MII 时钟生成模块
2125|1
 楼主| uiodh 发表于 2013-2-25 19:44 | 显示全部楼层 |阅读模式
下面是10M/100M IP CORE的MII时钟生成模块,功能是将CLK,分频为mdc=clk/Divider。
module eth_clockgen(Clk, Reset, Divider, MdcEn, MdcEn_n, Mdc);
parameter Tp=1;
input       Clk;              // Input clock (Host clock)
input       Reset;            // Reset signal
input [7:0] Divider;          // Divider (input clock will be divided by the Divider[7:0])
output      Mdc;              // Output clock
output      MdcEn;            // Enable signal is asserted for one Clk period before Mdc rises.
output      MdcEn_n;          // Enable signal is asserted for one Clk period before Mdc falls.
reg         Mdc;
reg   [7:0] Counter;
wire        CountEq0;
wire  [7:0] CounterPreset;
wire  [7:0] TempDivider;
assign TempDivider[7:0]   = (Divider[7:0]<2)? 8'h02 : Divider[7:0]; // 分频>=2
assign CounterPreset[7:0] = (TempDivider[7:0]>>1) - 1'b1;           // 除2减1
// 计数值为半个MDC周期
always @ (posedge Clk or posedge Reset)
begin
  if(Reset)
    Counter[7:0] <= #Tp 8'h1;
  else
    begin
      if(CountEq0)
        begin
          Counter[7:0] <= #Tp CounterPreset[7:0];
        end
      else
        Counter[7:0] <= #Tp Counter - 8'h1;
    end
end
// 当计数值为0,MDC翻转
begin
  if(Reset)
    Mdc <= #Tp 1'b0;
  else
    begin
      if(CountEq0)
        Mdc <= #Tp ~Mdc;
    end
end
// 一些组合信号
assign CountEq0 = Counter == 8'h0;
assign MdcEn = CountEq0 & ~Mdc;
assign MdcEn_n = CountEq0 & Mdc;
endmodule
思考一些问题:1、CountEq0持续多少clk
            2、当这个语句Counter[7:0] <= #Tp Counter - 8'h1中去掉#Tp,仿真时会如何呢?
              3、MdcEn持续多少clk?
