这板子,这条线画的牛屎。。跟蚊香一样。。高。。
11552|54
colala 发表于 2013-1-24 16:26 | 显示全部楼层
能点着吗?
xinyipcb 发表于 2013-1-25 19:14 | 显示全部楼层
这个牛。
funior 发表于 2013-1-28 17:00 | 显示全部楼层
要不要这个圈不是重点,牛的是这个
    Dim   Board
    DIM   xm,ym    'mouse coordinate
Sub PlaceSpiralTrackFormCreate(Sender)
    Set Board = PCBServer.GetCurrentPCBBoard
    If Board is Nothing Then Exit Sub
    If Not Board.ChooseLocation(xm,ym,"Choose Spiral Track start location") Then
    End If
    xm = xm/10000               'convert to mils
    ym = ym/10000               '
    PlaceSpiralTrackForm.StartX.Text = xm
    PlaceSpiralTrackForm.StartY.Text = ym
   PlaceSpiralTrackForm.LayerListBox.Text = Layer2String(Board.CurrentLayer)    'get current layer
    If (Board.DisplayUnit) Then
       PlaceSpiralTrackForm.Metric.Checked = false
    Else
       PlaceSpiralTrackForm.Metric.Checked = true                   ' read 0 = Metric, 1 = Inch
    End If
    StartX.Color = RGB(236, 233, 216)
    StartY.Color = RGB(236, 233, 216)
    Spacing.Color = RGB(236, 233, 216)
    TrackWidth.Color = RGB(236, 233, 216)
    Loops.Color = RGB(236, 233, 216)
    ViaSize.Color = RGB(236, 233, 216)
    ViaHoleSize.Color = RGB(236, 233, 216)
End Sub
Sub XPBitBtn1Click(Sender)
    DIM   ArcX1, ArcX2, ArcX3, ArcX4, ArcY1, ArcY2, ArcY3, ArcY4
    DIM   Layer, Radius, Spacing, Width, Offset, Temp
    Dim   Via, Track, Arc
    Dim   MouseX, MouseY
    Else
    End If
    Width = TrackWidth.Text
    Spacing = (PlaceSpiralTrackForm.Spacing.Text)
    Temp = ((Spacing/1) + (Width/1))
    Offset = Temp/4
    Layer = String2Layer(LayerListBox.Text)
    MouseX = StartX.Text
    MouseY = StartY.Text
    ArcX1 = StartX.Text
    ArcY1 = StartY.Text + Offset
    ArcX2 = StartX.Text
    ArcY2 = StartY.Text
    ArcX3 = StartX.Text - Offset
    ArcY3 = StartY.Text
    ArcX4 = StartX.Text - Offset
    ArcY4 = StartY.Text + Offset
    Radius = (ViaSize.Text/2) + (Spacing/1) + (Width/2)
    PlaceSpiralTrackForm.Hide
    PCBServer.PreProcess
'Place Via
    Via           = PCBServer.PCBObjectFactory(eViaObject, eNoDimension, eCreate_Default)
    Via.X         = MilsToCoord(MouseX)
    Via.Y         = MilsToCoord(MouseY)
    Via.Size      = MilsToCoord(ViaSize.Text)
    Via.HoleSize  = MilsToCoord(ViaHoleSize.Text)
    Via.LowLayer  = eTopLayer
    Via.HighLayer = eBottomLayer
    Board.AddPCBObject(Via)
'Place 1st Arc to met start of sprial
       Arc = PCBServer.PCBObjectFactory(eArcObject, eNoDimension, eCreate_Default)
       Arc.XCenter    = MilsToCoord(StartX.Text/1)
       Arc.YCenter    = MilsToCoord((StartY.Text/1) + Radius/2)
       Arc.Layer      = Layer 'eTopLayer
       Arc.LineWidth  = MilsToCoord(Width/1)
       Arc.Radius     = MilsToCoord(Radius/2)
       Arc.StartAngle = 90
       Arc.EndAngle   = 270
       Board.AddPCBObject(Arc)
' LOOP once for every turn
    FOR p0 = 1 TO Loops.Text
'Place arc quadrant
       Arc.XCenter    = MilsToCoord(ArcX2/1)
       Arc.YCenter    = MilsToCoord(ArcY2/1)
       Arc.Radius     = MilsToCoord(Radius/1)
       Arc.StartAngle = 0
       Arc.EndAngle   = 90
       Radius = (Radius + Offset)
       Arc.XCenter    = MilsToCoord(ArcX3/1)
       Arc.YCenter    = MilsToCoord(ArcY3/1)
       Arc.StartAngle = 270
       Arc.EndAngle   = 0
       Arc.XCenter    = MilsToCoord(ArcX4/1)
       Arc.YCenter    = MilsToCoord(ArcY4/1)
       Arc.StartAngle = 180
       Arc.EndAngle   = 270
       Arc.XCenter    = MilsToCoord(ArcX1/1)
       Arc.YCenter    = MilsToCoord(ArcY1/1)
       Arc.StartAngle = 90
       Arc.EndAngle   = 180
    NEXT
   PCBServer.PostProcess
    ' Refresh PCB workspace.
