sd卡的spi初始化问题~~~~~~高手帮忙啊
4868|8
 楼主| mcu_protel 发表于 2008-4-19 11:14 | 显示全部楼层 |阅读模式
给sd卡初始化为spi模式
cmd0,cmd1都没有正确响应
每次响应都不是0x01和0x00,程序中加上响应判断就初始化不成功
如果忽略响应,依次发送cmd0,cmd1,那么初始化就很成功,不过每个命令都要反复发送多次才可以,只发送一次也是不成功
各位高手,你们帮帮我啊,郁闷了很多天了
 楼主| mcu_protel 发表于 2008-4-19 11:44 | 显示全部楼层
进来的有什么
想法都说说啊
古道热肠 发表于 2008-4-19 12:11 | 显示全部楼层
用我用的SD卡驱动试试吧
原因自己去找,提醒一下SD卡未初始化时,SPI通信CLK频率一定要低。
#include "..incincludes.h"
#include "New_sd.h"
sbit c_SPI_CS = P2^4;        //Sht-mp3 Config
//set MMC_Chip_Select to high (MMC/SD-Card Invalid)
#define SD_Disable()   c_SPI_CS = 1
//set MMC_Chip_Select to low (MMC/SD-Card Active)
#define SD_Enable()    c_SPI_CS = 0
sbit c_SPI_SI = P1^5;
sbit c_SPI_SO = P1^6;
sbit c_SPI_CLK = P1^7;
sbit c_SD_In = P2^7;
sbit c_SD_WP = P2^6;
sbit c_SD_Power = P2^3;
#define Macro_Set_SI_High()      c_SPI_SI = 1
#define Macro_Set_SI_Low()      c_SPI_SI = 0
#define Macro_Set_CLK_High()      c_SPI_CLK = 1
#define Macro_Set_CLK_Low()      c_SPI_CLK = 0
//bool bSPICLK_LowSpeed;
static void SD_PowerOn(void)
    c_SD_Power = 0;
static void SD_PowerOff(void)
    c_SD_Power = 1;
//extern uint8 BUFFER[512];
uint8 SD_SPI_ReadByte(void);
void SD_SPI_WriteByte(uint8 ucSendData);
//#define SPI_ReadByte()  SD_SPI_ReadByte()
//#define SPI_TransferByte(x) SD_SPI_WriteByte(x)
static uint8 SPI_ReadByte(void)
    uchar ucReadData;
    uchar ucCount;
    ucReadData = 0;
    Macro_Set_SI_High();
    for(ucCount=0; ucCount<8; ucCount++)
        ucReadData <<= 1;
            //降低时钟频率
        Macro_Set_CLK_Low();
        //降低时钟频率
//        if(bSPICLK_LowSpeed)
//            Delay_100us();
        Macro_Set_CLK_High();
//            Delay_100us();
        if(c_SPI_SO)
            ucReadData |= 0x01;
    return(ucReadData);
 //  SPDR = 0xFF;
 //  while (!(SPSR & 0x80));
 //  return SPDR;
static void SPI_TransferByte(uint8 ucSendData)
    uchar ucCount;
    uchar ucMaskCode;
    ucMaskCode = 0x80;
        if(ucMaskCode & ucSendData)
        else
            Macro_Set_SI_Low();
        //降低时钟频率
//            Delay_100us();
        ucMaskCode >>= 1;
        //降低时钟频率
//            Delay_100us();
 //SPDR=cmp1;
 //while(!(SPSR&(1<<SPIF)));
    uchar ucReadData;
    uchar ucCount;
    ucReadData = 0;
        ucReadData <<= 1;
            //降低时钟频率
        //降低时钟频率
//            Delay_100us();
//            Delay_100us();
        if(c_SPI_SO)
            ucReadData |= 0x01;
    return(ucReadData);
 //  SPDR = 0xFF;
 //  return SPDR;
    uchar ucCount;
    uchar ucMaskCode;
    ucMaskCode = 0x80;
        else
            Macro_Set_SI_Low();
        //降低时钟频率
//            Delay_100us();
        ucMaskCode >>= 1;
        //降低时钟频率
//            Delay_100us();
 //SPDR=cmp1;
void SD_Port_Init(void)
    c_SPI_SO = 1;
    c_SD_In = 1;
    c_SD_WP = 1;
     SD_PowerOn();
//Send a Command to MMC/SD-Card
//Return: the second byte of response register of MMC/SD-Card
