用SPI的DMA方式写flash问题
3769|0
 楼主| song19881218 发表于 2013-3-22 11:14 | 显示全部楼层 |阅读模式
  1. void SPI_FLASH_DMA_PageWrite(u8 *pBuffer, u32 WriteAddr, u16 NumByteToWrite)
  3.     //u32 i = 0;
  4.     DMA_InitTypeDef  DMA_InitStructure;
  5.     /* MSD chip select low */
  6.     SPI_FLASH_CS_LOW();
  7.     /*initial the spi1 in write mode*/
  8.     /*initial dma channel5*/
  9.     DMA_DeInit(DMA1_Channel5);
  10.     DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI2->DR;
  11.     DMA_InitStructure.DMA_MemoryBaseAddr = (u32)pBuffer;
  12.     DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  13.     DMA_InitStructure.DMA_BufferSize = NumByteToWrite;
  14.     DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  15.     DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  16.     DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  17.     DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  18.     DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  19.     DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  20.     DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  21.     DMA_Init(DMA1_Channel5, &DMA_InitStructure);
  22.     SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
  23.    // SPI_Cmd(SPI1, ENABLE);
  24.    SPI_FLASH_WriteEnable();
  25.     SPI_FLASH_CS_LOW();
  26.   /* Send "Write to Memory " instruction */
  27.     SPI_FLASH_SendByte(WRITE);
  28.   /* Send WriteAddr high nibble address byte to write to */
  29.     SPI_FLASH_SendByte((WriteAddr & 0xFF0000) >> 16);
  30.   /* Send WriteAddr medium nibble address byte to write to */
  31.     SPI_FLASH_SendByte((WriteAddr & 0xFF00) >> 8);
  32.   /* Send WriteAddr low nibble address byte to write to */
  33.     SPI_FLASH_SendByte(WriteAddr & 0xFF);
  34.     DMA_Cmd(DMA1_Channel5, ENABLE);
  35.     while(!DMA_GetFlagStatus(DMA1_FLAG_TC4)) ;
  36.
  37.         DMA_Cmd(DMA1_Channel5, DISABLE);
  38.     /* MSD chip select high */
  39.     SPI_FLASH_CS_HIGH();
  40.     /* Send dummy byte: 8 Clock pulses of delay */
  41.     SPI_FLASH_SendByte(0xA5);
  42. }
  43. 为什么不行呢,一直死到这个里面while(!DMA_GetFlagStatus(DMA1_FLAG_TC4)) ;
