用三星单片机S3F9454做的一个遥控开关的源代码
6184|10
 楼主| 比尔熊 发表于 2008-11-28 13:30 | 显示全部楼层 |阅读模式
#include <ioS3C9454.h>
#define uchar unsigned char
#define uint  unsigned int
#define NOP asm("NOP")
#define DI  asm("DI")
#define EI  asm("EI")
#define SET_LED (P0 |= 0x01)
#define CLR_LED (P0 &= ~0x01)
#define COM_LED (P0 ^= 0x01)
#define SET_SCR (P0 |= 0x04)
#define CLR_SCR (P0 &= ~0x04)
#define COM_SCR (P0 ^= 0x04)
#define GET_SCR (P0 & 0x04)
#define GET_IR  (P0 & 0x02)
#define SET_BUZZER (P2 |= 0x01)
#define COM_BUZZER (P2 ^= 0x01)
#define IR_USER_CODE 0x00
#define IR_POWER     0x7C
#define IR_Vol_Add   0x16
#define IR_Vol_Dec   0x02
#define IR_RIGHT     0x0F
#define IR_LEFT      0x0E
#define IR_UP        0x5B
#define IR_DOWN      0x53
__root const uchar smartOption[4] @ 0x003C ={0x00,0x00,0xE4,0x00};
uchar remBuffer[4];
uchar irFlag;
uint timeCount;
void InitSfr(void)
 BTCON = 0x02;
 CLKCON = 0x18;
 P0CONH = 0xAA;
 P0CONL = 0xA6;
 P0PND = 0x00;
 P1CON = 0x0A;
 P2CONH = 0x4A;
 P2CONL = 0xAA;
 P0 = 0x00;
 P2 = 0x00;
 SET_SCR;
 SET_LED;
 SET_BUZZER;
 irFlag = 0;
 timeCount = 0;
void DelayMs(uchar ms)
    uchar i,j;
    for(i = 0; i < ms; i++)
        for(j = 0; j < 250; j++)
        NOP;
void SendDat(uchar byte)
  uchar i;
  for(i = 0; i < 8; i++)
    CLR_LED;
    if(byte & 0x80)
    DelayMs(1);
    else
    DelayMs(3);
    SET_LED;
    byte <<= 1;
    DelayMs(1);
void BuzzerOut(uint time)
  uint j;
  uchar i;
  for(j = 0; j < time; j++)
    BTCON = 0x02;
    for(i = 0; i < 16; i++)
      NOP;
    COM_BUZZER;
void main()
  DI;
  InitSfr();
  DelayMs(100);
  T0DATA = 250;//定时器初始值
  T0CON = 0xC8;//打开定时器 1/8之一分频
  P0PND = 0x08;
  BuzzerOut(3000);
  CLR_LED;
  EI;
  while(1)
    BTCON = 0x02;
    P0CONL = 0xA6;
    SET_BUZZER;
    if(irFlag)
      if(remBuffer[0] == IR_USER_CODE)
        if(remBuffer[2] == IR_POWER)
          COM_SCR;
          if(GET_SCR == 0)
            BuzzerOut(1000);
            SET_LED;
          else
            BuzzerOut(2000);
            CLR_LED;
      //SendDat(remBuffer[2]);
      irFlag = 0;
      P0PND = 0x08;
    if(GET_SCR)
      timeCount++;
      if(timeCount >= 55000)
        timeCount = 0;
        SET_LED;
        DelayMs(50);
        CLR_LED;
#pragma vector = 0x00
__interrupt void Interrupts(void)
  uchar count;
  uchar i,j;
  if(P0PND & 0x04)
    P0PND = 0x00;
    for(count = 0;count < 160; count++)
      T0CON = 0xC8;
      do
      NOP;
      while(T0CNT < 150);
      if(GET_IR)
        P0PND = 0x08;
        return;
    while(GET_IR == 0);
    for(count = 0;count < 80;count++)
      T0CON = 0xC8;
      do
      NOP;
      while(T0CNT < 150);
      if(GET_IR == 0)
        P0PND = 0x08;
        return;
    while(GET_IR);
    for(j=0;j<4;j++)
      for(i=0;i<8;i++)
        while(GET_IR == 0);
        for(count = 0; count < 18; count++)
          T0CON = 0xC8;
          do
          NOP;
          while(T0CNT < 150);
        remBuffer[j] >>= 1;
        if(GET_IR)
          remBuffer[j] |= 0x80;
          for(count = 0; count < 32; count++)
            T0CON = 0xC8;
            do
            NOP;
            while(T0CNT < 150);
    irFlag = 1;
测试100%通过,请大家放心试用!