    ResetParameters
    Call AddStringParameter("Action", "Redraw")
    RunProcess("PCB:Zoom")
  Close
End Sub
Sub MetricClick(Sender)
    If    Metric.Checked Then
          StartX.Text = (StartX.Text / 39.37)
          StartY.Text = (StartY.Text / 39.37)
          ViaSize.Text = (ViaSize.Text / 39.37)
          ViaHoleSize.Text = (ViaHoleSize.Text / 39.37)
          Spacing.Text = (Spacing.Text / 39.37)
          TrackWidth.Text = (TrackWidth.Text / 39.37)
    Else
          StartX.Text = (StartX.Text * 39.37)
          StartY.Text = (StartY.Text * 39.37)
          ViaSize.Text = (ViaSize.Text * 39.37)
          ViaHoleSize.Text = (ViaHoleSize.Text * 39.37)
          Spacing.Text = (Spacing.Text * 39.37)
          TrackWidth.Text = (TrackWidth.Text * 39.37)
    End If
End Sub
Sub Main
    PlaceSpiralTrackForm.showmodal
End Sub
Sub XPBitBtn2Click(Sender)
    close
End Sub
qin552011373 发表于 2013-2-5 21:07 | 显示全部楼层
GoldSunMonkey 发表于 2013-2-5 22:04 | 显示全部楼层
jakfens 发表于 2013-2-5 22:40 | 显示全部楼层
这难道就是版图艺术?
GoldSunMonkey 发表于 2013-2-5 22:54 | 显示全部楼层
这难道就是版图艺术?
是呀,艺术
airwill 发表于 2013-2-6 07:32 | 显示全部楼层
这其实就是一个 以 pcb 为骨架的电感.
往往作为电感, pcb 的反面还有个形状一样, 旋向相反的图形呢
jakfens 发表于 2013-2-6 09:44 | 显示全部楼层
是呀,艺术
嘿嘿
GoldSunMonkey 发表于 2013-2-6 23:03 | 显示全部楼层
往往作为电感, pcb 的反面还有个形状一样, 旋向相反的图形呢 ...
原来如此,兄弟有过此经验没有?
feihong777 发表于 2013-2-14 22:40 | 显示全部楼层
原来如此,兄弟有过此经验没有?
我没有。有的给说一下啊
GoldSunMonkey 发表于 2013-2-14 22:54 | 显示全部楼层
我没有。有的给说一下啊
没有折腾啥
LMQQ 发表于 2013-2-15 21:24 | 显示全部楼层
没有折腾啥
。。。什么意思啊
LongChip 发表于 2013-2-15 23:28 | 显示全部楼层
。。。什么意思啊
问猴哥啊
GoldSunMonkey 发表于 2013-2-15 23:32 | 显示全部楼层
。。。什么意思啊
就是没有出去玩的意思
DAXSX 发表于 2013-2-16 11:32 | 显示全部楼层
怎么画的讲解一下啊?
GoldSunMonkey 发表于 2013-2-18 22:52 | 显示全部楼层
怎么画的讲解一下啊?
没有讲解啊
shijiajun4 发表于 2013-2-21 15:57 | 显示全部楼层
这个用的什么元件封装软件画的啊??
GoldSunMonkey 发表于 2013-2-21 22:01 | 显示全部楼层
这个用的什么元件封装软件画的啊??
这个有关系么??
LMQQ 发表于 2013-2-21 22:30 | 显示全部楼层
这个有关系么??
为什么没有关系呢?侯哥
