【我的DIY设计】+7寸触摸屏的驱动
4099|16
 楼主| 13752718641 发表于 2013-1-15 10:52 | 显示全部楼层 |阅读模式
大家好,在这学生都要忙着放假过年的日子里,我的DIY设计是用STM32F3的开发板驱动了一个7寸的电阻触摸屏。
下面给大家看下基本程序
void Drow_Touch_Point(u16 x,u16 y)
LCD_DrawLine(x-12,y,x+13,y);
LCD_DrawLine(x,y-12,x,y+13);
LCD_DrawPoint(x+1,y+1);
LCD_DrawPoint(x-1,y+1);
LCD_DrawPoint(x+1,y-1);
LCD_DrawPoint(x-1,y-1);
Draw_Circle(x,y,6);
void Draw_Big_Point(u16 x,u16 y)
LCD_DrawPoint(x,y);//?DD?μ?
LCD_DrawPoint(x+1,y);
LCD_DrawPoint(x,y+1);
void Refreshes_Screen(void)
ssd1963_Clear(BLACK);//???á
WriteString(776,0,"RST",BLUE,BLACK);
void Convert_Pos(void)
if(Read_ADS2(&Pen_Point.X,&Pen_Point.Y))
  Pen_Point.X0=Pen_Point.xfac*Pen_Point.X+Pen_Point.xoff;
  Pen_Point.Y0=Pen_Point.yfac*Pen_Point.Y+Pen_Point.yoff;
void Touch_Adjust(void)
u16 pos_temp[4][2];
u8  cnt=0;
u16 d1,d2;
u32 tem1,tem2;
float fac;
cnt=0;
Drow_Touch_Point(20,20);
Pen_Point.Key_Sta=Key_Up;
Pen_Point.xfac=0;
while(1)
  if(Pen_Point.Key_Sta==Key_Down)
   if(Read_TP_Once())
    pos_temp[cnt][0]=Pen_Point.X;
    pos_temp[cnt][1]=Pen_Point.Y;
    cnt++;
   switch(cnt)
    case 1:
     ssd1963_Clear(WHITE);
     Drow_Touch_Point(780,20);
     break;
    case 2:
     Drow_Touch_Point(20,460);
     break;
    case 3:
     Drow_Touch_Point(780,460);
     break;
    case 4:
     tem1=abs(pos_temp[0][0]-pos_temp[1][0]);//x1-x2
     tem2=abs(pos_temp[0][1]-pos_temp[1][1]);//y1-y2
     tem1*=tem1;
     tem2*=tem2;
     d1=sqrt(tem1+tem2);
     tem1=abs(pos_temp[2][0]-pos_temp[3][0]);//x3-x4
     tem2=abs(pos_temp[2][1]-pos_temp[3][1]);//y3-y4
     tem1*=tem1;
     tem2*=tem2;
     d2=sqrt(tem1+tem2);
     fac=(float)d1/d2;
     if(fac<0.95||fac>1.05||d1==0||d2==0)
      cnt=0;
      continue;
     tem1=abs(pos_temp[0][0]-pos_temp[2][0]);//x1-x3
     tem2=abs(pos_temp[0][1]-pos_temp[2][1]);//y1-y3
     tem1*=tem1;
     tem2*=tem2;
     d1=sqrt(tem1+tem2);
     tem1=abs(pos_temp[1][0]-pos_temp[3][0]);//x2-x4
     tem2=abs(pos_temp[1][1]-pos_temp[3][1]);//y2-y4
     tem1*=tem1;
     tem2*=tem2;
     d2=sqrt(tem1+tem2);
     fac=(float)d1/d2;
     if(fac<0.95||fac>1.05)
      cnt=0;
      continue;
     tem1=abs(pos_temp[1][0]-pos_temp[2][0]);//x1-x3
     tem2=abs(pos_temp[1][1]-pos_temp[2][1]);//y1-y3
     tem1*=tem1;
     tem2*=tem2;
     d1=sqrt(tem1+tem2);
     tem1=abs(pos_temp[0][0]-pos_temp[3][0]);//x2-x4
     tem2=abs(pos_temp[0][1]-pos_temp[3][1]);//y2-y4
     tem1*=tem1;
     tem2*=tem2;
     d2=sqrt(tem1+tem2);
     fac=(float)d1/d2;
      cnt=0;
      continue;
                   Pen_Point.xfac=(long double)760/(pos_temp[1][0]-pos_temp[0][0]);
     Pen_Point.xoff=(800-Pen_Point.xfac*(pos_temp[1][0]+pos_temp[0][0]))/2;
     Pen_Point.yfac=(long double)440/(pos_temp[2][1]-pos_temp[0][1]);
     Pen_Point.yoff=(480-Pen_Point.yfac*(pos_temp[2][1]+pos_temp[0][1]))/2;//μ?μ?yoff
     WriteString(35,110,"Touch Screen Adjust OK!",RED,BLACK);
     Delay1(20);
     return;
void Touch_Init()
Touch_Configuration();
  Read_ADS(&Pen_Point.X,&Pen_Point.Y);
   GPIO_EXTILineConfig(GPIO_PortSourceGPIOG, GPIO_PinSource7);
   EXTI_InitStructure.EXTI_Line = EXTI_Line7;
   EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
   EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
   EXTI_InitStructure.EXTI_LineCmd = ENABLE;
   EXTI_Init(&EXTI_InitStructure);
   EXTI_GenerateSWInterrupt(EXTI_Line7);
#ifdef ADJ_SAVE_ENABLE
if(Get_Adjdata())return;
else
  ili9320_Clear(WHITE);//???á
     Touch_Adjust();
  Save_Adjdata();
Get_Adjdata();
#else
    Touch_Adjust();
#endif
驱动效果
驱动效果
驱动效果
驱动效果
驱动效果
驱动效果
驱动效果
驱动效果
驱动效果
驱动效果
mcu200689 发表于 2013-1-15 15:27 | 显示全部楼层
赞一个
568581185 发表于 2013-1-15 19:37 | 显示全部楼层
dyf1003 发表于 2013-1-15 20:47 | 显示全部楼层
logger 发表于 2013-1-15 22:08 | 显示全部楼层
不错啊
it_yrj 发表于 2013-1-15 22:41 | 显示全部楼层
楼主太棒了
tianyaddy 发表于 2013-1-23 10:58 | 显示全部楼层
louyj 发表于 2013-1-24 10:31 | 显示全部楼层
楼主V5啊。
ABCDELF 发表于 2013-1-28 15:59 | 显示全部楼层
不错不错,顶一个
qq20707 发表于 2013-2-27 21:22 | 显示全部楼层
赞一个
qq20707 发表于 2013-2-27 21:23 | 显示全部楼层
楼主 在哪买的屏!!能不能给个链接啊
txcy 发表于 2013-2-27 23:35 | 显示全部楼层
不错的DIY作品
qianzeqi 发表于 2013-2-28 10:32 | 显示全部楼层
没看出来那里diy了。这个7寸屏幕,淘宝上买的吧,200+;屏幕的程序,网上也有,貌似红牛开发板的。我记得屏幕背面能插sd卡
qianzeqi 发表于 2013-2-28 10:33 | 显示全部楼层
你的那个开发板,倒是没见过
baidudz 发表于 2013-2-28 13:22 | 显示全部楼层
很不错的DIY设计
dsqiu 发表于 2013-2-28 20:58 | 显示全部楼层
不错,谢谢分享!!!!!
guanlilp 发表于 2013-5-24 16:40 | 显示全部楼层
挺不错的
