最近用TSC2003做触摸屏,碰到难题请大侠们指教
2985|0
 楼主| keke 发表于 2008-7-29 18:57 | 显示全部楼层 |阅读模式
读取x,y数据总是255,正常应该为x=0,y=255; or x=255,y=0.查了好久没有发现问题。
程序如下:
#include <REG51.h>
#include "intrins.h"
typedef unsigned char   UINT8;
typedef unsigned int    UINT16;
typedef unsigned long   UINT32;
/*Address Byte
1    0    0    1    0     A1    A0    R/W
|_____________|             |_____|
    fixed bits            input pins   read"1"/write"0"
#define TSC2003_WRITE   0x90    //1001 0000
#define TSC2003_READ    0x91    //1001 0001
/*Command Byte
C3   C2   C1   C0    PD1   PD0     M     X
|_____________|   |______|
Configuration bits     power_down bits   mode bit   reserved
//1011 0000 reserved
#define COMMAND_X       0xc0    //1100 0000
#define COMMAND_Y       0xd0    //1101 0000
#define COMMAND_Z1      0xe0    //1110 0000
#define COMMAND_Z2      0xf0    //1111 0000
#define I2C_DELAY       2
unsigned char data touch_x,touch_y;
sbit SDIO           = P1^6;
sbit SCLK           = P1^7;
void ShortDelay(unsigned char time)
    while(--time);
void i2c_start(void)
    SDIO = 1;
    SCLK = 1;
    ShortDelay(I2C_DELAY);
    SDIO = 0;
    SCLK = 0;
void i2c_stop(void)
    SCLK = 0;
    SDIO = 0;
    SCLK = 1;
    SDIO = 1;
UINT8 i2c_byte_wr(UINT8 dat)     /* return 0 --> ack */
    UINT8 i;
    UINT8 temp_value = 0;
    for(i=8; i!=0; i--)
        SCLK = 0;
        SDIO = (bit)(dat & 0x80);
        dat <<= 1;
        SCLK = 1;
    SCLK = 0;
    SDIO = 1;
    SCLK = 1;
    temp_value = SDIO;
    return temp_value;
UINT8 i2c_byte_rd(UINT8 ack)
    UINT8 i, temp_value;
    SDIO = 1;
    temp_value = 0;
    for(i=8; i!=0; i--)
        SCLK = 0;
        SCLK = 1;
        temp_value <<= 1;
        if(SDIO) temp_value++;
    SCLK = 0;
    SDIO = ack;
    SCLK = 1;
    SCLK = 0;
    return temp_value;
void write_tsc2003(unsigned char address,unsigned char command)
    i2c_start();
    i2c_byte_wr(address);
    i2c_byte_wr(command);
    i2c_stop();
unsigned int read_tsc2003(unsigned char address)
    unsigned int retValue;
    i2c_start();
    retValue = i2c_byte_rd(0)*0x100+i2c_byte_rd(1);
    i2c_stop();
    retValue>>=4;
    return (retValue);
void delay_30ms(void)
    unsigned int i;
#ifdef CLOCK6
    for(i = 0; i < 20000; i ++);
#else
    for(i = 0; i < 10000; i ++);
#endif
void main(void)
    IE  = 0;
    IP  = 0;
// init all I/Os
    P0  = 0xff;
    P1  = 0xff;
    P2  = 0xff;
    P3  = 0xff;
    delay_30ms();
    delay_30ms();
    for(;;)
        write_tsc2003(TSC2003_WRITE,COMMAND_X);     //用差分方式读X坐标
        touch_x = read_tsc2003(TSC2003_READ)>>4;    //读X轴坐标地址命令,只取8位数据
        write_tsc2003(TSC2003_WRITE,COMMAND_Y);     //用差分方式读Y坐标
        touch_y = read_tsc2003(TSC2003_READ)>>4;    //读Y轴坐标地址命令,只取8位数据
        P0 = touch_x;   //接8个LED
        P2 = touch_y;   //接8个LED
        delay_30ms();
