求助,我的程序RTCALARM报警中断为啥进不去
5520|4
 楼主| dmj2168 发表于 2013-3-30 11:31 | 显示全部楼层 |阅读模式
谢谢了,求高手指点,周一领导要要,感觉都设置了不知道哪里出的问题,
 楼主| dmj2168 发表于 2013-3-30 11:35 | 显示全部楼层
int main()
        #ifdef DEBUG
        debug();
        #endif
        u32 tmp=0;
        Configuration();
        deletef("cmd.dat");
        creatf("cmd.dat",0,0);
        //RTC_Configuration();
        RTC_ITConfig(RTC_IT_SEC, ENABLE);                                                        //使能中断
        RTC_WaitForLastTask();
        RTC_ITConfig(RTC_IT_ALR,ENABLE);
    tmp=RTC_GetCounter();
        RTC_SetAlarm(tmp + 60);        //60S 后RTC报警唤醒
        while(1)
           RCC_ClearFlag();
           if(count>4000)
               writef("cmd.dat",GPS,count);                                                   //写入SD卡SRAM的数据
                   GPIO_SetBits(GPIOB, GPIO_Pin_12);                            //给GPS供电打开
               Delay1(1500);
                   count=0;
           else
               Delay1(1500);
           USART_ITConfig(USART3,USART_IT_RXNE  , ENABLE);
           GPSdataformat();        //用串口收到GPS数据,并且写入 SRAM
           if (dingwei==0)
                   //PWR_EnterSTOPMode(PWR_Regulator_LowPower,PWR_STOPEntry_WFE) ;         //系统进入STOP模式
                   //Configuration();
 楼主| dmj2168 发表于 2013-3-30 11:36 | 显示全部楼层
我吧进入STOP模式关了,因为报警没好用,
 楼主| dmj2168 发表于 2013-3-30 11:39 | 显示全部楼层
void Configuration(void)
        RCC_Configuration();                                           //时钟初始化
        NVIC_Configuration();                                           //中断初始化
        GPIO_Configuration();                                           //I/O口初始化
        USART3_Configuration();                                           //串口3初始化
        power_on1();                                                           // SPI初始化
          SysTick_SetReload(9000);                                   //重装系统街拍
    SysTick_ITConfig(ENABLE);                                   //使能体统中断
        RTC_SetAlarm_EXTI() ;                                           //RTC闹钟报警 设置
    RTC_ITConfig(RTC_IT_ALR, ENABLE);
        RTC_Config() ;                                              //RTC设置
        Delay1(2000);
void RCC_Configuration(void)
        RCC_DeInit();
        RCC_HSEConfig(RCC_HSE_ON);
        HSEStartUpStatus = RCC_WaitForHSEStartUp();
        if(HSEStartUpStatus == SUCCESS)
            FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);           /* Enable Prefetch Buffer */
            FLASH_SetLatency(FLASH_Latency_2);                                                             /* Flash 2 wait state */
            RCC_HCLKConfig(RCC_SYSCLK_Div1);                                                               /* HCLK = SYSCLK */
            RCC_PCLK2Config(RCC_HCLK_Div1);                                                             /* PCLK2 = HCLK */
            RCC_PCLK1Config(RCC_HCLK_Div2);        /* PCLK1 = HCLK/2 */
            RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);                    /* PLLCLK = 8MHz * 9 = 72 MHz */
            RCC_PLLCmd(ENABLE);        /* Enable PLL */
            while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)                            /* Wait till PLL is ready */
            RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);                                                /* Select PLL as system clock source */
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE);
            while(RCC_GetSYSCLKSource() != 0x08)                                    /* Wait till PLL is used as system clock source */
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
void NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
void RTC_SetAlarm_EXTI(void)
    EXTI_InitTypeDef EXTI_InitStructure;
    EXTI_ClearITPendingBit(EXTI_Line17);
    EXTI_InitStructure.EXTI_Line = EXTI_Line17;
    EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
    EXTI_Init(&EXTI_InitStructure);
    RTC_NVIC_Config();
void RTC_NVIC_Config(void)
    NVIC_InitStructure.NVIC_IRQChannel = RTCAlarm_IRQChannel;
void RTC_Config(void)
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
        //后备域解锁
     PWR_BackupAccessCmd(ENABLE);
    //我们在BKP的后备寄存器1中,存了一个特殊字符0xA5A5
    //第一次上电或后备电源掉电后,该寄存器数据丢失,
    //表明RTC数据丢失,需要重新配置
    if (BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5)
        //重新配置RTC
        //配置完成后,向后备寄存器中写特殊字符0xA5A5
        BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
                settime=1;
    else
        //若后备寄存器没有掉电,则无需重新配置RTC
        //这里我们可以利用RCC_GetFlagStatus()函数查看本次复位类型
        if (RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET)
            //这是上电复位
        else if (RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET)
            //这是外部RST管脚复位
        //清除RCC中复位标志
        RCC_ClearFlag();
        //虽然RTC模块不需要重新配置,且掉电后依靠后备电池依然运行
        //但是每次上电后,还是要使能RTCCLK???????
        //RCC_RTCCLKCmd(ENABLE);
        //等待RTC时钟与APB1时钟同步
        //RTC_WaitForSynchro();
        //使能秒中断
        //RTC_ITConfig(RTC_IT_SEC, ENABLE);
        //等待操作完成
        //        RTC_ITConfig(RTC_IT_SEC, ENABLE);
    #ifdef RTCClockOutput_Enable
    /* Enable PWR and BKP clocks */
    /* Disable the Tamper Pin */
    BKP_TamperPinCmd(DISABLE);
    /* Enable RTC Clock Output on Tamper Pin */
    BKP_RTCOutputConfig(BKP_RTCOutputSource_CalibClock);
   #endif
    return;
 楼主| dmj2168 发表于 2013-3-30 11:40 | 显示全部楼层
void RTCAlarm_IRQHandler(void)
  if(RTC_GetITStatus(RTC_IT_ALR) != RESET)
    /* Check if the Wake-Up flag is set */
    if(PWR_GetFlagStatus(PWR_FLAG_WU) != RESET)
      /* Clear Wake Up flag */
      PWR_ClearFlag(PWR_FLAG_WU);
    /* Clear the RTC Second interrupt */
    RTC_ClearITPendingBit(RTC_IT_ALR);
    /* Enable time update */
    TimeDisplay = 1;
    /* Wait until last write operation on RTC registers has finished */
    /* Reset RTC Counter when Time is 23:59:59 */
    if(RTC_GetCounter() == 0x00015180)
      RTC_SetCounter(0x0);
