[AVR单片机] VS1003管脚配置是否出问题了,WINAVR开发软件,大神进来看看啊
3223|4
 楼主| 910200850 发表于 2013-4-18 12:06 | 显示全部楼层 |阅读模式
* MP3模块测试程序
* 用途:MP3模块测试程序
*       vs1003 的硬件测试程序,主控芯片为STC12LE5A60S2
*       其他的微处理器(带SPI接口的)只需稍加修改即可适用
*       对于不带硬SPI接口的微处理器可以用IO进行SPI的时序模拟
* 作者                                        日期                                备注
* Huafeng Lin                        20010/09/10                        新增
* Huafeng Lin                        20010/09/10                        修改
//针对SD卡读写板调整引脚
#include <avr/io.h>
#include "vs1003h.h"
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#define bool bit
#define true 1
#define flase 0
#define uint8 unsigned char
//#define PORT PORTA
#define  MP3_XRESET             0
#define MP3_XCS                                 1
#define MP3_XDCS                                 2
#define MP3_DREQ                             3
#define c_SPI_SI                                  4
#define c_SPI_SO                                  5
#define CLK                                     6
#define MP3_DREQset                (PORTA|=(1<<(MP3_DREQ)))
#define MP3_DREQclr      (PORTA&=(~(1<<(MP3_DREQ))))
#define Mp3PutInReset  (PORTA&=(~(1<<(MP3_XRESET ))))
#define Mp3ReleaseFromReset  (PORTA|=(1<<(MP3_XRESET)))
#define Mp3SelectControl  (PORTA&=(~(1<<(MP3_XCS))))
#define Mp3DeselectControl  (PORTA|=(1<<(MP3_XCS)))
#define Mp3SelectData        (PORTA&=(~(1<<(MP3_XDCS))))
#define Mp3DeselectData        (PORTA|=(1<<(MP3_XDCS)))
#define SI_High           (PORTA|=(1<<(c_SPI_SI)))
#define SI_Low           (PORTA&=(~(1<<(c_SPI_SI))))
#define SO_High           (PORTA|=(1<<(c_SPI_SO)))
#define SO_Low           (PORTA&=(~(1<<(c_SPI_SO))))
#define CLK_High     (PORTA|=(1<<(CLK)))
#define CLK_Low           (PORTA&=(~(1<<(CLK))))
void wait(unsigned char ucDelayCount)
        uchar ucTempCount;
        uchar uci;
        for(ucTempCount=0; ucTempCount<ucDelayCount; ucTempCount++)
//                uci = 200;        //Err
//                uci = 250;        //OK
                uci = 230;
                while(uci--)
/*  函数名称 :  SPIPutChar                                */
/*  函数功能 : 通过SPI发送一个字节的数据                 */
/*  参数     :  待发送的字节数据                          */
/*  返回值   :  无                                        */
void  SPIPutChar(unsigned char ucSendData)
        //S0SPDR = c;
        //while((S0SPSR & 0x80) == 0);         //等待SPI将数据发送完毕
        // SPDR = ucSendData;
        //while (!(SPSR & 0x80));
             uchar ucCount;
        uchar ucMaskCode;
        ucMaskCode = 0x80;
        for(ucCount=0; ucCount<8; ucCount++)
                CLK_Low;
                if(ucMaskCode & ucSendData)
                        SI_High;
                else
                        SI_Low;
                CLK_High;
                ucMaskCode >>= 1;
/*  函数名称 :  Mp3WriteRegister                             */
/*  函数功能 : 写vs1003寄存器                               */
/*  参数     :  寄存器地址,待写数据的高8位,待写数据的低8位 */
/*  返回值   :  无                                           */
void Mp3WriteRegister(unsigned char addressbyte, unsigned char highbyte, unsigned char lowbyte)
        //Mp3DeselectData();
        MP3_DREQset;
        while (MP3_DREQ == 0);
        Mp3SelectControl;//XCS = 0
        SPIPutChar(0x02); //发送写寄存器命令
        SPIPutChar(addressbyte);      //发送寄存器的地址
        SPIPutChar(highbyte);         //发送待写数据的高8位
        SPIPutChar(lowbyte);          //发送待写数据的低8位
        Mp3DeselectControl; //XCS=1
/*  函数名称 :  Mp3Reset                                  */
/*  函数功能 : vs1003硬件复位                            */
/*  参数     :  无                                        */
/*  返回值   :  无                                        */
void Mp3Reset(void)
        Mp3PutInReset;//xReset = 0   复位vs1003
        wait(200);//延时100ms