uint8 Write_Command_SD(uint8 *cmd)
        uint8 tmp,i;
        uint8 retry=0;
        SD_Disable();
        SPI_TransferByte(0xFF);
        SD_Enable();
        for(i=0;i<6;i++)
        SPI_TransferByte(*cmd++);
        SPI_ReadByte();
        do{
                tmp = SPI_ReadByte();
        }while((tmp==0xff)&&(retry++ <100));
        return(tmp);
uint8 Write_Command_SD_HighSpeed(uint8 *cmd)
        uint8 tmp,i;
        uint8 retry=0;
        SD_Disable();
        SD_SPI_WriteByte(0xFF);
        SD_Enable();
        for(i=0;i<6;i++)
        SD_SPI_WriteByte(*cmd++);
        SD_SPI_ReadByte();
        do{
                tmp = SD_SPI_ReadByte();
        return(tmp);
//Routine for Init MMC/SD card(SPI-MODE)
uint8 SD_Init(void)
        uint8 retry,temp;
        uint8 i;
       uint8  CMD[] = {0x40,0x00,0x00,0x00,0x00,0x95};
   SD_Port_Init(); //Init SPI port
//   for (i = 0; i < 200; i++) asm("nop"); //Wait MMC/SD ready...
            _nop_();
   //Active SPI bus at low speed
 //  SPCR=0x53; //SPI Master,MSB First
 //  SPSR=0x00; //double speed disable,Fsck=Fosc/128
   for (i = 0; i < 16; i++)
      SPI_TransferByte(0xff); //send 74 clock at least!!!
   //Send Command CMD0 to MMC/SD Card
   SD_Enable();
   retry = 0;
   do
   { //retry 200 times to send CMD0 command
     temp = Write_Command_SD(CMD);
     if (retry++ == 200)
       return INIT_CMD0_ERROR;//CMD0 Error!
   while (temp != 1);
   //Send Command CMD1 to MMC/SD-Card
   CMD[0] = 0x41; //Command 1
   CMD[5] = 0xFF;
   retry = 0;
   do
   { //retry 100 times to send CMD1 command
     if (retry++ == 100)
       return INIT_CMD1_ERROR;//CMD1 Error!
   while (temp != 0);
   //Active High-speed SPI mode(Fsck=Fosc/2)
 //  SPCR = 0x50;
 //  SPSR = 0x00;
   SD_Disable();  //set MMC_Chip_Select to high
   return INIT_OK; //All commands have been taken.
uint8 SD_Read_Block(uint8 *CMD,uint8  *Buffer,uint16 Bytes)
   uint16 i;
   uint8 retry, temp;
   //Send Command CMD to MMC/SD-Card
   retry=0;
//#if 1
   do
   {  //Retry 100 times to send command.
//      temp=Write_Command_SD(CMD);
        temp=Write_Command_SD_HighSpeed(CMD);
      if(retry++ == 100)
        return READ_BLOCK_ERROR; //block write Error!
   while (temp != 0);
   //Read Start Byte form MMC/SD-Card (FEh/Start Byte)
   while (SPI_ReadByte() != 0xfe);
//#endif
   //Read blocks(normal 512Bytes) to MMC/SD-Card
#if 1
   for (i = 0; i < Bytes; i++)                //int count for loop cost 13 machine cycle
//      *Buffer++ = SPI_ReadByte();            //Cost 70 Machine Cycle
                                            //When define point is a Xdata point then Cost 62 Machine Cycle
      *Buffer++ = SD_SPI_ReadByte();            //Cost 70 Machine Cycle
     // put_c(*Buffer);
#endif
    i = Bytes;
    while(i--)                                //When Delete {} 2 Machine Cycle is save.
