延时的宏 汇编自定义的一个宏,怎样加到头文件中?
2320|1
 楼主| 龙的图腾 发表于 2009-4-5 19:14 | 显示全部楼层 |阅读模式
;Required Routines & Macros:
;MACROS:
DELAY     macro      Time                  ;Delay "Cycles" instruction cycles
    if (Time==1)
            nop
            exitm
    endif
        if (Time==2)
            goto $ + 1
            exitm
    endif
        if (Time==3)
            nop
            goto $ + 1
            exitm
    endif
        if (Time==4)
            goto $ + 1
            goto $ + 1
        exitm
    endif
        if (Time==5)
            goto $ + 1
            goto $ + 1
        nop
            exitm
    endif
        if (Time==6)
            goto $ + 1
            goto $ + 1
        goto $ + 1
            exitm
    endif
        if (Time==7)
            goto $ + 1
            goto $ + 1
        goto $ + 1
            nop
            exitm
    endif
    if (Time%4==0)
            movlw (Time-4)/4
            call Delay_Routine
            exitm
    endif
    if (Time%4==1)
        movlw (Time-5)/4
            call Delay_Routine
            nop
            exitm
    endif
    if (Time%4==2)
            movlw (Time-6)/4
            call Delay_Routine
            goto $ + 1
        exitm
    endif
    if (Time%4==3)
            movlw (Time-7)/4
            call Delay_Routine
        goto $ + 1
            nop
            exitm
    endif
    endm
; DELAY:
;--------------------------------------------------------------------------------------------- ;Delays 4w+4 cycles (including call,return, and movlw) (0=256)
Delay_Routine        addlw     -1   ;Precise delays used in  I/O
                      btfss    STATUS, Z
             goto    Delay_Routine
                       return
ayb_ice 发表于 2009-4-6 12:20 | 显示全部楼层
直接定义一个专用宏头文件
