【非典】16 bits to packed BCD, 51 ASM. 61周期/80字节
7069|26
 楼主| dengm 发表于 2007-4-2 17:36 | 显示全部楼层 |阅读模式
BCD, ck, AC, ov, vr
  TEST_NUM  EQU 65432
  ORG 000H
    MOV R2, #LOW(TEST_NUM) ; #11111111B
    MOV R3, #HIGH(TEST_NUM); #11111111B ; 65535
    CALL BIN2BCD
    SJMP $
BIN2BCD:
    ;Input:  R3:R2 --- 16 bits bin         |
    ;                R2--Bit 0 to bit 7    |
    ;                R3--Bit 8 to bit 15   |
    ;Output: R7:R6:R5 --- 5 Dig Packed BCD |
    ;                     R5: 个位/十位    |
    ;                     R6: 百位/千位    |
    ;                     R7: 万位         |
    ;Usage:  PSW (C, AC, OV), Acc, B       |
    ;PS: 61 CYs only.  78 bytes            |
    ;           DengMiao  2007-4 Guangzhou |
    MOV A, R3
    RRC A
    MOV B, A
    MOV A, R2
    RRC A
    MOV C, B.0
    RRC A
    XCH A, B
    RR A
    ANL A, #00111111B
    MOV R5, A
    RL A
    ADD A, R5
    XCH A, B
    ADD A, B
    JC BIN2BCD_L1
      SJMP BIN2BCD_L2
BIN2BCD_L1:
      INC R5
      ADD A, #6
BIN2BCD_L2:
    ADD A, B
    JC BIN2BCD_L1B
      SJMP BIN2BCD_L2B
BIN2BCD_L1B:
      INC R5
      ADD A, #6
BIN2BCD_L2B:
    MOV B, #25
    DIV AB
    CJNE A, #10, BIN2BCD_L3
      INC R5
      CLR A
BIN2BCD_L3B:
    MOV R7, A  ; *100
    MOV A, R2
    ANL A, #00000011B
    MOV R6, A
    MOV A, #10
    XCH A, B
    RL A
    RL A
    ORL A, R6
    DIV AB
    SWAP A
    ORL A, B
    XCH A, R5
    MOV B, #10
    DIV AB
    XCH A, R7
    SWAP A
    ORL A, B
    SWAP A
    MOV R6, A
    RET
BIN2BCD_L3:
    SJMP BIN2BCD_L3B
;----------END OF BIN2BCD-------
  END
 楼主| dengm 发表于 2007-4-20 08:36 | 显示全部楼层
airwill 发表于 2007-4-2 21:54 | 显示全部楼层
哇, 够精练哪! 佩服
 楼主| dengm 发表于 2007-4-3 02:41 | 显示全部楼层
算法说明:
把16bits, 分为3段:
     X -- Bit 10 到 Bit 15, 共 6 bits; (0 - 63)      *1024
     Y -- Bit 2 到 Bit 9,   共 8 bits; (0 - 255)     *4
     Z -- Bit 0 到 Bit 1,   共 2 bits; (0 - 3)       *1
可得到:
     1024 * X + 4 * Y + Z
   = 1000 * X + 24 * X + 4 * Y + Z
   = 1000 * X + 4 * ( 6 * X + Y ) + Z
   = 1000 * X + 4 * [ Y + (3*X) + (3*X)] + Z
  其中 X 的范围为 0 -- 63, 那么(3*X)的范围就为 0 -- 189, <255 (1 byte)
Y+(3*X) 如进位就 X 加1, [Y+(3*X)]-256 加 6, (因为 24 = 4 * 6).
另外, {[Y + (3*x)] - 256}+6 < 255 .