        SPIPutChar(0xff);//发送一个字节的无效数据,启动SPI传输
        Mp3DeselectControl;   //xCS = 1
        Mp3DeselectData;     //xDCS = 1
        Mp3ReleaseFromReset; //xRESET = 1
        wait(200);
        Mp3WriteRegister (0x00, 0x08, 0x04); //软件复位
        wait(200);            //延时100ms
        MP3_DREQset;
        Mp3WriteRegister(0x03, 0x98, 0x00);//设置vs1003的时钟,3倍频
        wait(20);            //延时100ms
        Mp3WriteRegister (0x05, 0xBB, 0x81); //采样率48k,立体声
        wait(20);            //延时100ms
        Mp3WriteRegister(0x02, 0x00, 0x55);//设置重音
        wait(20);            //延时100ms
        Mp3SetVolume(50,50);//设置音量
        wait(5); //延时1ms
                  //延时100ms
        //向vs1003发送4个字节无效数据,用以启动SPI发送
        SPIPutChar(0);
        SPIPutChar(0);
        SPIPutChar(0);
        SPIPutChar(0);
void VS1003B_WriteCMD(unsigned char addr, unsigned int dat)
        VS1003B_XDCS_H();
        VS1003B_XCS_L();
        VS1003B_WriteByte(0x02);
        //delay_Nus(20);
        VS1003B_WriteByte(addr);
        VS1003B_WriteByte(dat>>8);
        VS1003B_WriteByte(dat);
        //delay_Nus(200);
        VS1003B_XCS_H();
        Mp3WriteRegister(addr,dat>>8,dat);
  void VS1003B_SoftReset()
        VS1003B_WriteCMD(0x00,0x0804);//写复位
//        VS1003B_Delay(0xffff);//延时,至少1.35ms
        wait(2);
  int CheckVS1003B_DRQ(void)
        int bResult;
        bResult =MP3_DREQ;
        return(bResult);
/*  函数名称 :  VsSineTest                                 */
/*  函数功能 : vs1003正弦测试,将该函数放在while循环中,  */
/*              如果能持续听到一高一低的声音,证明测试通过 */
/*  参数     :  无                                         */
/*  返回值   :  无                                         */
void VsSineTest(void)
        Mp3PutInReset;  //xReset = 0   复位vs1003
        Mp3DeselectData;     //XDCS=1
        Mp3ReleaseFromReset; //xReset = 1
        wait(200);
        Mp3WriteRegister(0x00,0x08,0x20);//进入vs1003的测试模式
        while (MP3_DREQ == 0);     //等待DREQ为高
        Mp3SelectData;       //xDCS = 1,选择vs1003的数据接口
        //向vs1003发送正弦测试命令:0x53 0xef 0x6e n 0x00 0x00 0x00 0x00
        //其中n = 0x24, 设定vs1003所产生的正弦波的频率值,具体计算方法见vs1003的datasheet
           SPIPutChar(0x53);
        SPIPutChar(0xef);
        SPIPutChar(0x6e);
        SPIPutChar(0x24);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
//        wait(500);
        wait(250);
        wait(250);
        Mp3DeselectData;//程序执行到这里后应该能从耳机听到一个单一频率的声音
        //退出正弦测试
        Mp3SelectData;
        SPIPutChar(0x45);
        SPIPutChar(0x78);
        SPIPutChar(0x69);
        SPIPutChar(0x74);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
//        wait(500);
        wait(250);
        wait(250);
        Mp3DeselectData;
        //再次进入正弦测试并设置n值为0x44,即将正弦波的频率设置为另外的值
        Mp3SelectData;
        SPIPutChar(0x53);
        SPIPutChar(0xef);
        SPIPutChar(0x6e);
        SPIPutChar(0x44);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
//        wait(500);
        wait(250);
        wait(250);
        Mp3DeselectData;
        //退出正弦测试
        Mp3SelectData;
        SPIPutChar(0x45);
        SPIPutChar(0x78);
        SPIPutChar(0x69);
        SPIPutChar(0x74);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
        SPIPutChar(0x00);
//        wait(500);
        wait(250);
        wait(250);
        Mp3DeselectData;
void open_mp3()
   int i=0;
   Mp3Reset();
   MP3_XDCS=0;
   while(1)
   MP3_DREQ=1;
   while(!MP3_DREQ);
   SPIPutChar(MusicData[i]);
   i++;
qin552011373 发表于 2013-4-18 23:03 | 显示全部楼层
 楼主| 910200850 发表于 2013-4-18 23:48 | 显示全部楼层
WINAVR里写void  SPIPutChar(unsigned char ucSendData)函数是不是有问题
qin552011373 发表于 2013-4-20 09:32 | 显示全部楼层
应该没有的  怎么?
huangshuai0795 发表于 2013-4-28 15:54 | 显示全部楼层
VS1003技术问题找我, 我这边就是解决VS1003问题的    2355355260  :call:13751145915
