AD_SPIInit(void)
        SPI_InitTypeDef  SPI_InitStructure;
        EXTI_InitTypeDef EXTI_InitStructure;
        /* Enable SPI1 and GPIO clocks */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_AD | RCC_APB2Periph_GPIO_AD | RCC_APB2Periph_GPIO_AD_NSS | RCC_APB2Periph_AFIO, ENABLE);
        /* Configure SPI1 pins: SCK, MISO and MOSI */
        GPIO_InitStructure.GPIO_Pin = AD_SCLK | AD_MISO | AD_MOSI;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIO_AD, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = AD_INT;
//        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
        GPIO_Init(GPIO_ENERGY, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = AD_NSS;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIO_AD_NSS, &GPIO_InitStructure);
        /* Deselect the FLASH: Chip Select high */
        AD_CS_HIGH();
//        AD_INT_HIGH();
        /* Connect Key Button EXTI Line to Key Button GPIO Pin */
        GPIO_EXTILineConfig(AD_PORT_SOURCE, AD_PIN_SOURCE);
        /* Configure Key Button EXTI Line to generate an interrupt on falling edge */
        EXTI_InitStructure.EXTI_Line = AD_EXTI_LINE;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
//        EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
//        EXTI_Init(&EXTI_InitStructure);
        /* Configure one bit for preemption priority */
//        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        /* SPI1 configuration */
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(SPI_AD, &SPI_InitStructure);
        /* Enable SPI1  */
        SPI_Cmd(SPI_AD, ENABLE);
Func: AD7799忙判断
Time: 2012-3-29
Ver.: V1.0
Note: 0/OK >0/ERROR,timeout
bool AD_WaitBusy()
        int i;
        AD_CS_LOW();
        i=0;
        while(AD_MISORead()){
                i++;
                if(i>2000)
                        return TRUE;
        AD_CS_HIGH();
        return FALSE;
Func: AD7799读取寄存器数据
Time: 2012-3-29
Ver.: V1.0
Note:
void AD_RegRead(u8 RegAddr,u8 *Buffer,int Length)
        AD_CS_LOW();
        RegAddr|=AD_OP_READ;
        while (SPI_I2S_GetFlagStatus(SPI_AD, SPI_I2S_FLAG_TXE) == RESET);
        SPI_I2S_SendData(SPI_AD,RegAddr);
        for(int i=0;i<Length;i++)
                SPI_I2S_SendData(SPI_AD,0x0);
                while (SPI_I2S_GetFlagStatus(SPI_AD, SPI_I2S_FLAG_RXNE) == RESET);
                Buffer = SPI_I2S_ReceiveData(SPI_AD);
        AD_CS_HIGH();
Func: AD7799写入寄存器数据
Time: 2012-3-29
Ver.: V1.0
Note:
void AD_RegWrite(u8 RegAddr,u8 *Buffer,int Length)
        AD_CS_LOW();
        RegAddr|=AD_OP_WRITE;
                SPI_I2S_SendData(SPI_AD,Buffer);
        AD_CS_HIGH();
Func: AD7799复位
Time: 2012-3-29
Ver.: V1.0
Note: 0/OK >0/Error
void AD_Reset()
    u8 Cmd[4]={0xFF,0xFF,0xFF,0xFF};
        AD_CS_LOW();
        for(int i=0;i<4;i++)
                SPI_I2S_SendData(SPI_AD,Cmd);
        AD_CS_HIGH();
Func: AD7799通道内部校准
Time: 2012-3-29
Ver.: V1.0
Note: 0/OK >0/Error
bool AD_Calibrate(u16 cfg)
    bool R=FALSE;
        u8 Cmd[2];
    Cmd[0]=cfg/0x100;
    Cmd[1]=cfg%0x100;
    AD_RegWrite(AD_REG_CONFIG,Cmd,2);        //设置配置寄存器
    Cmd[0]=AD_MODE_IZCM/0x100;
    Cmd[1]=AD_MODE_URA15;
    AD_RegWrite(AD_REG_MODE,Cmd,2);                                //进行内部零度校准
    R|=AD_WaitBusy();                                                        //等待校准完成
    Cmd[0]=AD_MODE_IFCM/0x100;
    return R;
Func: AD7799初始化
Time: 2012-3-29
Ver.: V1.0
Note: 0/OK >0/Error
bool AD_Init(u16 cfg0,u16 cfg1,u16 cfg2)
    u8 ID;
        AD_SPIInit();
    AD_Reset();
        DelayMs(10);
//    Wrtos_TaskDelay(10);
    AD_RegRead(AD_REG_STATUS,&ID,1);                        //读取器件ID
    AD_RegRead(AD_REG_ID,&ID,1);                        //读取器件ID
任何时候这儿读出都是0,明显不对
    if((ID==0xFF)||(ID==0x00))
                return TRUE;
    AD_Calibrate(cfg0);                //通道1校准
    AD_Calibrate(cfg1);                //通道2校准
    AD_Calibrate(cfg2);                //通道3校准
//    Cmd[0]=S6|S5|S4;
//    AD7799_WriteReg(ADC_REG_IO,Cmd,1);
    return FALSE;
Func: AD7799开始转换
Time: 2012-3-29
Ver.: V1.0
Note:
void AD_Start(u16 cfg,u16 mode)
        u8 Cmd[2];
        Cmd[0]=cfg/0x100;
        Cmd[1]=cfg%0x100;
        Cmd[0]=mode/0x100;
        Cmd[1]=mode%0x100;
Func: AD7799读取转换结果
Time: 2012-3-29
Ver.: V1.0
Note:
u32 AD_Read()
        UNION_V v;
        v.v_char[0]=0;
        AD_RegRead(AD_REG_DATA,&v.v_char[1],3);
//        D=TTS_D32FromArray(Cmd,1);
        return v.v_long;
nitu 发表于 2015-1-26 16:15 | 显示全部楼层
楼主,你的问题解决了没有啊?
 楼主| l_a 发表于 2017-3-12 13:47 | 显示全部楼层
已解决,SPI接口配置问题
xiaoxiangyeyuwq 发表于 2018-7-21 15:10 | 显示全部楼层
已解决,SPI接口配置问题
怎么解决的?能说明一下吗,谢谢
bjfxxc 发表于 2020-3-18 17:25 | 显示全部楼层
好东西,谢谢楼主的分享。
香水城 发表于 2020-3-19 12:04 | 显示全部楼层
好东西,谢谢楼主的分享。
如果使用 STM32CubeMx工具来做配置可以 省却很多因为 管脚分配、管脚复用、时钟配置方面的问题,
真的省很多事!
bjfxxc 发表于 2020-4-17 22:50 | 显示全部楼层
请问楼主,这个问题是怎么解决的?SPI需要怎样的配置?
l_a
