STM32串口应该如何正确配置及疑问?
9110|12
 楼主| 雨落沉轩 发表于 2013-1-7 14:17 | 显示全部楼层 |阅读模式
串口配置的部分程序:
static void USART_Config(void)
  USART_InitTypeDef USART_InitStructure;
  /* Enable GPIOC and GPIOE clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC , ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOE , ENABLE);
  /* Enable USART1 APB clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
  /* USART1 Pins configuration
  /* Connect pin to Periph */
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_7);
  GPIO_PinAFConfig(GPIOE, GPIO_PinSource1, GPIO_AF_7);
  /* Configure pins as AF pushpull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
这是官方下载的例子,我跑这个例子,用串口调试助手检查不到端口。
对于F3串口初始还有几点疑惑:
1:通过查看手册发现STM32有两个,USART1:PC3、PC4和PE0、PE1.为什
么要设两个呢?而且上面例子中,UARTTX选择PC4,UARTRX选择PE1,这
又是为什么?
2:上面USART1 Pins两个都配置成了推免输出,我查看以一下其他STM32的串口是这样配置的,串口TX对应I/O口配置成推免输出模式,RX口配置成浮空,如:
这是芯达STM32入门系列教程USART串口编程里的配置:
结构的成员设置如下:
GPIO_StructInit(&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA , &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
上面那个配置成推免,下面配置成GPIO_Mode_IN_FLOATING。但我的stm32f30x_gpio.h的文件里对于GPIO_Mode模式里并没有GPIO_Mode_IN_FLOATING选项,于是我修改成下面形式,不知道是否表示浮空
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
但结果烧写完程序还是无法检测到串口工作。请高手指点
jiaxinhui 发表于 2013-1-7 16:40 | 显示全部楼层
你还没有说明你用的芯片的具体型号呢
uet_cache 发表于 2013-1-7 16:49 | 显示全部楼层
F3 要配置重映射功能的,而且配置方法与F1不同。
帖段代码给你看吧:
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA , ENABLE);
  GPIO_DeInit(GPIOA);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_7);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_7);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
不行,就买我开发板吧,配了各种例程,
 楼主| 雨落沉轩 发表于 2013-1-7 17:46 | 显示全部楼层
帖段代码给你看吧:
哦,看到过重映射,但对这个不是很理解。你的这几行:
意思是把A9、A10都配置成推免上拉方式,而不像F1中一个要上拉,一个要浮空吧。这样理解可以吗?还有哪段代码是体现重映射思想,不是很理解。
 楼主| 雨落沉轩 发表于 2013-1-7 17:47 | 显示全部楼层
你还没有说明你用的芯片的具体型号呢
不好意思,没说清楚,是STM32F3DISCOVERY,之前活动中申请到的
uet_cache 发表于 2013-1-7 17:51 | 显示全部楼层
为重映射,,可以查看手册,,
 楼主| 雨落沉轩 发表于 2013-1-7 18:10 | 显示全部楼层
  GPIO_PinAF ...
好的,这句话我原本以为就是将普通I/O配置成UART串口功能的意思,原来这就是重映射,多谢讲解。那请问你我上述的理解对吗?就是在F3中就不需要吧串口对应的端口配置为一个上拉,一个浮空,而只需要像上述你的配置就行了。是吧?
uet_cache 发表于 2013-1-7 18:43 | 显示全部楼层
上面我帖的代码是测试通过了的
uet_cache 发表于 2013-1-7 18:44 | 显示全部楼层
我有个专门帖F3例程的帖,上传了8个例程的,,你可以参考下
 楼主| 雨落沉轩 发表于 2013-1-7 19:43 | 显示全部楼层
能发给链接吗,没找到,谢谢
uet_cache 发表于 2013-1-7 19:50 | 显示全部楼层
sunnyhey 发表于 2013-1-8 15:13 | 显示全部楼层
其实串口是STM32的所有外设中最简单的,配置好管脚,TX配置成输出模式(推挽还是开漏要看你的硬件有没有上拉电阻),RX配置成输入模式(上拉、下拉或浮空,也要看硬件连接),是复用的管脚需要映射下,不是复用的直接用,至于收发数据,你可以开个中断,先自发自收。
