求大神帮我看下这个例程
2049|1
 楼主| singe0915 发表于 2013-4-9 14:07 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<math.h>
#include<absacc.h>
#define uchar unsigned char
#define uint unsigned int
#define COUNT 10
uchar buffer[COUNT];
uchar point;
void UART_init();
void COM_send(void);
uchar CLU_checkdata(void);
unsigned char code table[] = {0x3f,0x06,0x5b,0x4f,
                              0x66,0x6d,0x7d,0x07,
                              0x7f,0x6f,0x77,0x7c,
                              0x39,0x5e,0x79,0x71,0X40,0X00};
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^5;
sbit lcdrs=P3^7;
uchar tab_key[50];
uchar code tab[]="0123456789abcdef";
uchar n=0,temp,key;
void UART_init()
        SCON=0x58;
        TMOD=0x21;
        TH1 =0xfd;
        TR1 =1;
        ET1 =0;
        ES =1 ;
        EA =1;
com_interrupt(void) interrupt 4 using  3
        uchar RECEIVR_buffer;
        if(RI)
                        RI=0;
                        RECEIVR_buffer=SBUF;
                        if(point==0)
                                        if(RECEIVR_buffer=='S')
                                        point++;
                                        else
                                        point=0;
                                else if(point>0&&point<10)
                                buffer[point++]=RECEIVR_buffer;
                                else point =0;
                if(TI)
                        TI=0;
void COM_sent(void)
        for(point=0;point<=10,TI=1;point++)
                SBUF=buffer[point];
                TI=0 ;
        uchar checkdata=0;
        for(point=0;point<9,TI=1;point++ )
                checkdata=checkdata|buffer[point];
        return(checkdata);
void lcd_disp();
void lcd_init();
void display(unsigned char);
void write_com(uchar);
void write_data(uchar);
void delay(unit);
void key_scan();
void key_manage1();
void key_manage2();
void key_manage3();
void key_manage4();
void key_manage5();
void key_manage6();
void key_manage7();
void key_manage8();
void key_manage9();
void key_manage10();
void key_manage11();
void key_manage12();
void key_manage13();
void key_manage14();
void key_manage15();
void key_manage16();
void main()
{                 uchar checkdata;
         lcd_init();
         write_com(1);
         while(1)
                         key_scan();
                         lcd_disp();
                                                 if(n>15)
                                                 write_com(0x80+0x40);
        P3=0x10;
        delay(10);
        P3=0xe18;
        delay(10);
        P3=0x04;
        delay(10);
        P3=0x08;
        delay(10);
        P3=0x0c;
        delay(10);
        P3=0x1c;
        delay(10);
        P3=0x14;
        delay(10);
                                                do
                         UART_init();
                        if(point==10)
                        checkdata=CLU_checkdata;
                        if(checkdata==buffer[9])
                        COM_send();
                        point=0;
                 while(1);
void lcd_disp()
         uchar a,i=0;
         write_com(0x80);
        i=0;
        while(i<n)
            a=tab_key[i];
            write_data(tab[a]);
            i++;
            if(i==15)
void lcd_init()
         dula=0;
         wela=0;
         lcden=0;
         write_com(0x38);
         write_com(0x0c);
        write_com(0x06);
                write_com(0x80);
       // write_com(0x80+0x40);
void write_com(uchar com)
         lcdrs=0;
         P2=com;
         delay(3);
         lcden=1;
         delay(5);
         lcden=0;
void write_data(uchar dat)
         lcdrs=1;
         P2=dat;
         delay(3);
         lcden=1;
         delay(5);
         lcden=0;
void key_scan()
         P1=0xfe;
         temp=P1;
         temp=temp&0xf0;
         if(temp!=0xf0)
                         delay(100);
                         if(temp!=0xf0)
                                         temp=P1;
                                         switch(temp)
                                                         case 0xee:   key_manage1();display(0);   break;
                                                         case 0xde:   key_manage2();display(1);   break;
                                                         case 0xbe:   key_manage3();display(2);   break;
                                                         case 0x7e:   key_manage4();display(3);   break;
                                         while(temp!=0xf0)
                                                         temp=P1;
                                                         temp=temp&0xf0;
         P1=0xfd;
                 temp=P1;
                 temp=temp&0xf0;
                 if(temp!=0xf0)
                                 delay(100);
                                 if(temp!=0xf0)
                                                 temp=P1;
                                                 switch(temp)
        case 0xed:   key_manage5();display(4);   break;
        case 0xdd:   key_manage6();display(5);   break;
        case 0xbd:   key_manage7();display(6);   break;
        case 0x7d:   key_manage8();display(7);   break;
                                                 while(temp!=0xf0)
        temp=P1;
        temp=temp&0xf0;
         P1=0xfb;
                 temp=P1;
                 temp=temp&0xf0;
                 if(temp!=0xf0)
                                 delay(100);
                                 if(temp!=0xf0)
                                                 temp=P1;
                                                 switch(temp)
        case 0xeb:   key_manage9();display(8);   break;
        case 0xdb:   key_manage10();display(9);   break;
        case 0xbb:   key_manage11();display(10);   break;
        case 0x7b:   key_manage12();display(11);   break;
                                                 while(temp!=0xf0)
        temp=P1;
        temp=temp&0xf0;
         P1=0xf7;
         temp=P1;
         temp=temp&0xf0;
         if(temp!=0xf0)
                         delay(100);
                         if(temp!=0xf0)
                                         temp=P1;
                                         switch(temp)
                                                         case 0xe7:   key_manage13();display(12);   break;
                                                         case 0xd7:   key_manage14();display(13);   break;
                                                         case 0xb7:   key_manage15();display(14);   break;
                                                         case 0x77:   key_manage16();display(15);   break;
                                         while(temp!=0xf0)
                                                         temp=P1;
                                                         temp=temp&0xf0;
void display(unsigned char S)
  P0 = table[S];
delay(200);
P2 = 0x7f;
void delay(uint k)
         uint i,j;
         for(i=k;i>0;i--)
         for(j=50;j>0;j--);
void key_manage1()
         tab_key[n]=0;
         n++;
void key_manage2()
         tab_key[n]=1;
         n++;
void key_manage3()
         tab_key[n]=2;
         n++;
void key_manage4()
         tab_key[n]=3;
         n++;
void key_manage5()
         tab_key[n]=4;
         n++;
void key_manage6()
         tab_key[n]=5;
         n++;
void key_manage7()
         tab_key[n]=6;
         n++;
void key_manage8()
         tab_key[n]=7;
         n++;
void key_manage9()
         tab_key[n]=8;
         n++;
void key_manage10()
         tab_key[n]=9;
         n++;
void key_manage11()
         tab_key[n]=10;
         n++;
void key_manage12()
         tab_key[n]=11;
         n++;
void key_manage13()
         tab_key[n]=12;
         n++;
void key_manage14()
         tab_key[n]=13;
         n++;
void key_manage15()
         tab_key[n]=14;
         n++;
void key_manage16()
         tab_key[n]=15;
         n++;
 楼主| singe0915 发表于 2013-4-9 14:09 | 显示全部楼层
这个例程是 44控制数码管 还有1602 还有一彩灯闪烁
但是仿真只有1602的显示 还有数码管的显示  串口失效
用的是11.0592晶振 9600波特率
