AT24C04写入的数据和读出来的数据不一样
2263|2
 楼主| woowtaotao 发表于 2013-3-13 18:01 | 显示全部楼层 |阅读模式
FOR, ui, TI
void delay1(uchar x)
   uint i;
   for(i=0;i<x;i++);
void clock()
   uchar i=0;
//TRISB = 0B00000011;//设置RB1 SDA为输入
   SCL=1;
    asm("NOP");
   while ((SDA==1)&&(i<255))i++;
   SCL=0;
    asm("NOP");
  // TRISB = 0B00000001;//设置RB1 SDA为输出
void WIN24C02_init()
   SCL=1;
     asm("NOP");
   SDA=1;
     asm("NOP");
void start()
   SDA=1;
    asm("NOP");
   SCL=1;
     asm("NOP");
   SDA=0;
    asm("NOP");
   SCL=0;
     asm("NOP");
void stop()
   SDA=0;
     asm("NOP");
   SCL=1;
     asm("NOP");
   SDA=1;
    asm("NOP");
void writex(uchar j)
   uchar i,temp;
   temp=j;
   for (i=0;i<8;i++)
      SCL=0;
        asm("NOP");
  if  (temp & 0x80) //读取
      SDA=1;
    else
      SDA=0;
    temp=temp<<1;
      //SDA=CY;
       asm("NOP");
      SCL=1;
        asm("NOP");
   SCL=0;
     asm("NOP");
   SDA=1;
    asm("NOP");
char readx()
   uchar i,j,k=0;
   SCL=0;
   asm("NOP");
   SDA=1;
//   TRISB = 0B00000011;//设置RB1 SDA为输入
   for (i=0;i<8;i++)
       asm("NOP");
      SCL=1;
       asm("NOP");
      if (SDA==1) j=1;
      else j=0;
      k=(k<<1)|j;
      SCL=0;
    asm("NOP");
   return(k);
char WIN24C02_read(uchar address)
   uchar i;
   start();
   writex(0xa0);
   clock();
   writex(address);
   clock();
   start();
   writex(0xa1);
   clock();
   i=readx();
   stop();
   delay1(10);
   return(i);
void WIN24C02_write(  uchar address,  uchar info)
  // GIE=0;//关闭中断
   start();
   writex(0xa0);
   clock();
   writex(address);
   clock();
   writex(info);
   clock();
   stop();
  // GIE=1;//打开中断
   delay1(50);
outstanding 发表于 2013-8-16 15:59 | 显示全部楼层
时序问题么?
创隆电子 发表于 2013-8-16 16:39 | 显示全部楼层
用编程器,先看看你的写入数据对不对,在用编程器往24c02写入后读出,看看是写入问题还是读出问题,24C02程序照书上写就行