  = 1000 * (X+i) + 4 * {[Y + (3*x) + (3*x)] + 6 * i } + Z
  =   1000 * (X+i)
     + 100 * {[Y+3*X+3*X+6*i]  25 }
     + 4 * {[Y+3*X+3*X+6*i] MOD  25 }  + Z
其中   i          范围为    0 -- 2
     {[Y+3*X+3*X+6*i]  25 } <= 10
     4 * {[Y+3*X+3*X+6*i] MOD  25 }  + Z <= 99
 楼主| dengm 发表于 2007-4-3 03:13 | 显示全部楼层
速度优化:
      优化                       一般
    MOV A, R3                  MOV A, R3
    RRC A                      CLR C
                               RRC A
    MOV B, A                   MOV B, A
    MOV A, R2                  MOV A, R2
                               XCH A, B
    RRC A                      RRC A
    MOV C, B.0                 XCH A, B
                               CLR C
    RRC A                      RRC A
    XCH A, B                   XCH A, B
    RR A                       RRC A
    ANL A, #00111111B          XCH A, B
    MOV R5, A                  MOV R5, A
    RL A                       RL A
    ADD A, R5                  ADD A, R5
    XCH A, B                   XCH A, B
 楼主| dengm 发表于 2007-4-3 11:58 | 显示全部楼层
【非典】16 bits to packed BCD, 51 ASM. 61周期/73字节(注释)
  TEST_NUM  EQU 12345
  ORG 000H
    CALL BIN2BCD
    SJMP $
BIN2BCD:
    ;                     R5: 个位/十位    |
    ;                     R6: 百位/千位    |
    ;                     R7: 万位         |
    ;PS: 61 CYs only.  73 bytes            |
    MOV A, R2
    ANL A, #00000011B
    MOV R6, A     ; R6 --- *1  (bit 0 to bit 1) (2 bits)
    MOV A, R3
    RRC A
    MOV B, A
    MOV A, R2
    RRC A
    MOV C, B.0
    RRC A
    MOV R7, A    ; R7 --- *4  (bit 2 to bit 10) (8 bits)
    MOV A, #25   ; 25 * 4 = 100
    XCH A, B
    RR A
    ANL A, #00111111B
    MOV R5, A    ; R5 --- *1024 (bit 11 to bit 15) (6 bits)
    RL A
    ADD A, R5
    XCH A, R7    ; R7 == 3 * R5   (<= 3*63=189 < 255)
                 ; A  --- *4
    ADD A, R7    ; 4* (A + 3*R5)
    JC BIN2BCD_L1
      SJMP BIN2BCD_L2
BIN2BCD_L1:
      INC R5     ; +1000
      ADD A, #6  ; +  24 (4*6)
BIN2BCD_L2:
    ADD A, R7   ;  4*(A + 3*R5 + 3*R5)= 4*A + 24*R5
    JC BIN2BCD_L1B
      SJMP BIN2BCD_L2B
BIN2BCD_L1B:
      INC R5     ; +1000
BIN2BCD_L2B:
    ;MOV B, #25
    DIV AB       ; A  25 (4*25=100)
    CJNE A, #10, BIN2BCD_L3  ; A<=25525=10
      INC R5     ; *1000
      CLR A
BIN2BCD_L3B:
    MOV R7, A    ; R7 --- *100  Bin/BCD  R7<=9
                 ; B  --- *4    Bin      B <=24
    MOV A, #10
    XCH A, B     ; A  --- *4    Bin      B <=24
    RL A         ; A*4
    RL A         ; A  --- *1    Bin      A <=4*24=96
    ORL A, R6    ; R6 --- *1    Bin/BCD  R6<=3
                 ; A  --- *1    Bin      A<=96+3=99
    ;MOV B, #10
    DIV AB
    SWAP A
    ORL A, B
    XCH A, R5    ; R5 --- *1    BCD    个位/十位
                 ; A  --- *1000 Bin    A<=65
    MOV B, #10
    DIV AB
    XCH A, R7    ; R7 --- *10000 bin/BCD 万位 R7<=6
                 ; A  --- *100  Bin/BCD  A<=9
                 ; B  --- *1000 Bin/BCD  B<=9
    SWAP A
    ORL A, B
    SWAP A
    MOV R6, A   ; R6  --- *100  BCD   百位/千位
    RET
BIN2BCD_L3:
    SJMP BIN2BCD_L3B
  END
ayb_ice 发表于 2007-4-3 13:26 | 显示全部楼层
随便说说
  网上大把的...
 楼主| dengm 发表于 2007-4-3 17:11 | 显示全部楼层
LS: 网上大把?请给一个 100 周期以下的。。
xwj 发表于 2007-4-3 17:22 | 显示全部楼层
好小子,竟然敢质疑邓喵的汇编水平!
ayb_ice 发表于 2007-4-4 13:32 | 显示全部楼层
随便说说
  我是随便说说,不必生气.