   //CRC-Byte
   SPI_ReadByte();//CRC - Byte
   //set MMC_Chip_Select to high (MMC/SD-Card invalid)
   SD_Disable();
   return READ_BLOCK_OK;
//Routine for writing a Block(512Byte) to MMC/SD-Card
//Return 0 if sector writing is completed.
uint8 SD_read_sector(uint32 addr,uint8  *Buffer)
       //Command 16 is reading Blocks from MMC/SD-Card
   uint8  CMD[] = {0x51,0x00,0x00,0x00,0x00,0xFF};
//   asm("cli"); //clear all interrupt.
   //Address conversation(logic block address-->byte address)
   addr = addr << 9; //addr = addr * 512
   CMD[1] = ((addr & 0xFF000000) >>24 );
   CMD[2] = ((addr & 0x00FF0000) >>16 );
   CMD[3] = ((addr & 0x0000FF00) >>8 );
   return SD_Read_Block(CMD, Buffer, 512);
uint8 SD_write_sector(uint32 addr,uint8 *Buffer)
   uint8 tmp,retry;
   uint16 i;
   //Command 24 is a writing blocks command for MMC/SD-Card.
   uint8 CMD[] = {0x58,0x00,0x00,0x00,0x00,0xFF};
   //Send Command CMD24 to MMC/SD-Card (Write 1 Block/512 Bytes)
   retry=0;
   do
      tmp = Write_Command_SD(CMD);
      if(retry++ == 100)
        return(tmp); //send commamd Error!
   while(tmp != 0);
   //Before writing,send 100 clock to MMC/SD-Card
   for (i = 0; i < 100; i++)
      SPI_ReadByte();
   //Send Start Byte to MMC/SD-Card
   SPI_TransferByte(0xFE);
   //Now send real data Bolck (512Bytes) to MMC/SD-Card
   for (i = 0; i < 512; i++)
      SPI_TransferByte(*Buffer++); //send 512 bytes to Card
   //CRC-Byte
   SPI_TransferByte(0xFF); //Dummy CRC
   SPI_TransferByte(0xFF); //CRC Code
   tmp=SPI_ReadByte();   // read response
   if((tmp & 0x1F) != 0x05) // data block accepted ?
     SD_Disable();
     return WRITE_BLOCK_ERROR; //Error!
   //Wait till MMC/SD-Card is not busy
   while (SPI_ReadByte() != 0xFF){};
   SD_Disable();
   return 0;
extern unsigned char xdata Page_Buf[512];        //文件缓冲区。
//测试SD卡SPI接口性能
void TestSD_SPIFunc(void)
    uchar ucCount;
    uchar ucReadData;
    ucCount = 0;        //开始
    for(ucCount=0; ucCount<10; ucCount++)
//        SPI_TransferByte(0x88);            //用C语言实现的写字节机器周期数为188
        SD_SPI_WriteByte(0x88);
                                        //用C51的bData变量,采用位指令直接传送操作,共用机器机器49
    for(ucCount=0; ucCount<50; ucCount++)
        ucReadData = SPI_ReadByte();    //用C语言实现的SPI读字节机器赌周期为154
                                        //自用C51的bData变量,采用位指令操作读字节机器周期为49
    ucCount= 88;        //结束
    SD_read_sector(0,Page_Buf);
好不厉害 发表于 2008-4-19 13:27 | 显示全部楼层
弱问一句
收藏夹咋不能用了
21ic经常间歇性抽风啊
mcspic 发表于 2008-4-19 14:17 | 显示全部楼层
RE:
你初始化时SPI的速度是多少呢,好象最高不超过400KHZ。
 楼主| mcu_protel 发表于 2008-4-21 09:37 | 显示全部楼层
非常感谢大家的帮助
现在已经初始化通过了,我换了一个sd卡就可以了,程序没问题,可能是硬件问题吧
 楼主| mcu_protel 发表于 2008-4-21 09:58 | 显示全部楼层
顺便问一下
 楼主| mcu_protel 发表于 2008-4-21 10:01 | 显示全部楼层
顺便问一下古道热肠
您使用VS1003播放的mp3最高速率是多大?
我用的stc单片机,晶振26M的放128k都卡的要命,64k没问题真是不理想啊!!
 楼主| mcu_protel 发表于 2008-4-21 15:19 | 显示全部楼层
古道兄呢?
古道兄