程序匠人 发表于 2008-11-28 14:08 | 显示全部楼层
送裤子一条,如果有原理图,再送一条
古道热肠 发表于 2008-11-28 14:29 | 显示全部楼层
哈哈,这个网名有意思
Bear熊(贝尔熊),俺家小子看的<右脑开发宝典>中的主角.
keyanfeng 发表于 2008-11-28 17:06 | 显示全部楼层
关于RF的编码
开始的时候我是用中断产生定时间隔来做的.
也是用9454.
这种方法不是很准确,
330us的高电平,有时候只有300us,
现在换成,发射编码时,先关中断,
再调用延时函数,处理产生时序.
楼主的DelayMs(1) 好像延时不是1ms,
你的晶振是多少?
    uchar i,j;
        NOP;
IAR的汇编如下,
代码中级优化.
DelayMs:
    0111    B0CE        CLR      R14
    0113    8B0B        JR       T, 0x0120
        NOP;
    0115    FF          NOP
    0116    DE          INC      R13
    0117    56DFFC      AND      0xDF, #0xFC
    011A    A6CDFA      CP       R13, #0xFA
    011D    7BF6        JR       C, 0x0115
    011F    EE          INC      R14
    0120    A2EF        CP       R14, R15
    0122    FB04        JR       NC, 0x0128
    0124    B0CD        CLR      R13
    0126    8BEF        JR       T, 0x0117
    0128    AF          RET
    0129    FF          NOP
?C_EXIT:
exit:
    012A    FF          NOP
看我的RF 编码.
// RF send data start
// 12ms idle time,333us start bit,(333+666)us*16 data bit,
//       __    __
//    __|  |__|  |__
        di();
        RF_out0();
        i = 12;                            // RF idle  12ms
        while(i>0)
            delay_330us();
            delay_330us();
            delay_330us();
            i--;
        RF_out1();                      // RF start bit 330us
        delay_330us();                    // RF_out1
        do
            j = RF_code[RF_byte];
            for(i=0; i<8; i++)
                if(j & 0x80)
                    RF_out0();
                    delay_330us();                // 0
                    RF_out1();
                    delay_330us();              // 1
                    delay_330us();              // 1
                else
                    RF_out0();
                    delay_330us();                // 0
                    delay_330us();              // 0
                    RF_out1();
                    delay_330us();              // 1
                j = j << 1;
            RF_byte++;
        }while(RF_byte < 2);
        RF_out0();
        RF_flag.bit.BIT_RF_EN = 0;
        RF_frame_num++;
        ei();
延时函数
void delay_330us(void)
    uchar i;
//    i = 64;
    i = 93;
    while(i > 0)
        i--;
IAR的汇编如下,
 i = 93;
delay_330us:
    0B74    FC5D        LD       R15, #0x5D
    0B76    8B02        JR       T, 0x0B7A
  i--;
    0B78    00CF        DEC      R15
 while(i > 0)
    0B7A    42FF        OR       R15, R15
    0B7C    EBFA        JR       NZ, 0x0B78
    0B7E    AF          RET
    0B7F    FF          NOP
4M晶振,延时为:
1+1.5+ 93*3.5 -1 + 2 + 3.5= 332.5us
awey 发表于 2008-11-28 18:08 | 显示全部楼层
这款单片机价格好象很便宜,性价比很高
 楼主| 比尔熊 发表于 2008-11-29 16:29 | 显示全部楼层
不是很高,而是超高
不是很高,而是超高
 楼主| 比尔熊 发表于 2008-12-1 10:58 | 显示全部楼层
没人顶的贴就不是好贴
keyanfeng 发表于 2008-12-1 19:49 | 显示全部楼层
仿真器贵
在这间公司呆了一年,
OPENice还只能够借别人的来用。
discussant 发表于 2008-12-10 08:30 | 显示全部楼层
可以不用仿真器,用烧写器即可
电磁炉上用得很多。
超导体88 发表于 2008-12-12 09:26 | 显示全部楼层
大虾好
小弟用9454开发了一个项目,需要用到9454的编程时序资料,不知您能否赐教
j1ason 发表于 2013-12-13 07:10 来自手机 | 显示全部楼层
Mark!!!!!