  我认为只有CPU速度不能满足要求时,你的这些才会有意义,现实情况是现在的CPU很快(我在用C8051F系列,分频使用),更何况合理的整体程序结构比这更重要,比如再快的CPU,你调用软件延时程序...
  当然你的程序确实不错,向LZ道歉.
yewuyi 发表于 2007-4-4 15:47 | 显示全部楼层
呵呵,老邓快要走火入魔了……
不会是上次白沙题目的延续把?
怎么长时间还在考虑这?呵呵,小心成了‘欧阳峰’……
 楼主| dengm 发表于 2007-4-9 22:17 | 显示全部楼层
还能减6个左右周期, 也就是 10%, 但要20多字节的代价.
ayb_ice 发表于 2007-4-10 07:51 | 显示全部楼层
‘欧阳峰’
 楼主| dengm 发表于 2007-4-10 10:57 | 显示全部楼层
【非典】16 bits to packed BCD, 51 ASM. 55周期/93字节(终结)
  TEST_NUM  EQU 65535
  ORG 000H
    CALL BIN2BCD
    SJMP $
BIN2BCD:
    ;                     R5: 个位/十位    |
    ;                     R6: 百位/千位    |
    ;                     R7: 万位         |
    ;PS: 55 CYs only.  93 bytes            |
    MOV A, R2
    ANL A, #00000011B
    MOV A, R3
    RRC A
    MOV B, A
    MOV A, R2
    RRC A
    MOV C, B.0
    RRC A
    XCH A, B
    RR A
    ANL A, #00111111B
    RL A
    ADD A, R5
                 ; A  --- *4
    JC BIN2BCD_L1
      SJMP BIN2BCD_L2
BIN2BCD_L1:
      INC R5     ; +1000
BIN2BCD_L2:
    JC BIN2BCD_L1B
      SJMP BIN2BCD_L2B
BIN2BCD_L1B:
      INC R5     ; +1000
BIN2BCD_L2B:
    ;MOV B, #25
      INC R5     ; *1000
      CLR A
BIN2BCD_L3B:
    MOV A, #10
    ;RL A         ; A*4
    ;RL A         ; A  --- *1    Bin      A <=4*24=96
    ;ORL A, R6    ; R6 --- *1    Bin/BCD  R6<=3
    ;             ; A  --- *1    Bin      A<=96+3=99
    ;DIV AB
    ;SWAP A
    ;ORL A, B
    ;XCH A, R5    ; R5 --- *1    BCD    个位/十位
    ;             ; A  --- *1000 Bin    A<=65
    ;MOV B, #10
     ADD A, #(BIN2BCD_DB - $ - 3)
     MOVC A, @A+PC
     ADD A, R6
     DA A
    DIV AB
    SWAP A
    ORL A, B
    SWAP A
    RET
BIN2BCD_L3:
    SJMP BIN2BCD_L3B
BIN2BCD_DB:
    DB 00H, 04H, 08H, 12H, 16H
    DB 20H, 24H, 28H, 32H, 36H
    DB 40H, 44H, 48H, 52H, 56H
    DB 60H, 64H, 68H, 72H, 76H
    DB 80H, 84H, 88H, 92H, 96H
  END
 楼主| dengm 发表于 2007-4-10 11:05 | 显示全部楼层
精益求精的艺术品,希望大家喜欢。
zuoyou 发表于 2007-4-10 13:54 | 显示全部楼层
re
精益求精,pf
teddeng 发表于 2007-4-10 14:17 | 显示全部楼层
完全赞同楼主的思想
资源永远是稀缺的,思想才显得如此光辉。
只是觉得用错了地方,51资源的稀缺性越来越不重要了,因此楼主光辉的思想只剩下欣赏和训练的价值。
为什么不换个领域发挥?大有作为!
airwill 发表于 2007-4-11 19:46 | 显示全部楼层
呵呵, 真正是炉火纯青, 佩服
谈的元 发表于 2007-4-11 20:41 | 显示全部楼层
先收藏起,顶
要是用pic写的就更好了
diannaoza 发表于 2007-4-20 12:14 | 显示全部楼层
非典中的经典!
学习了,谢谢!
