那位兄弟用过STC的89C516RD+
5233|1
 楼主| chuandaoxy 发表于 2007-11-28 16:52 | 显示全部楼层 |阅读模式
STC说516兼容AT89C51RD2,我从ATMEL的官方网上下了个程序测试毫无反应
晶振设置稍有不同测试代码用的是11.0592,我的板子是18.432
问题在STC的单片机里有没有BDRCON这个寄存器,波特率不对也应该有乱玛呀
#include "reg_c51.h"
char uart_data;
 * FUNCTION_PURPOSE: This file set up uart in mode 1 (8 bits uart) with
 * internal baud rate generator.
 * FUNCTION_INPUTS: void
 * FUNCTION_OUTPUTS: void
void main (void)
   SCON = 0x50;        /* uart in mode 1 (8 bit), REN=1 */
   BDRCON &=0xEC;                     /* BRR=0; SRC=0; */
   BDRCON |=0x0C;                     /* TBCK=1;RBCK=1; SPD=0 */
   BRL=0xF6;                          /* 9600 Bds at 11.059MHz */
     ES = 1;              /* Enable serial interrupt    */
    EA = 1;            /* Enable global interrupt */
   BDRCON |=0x10;                     /* Baud rate generator run*/
   while(1);                          /* endless */
 * FUNCTION_PURPOSE: serial interrupt, echo received data.
 * FUNCTION_INPUTS: P3.0(RXD) serial input
 * FUNCTION_OUTPUTS: P3.1(TXD) serial output
void serial_IT(void) interrupt 4
    if (RI == 1)
    {        /* if reception occur */
      RI = 0; /* clear reception flag for next reception */
      uart_data = SBUF;          /* Read receive data */
      SBUF = uart_data;  /* Send back same data on uart*/
    else TI = 0;                  /* if emission occur */
      /* clear emission flag for next emission*/
jjg 发表于 2007-11-28 17:14 | 显示全部楼层
那你不会去看STC的datasheet?
