quartus 编写的硬件乘法器有错误 求解。
2703|4
 楼主| 骑狼的诗人 发表于 2013-4-6 23:49 | 显示全部楼层 |阅读模式
语句:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
ENTITY 16jishu IS
GENERIC( WIDTHd: INTEGER:=16;
         WIDTHb:INTEGER:=16 );
port( clk,clrn,st : in std_logic;
      d      : IN std_logic_vector( WIDTHd-1 DOWNTO 0);
      b      : IN std_logic_vector ( WIDTHb-1 DOWNTO 0);
      A      : out std_logic_vector(WIDTHd+WIDTHb-1 DOWNTO 0);
      z       :  out std_logic
end 16jishu;
architecture one of 16jishu is
      TYPE ss IS(s0,s1,s2,s3 );
      signal state: ss:=s0;
      signal n : INTEGER RANGE WIDTHb DOWNTO 0;
      signal q : std_logic_vector(WIDTHd+WIDTHb downto 0);
      signal t : std_logic_vector(WIDTHb-1 downto 0);
begin
process (clk, clrn)
begin
    if clrn = '0' then state<=s0;
     elsif (clk'event and clk = '1') then
       case state is
             when s0=>if st='1'then
               state<=s1;end if;
               when s1=>state<=s2;
               when s2=>if n=0 then state <=s3;
               else state <=s1;end if ;
               when s3=>state<=s0;
               when others =>state<=s0;
               end case;
               end if;
          end process;
       process (clk )
      VARIABLE cont :std_logic_vector(WIDTHd downto 0);
      begin
      if(clk'event and clk = '1') then
CASE state IS
      when s0 =>n<= WIDTHb;t<=b;z<='0';
      q<=(OTHERS =>'0');
      cont (WIDTHd downto 0):='0'&d(WIDTHd-1 DOWNTO 0);
      when s1=> n<=n-1;if t(0)='1' then
     q(WIDTHd+WIDTHb downto WIDTHb)<=q(WIDTHd + WIDTHb downto WIDTHb)
                                         +cont (WIDTHd downto 0);
                                         end if;
        when s2 =>t(WIDTHb-2 downto 0)<=t(WIDTHb-1 downto 1);
        t(WIDTHb-1)<='0';
       q(WIDTHd+WIDTHb -1 downto 0)<=q(WIDTHd+WIDTHb downto 1) ;
       q(WIDTHd+WIDTHb )<='0';
     when s3=> z<='1';
     q(WIDTHd+WIDTHb downto  1)<=q(WIDTHd+WIDTHb -1 downto 0);
     A<=q(WIDTHd+WIDTHb -1 downto 0);
     END CASE ;
     END IF;
     end process;
     END one;
Error (10500): VHDL syntax error at 16jishu.vhd(4) near text "16";  expecting an identifier
ifpga 发表于 2013-4-7 14:06 | 显示全部楼层
怎么发这儿了
16后应该是,号吧
hawksabre 发表于 2013-4-7 18:09 | 显示全部楼层
这个比较头疼   呵呵   偷个懒  呼叫版主出来搞定他   呵呵  顶起来
sahh 发表于 2013-4-7 22:14 | 显示全部楼层
16jishu 这名字非法,不能数字开头。
 楼主| 骑狼的诗人 发表于 2013-4-8 09:14 | 显示全部楼层
谢啦。大神,我已经解决了。。
