[AVR单片机] Linux下使用smartCOM调试串口
5727|16
 楼主| nextkey 发表于 2013-4-20 02:30 | 显示全部楼层 |阅读模式
在Windows下的串口调试一直使用sscom,在Linux下只找到一个cutecom,用了几次,很不喜欢,就着手开发了一款自己的串口调试工具,smartCOM。
smartCOM介绍:http://gnssinfo.com/2012/11/21/wiki-smartcom/
smartCOM is a graphical serial device terminal, it’s an alternative to minicom. It is aimed mainly at hardware developers who need a gui test tools to talk to their custom hardware. The GUI is written using the wxWidgets library, and using the tinyxml to save or load config.
2013/1/12 Update: ver 2.4
1) Add RTCM v2.3/3.1 decoder, more info;
2) Support baudrate 230400/460800;
3) delete protocol ymodem, becase ymodem = xmodem-1k;
2012/12/26 Update: ver 2.2
1) Add Save Button;
2) Add auto save file when exit;
2012/12/17 Update:
Add GB2312 support;
2012/12/10 Update:
Fixed the rx data display in string mode;
FromUTF8->From8BitData, only support ISO-8859-1 encoding;
Add dynamic dll support, and the extSerialSample.dll is a demo; smartcom增加自定义插件支持
add side tree list;
下载链接: please open url: sourceforge.net;
    smartCOM-linux-v2.4.tar.gz
    smartCOM-windows-v2.4.rar
同步更新上传地址: http://sourceforge.net/projects/smartcoms/
2012/12/05 Update:
1) Up File transfer UI;
2) Add Cortex M3 IAP Protocol(for a project);
3) Add input support in output window;
4) Add File Protocol Selection remember;
5) Fix “Cancel” function bug in ver1.3;
2012/12/03 Update:
1) Add file transfer ui;
2) Add simple file transfer: protocol(NONE);
3) Add XModem protocol: TX Modem(1K), RX Modem(1K)
2012/11/22 Update:
1) Add Hex display for the received data;
2) Add Rx/Tx Statistic;
2012/11/21 目前已支持如下功能(Support Feature List):
1) 自动枚举串口(Auto List Serial);
2) 支持侧边栏命令框(Support Side Command Bar);
3) 支持回车、换行符勾选(Support Enter/NewLine Code);
4) 支持定时发送(You can Ontimer Send one command);
5) 支持读取文本显示(Display the ASCII that read from serial);
6) 支持多窗口,可以创建多个串口界面(You Can Create Multi-Serial Ctrl UI);
7) 支持当前窗口保存(You can save the Commands to file, and load back);
8) 支持读取文件记录(You can save the received data to file);
9) 提供WINDOWS、LINUX版本;
与cutecom相比,增加了自动枚举串口功能,支持USB串口;
BUG: 在LINUX下,暂未强制锁定串口(该问题CuteCOM同样存在);
ToDO:
1) 增加HEX显示;
2) 增加xmodem的文件发送协议支持;
3) 增加读写统计;
注: LINUX下串口使用需要管理员权限,用管理员登录打开,或是修改权限,如下:
查看串口设备属性后如下:
[root@zynq7k ~]# cd /dev
[root@zynq7k dev]# ls -l ttyS*
crw-rw—-. 1 root dialout 4, 64 Nov 9 08:30 ttyS0
crw-rw—-. 1 root dialout 4, 65 Nov 8 09:43 ttyS1
crw-rw—-. 1 root dialout 4, 66 Nov 8 09:43 ttyS2
crw-rw—-. 1 root dialout 4, 67 Nov 8 09:43 ttyS3
普通用户无读写权限,对其修改,操作如下:
[root@zynq7k dev]# chmod 666 ttyS*
crw-rw-rw-. 1 root dialout 4, 64 Nov 9 08:30 ttyS0
crw-rw-rw-. 1 root dialout 4, 65 Nov 8 09:43 ttyS1
crw-rw-rw-. 1 root dialout 4, 66 Nov 8 09:43 ttyS2
crw-rw-rw-. 1 root dialout 4, 67 Nov 8 09:43 ttyS3
[root@zynq7k dev]#
ScreenShot:
 楼主| nextkey 发表于 2013-4-20 02:33 | 显示全部楼层
 楼主| nextkey 发表于 2013-4-20 02:34 | 显示全部楼层
qin552011373 发表于 2013-4-20 09:19 | 显示全部楼层
谢谢分享
huangxz 发表于 2013-4-21 07:51 | 显示全部楼层
这个做的也不错,谢谢楼主,最好RTS,DTR有可以控制的,
huangxz 发表于 2013-4-21 07:56 | 显示全部楼层
不过如果作为终端软件使用,我还是喜欢securecrt,小巧,功能强大的(支持python脚本等)让我还找不到另外一个跟他相比
 楼主| nextkey 发表于 2013-4-23 23:33 | 显示全部楼层
不过如果作为终端软件使用,我还是喜欢securecrt,小巧,功能强大的(支持python脚本等)让我还找不到另外一个 ...
securecrt是收费的吧? 另没有linux版。
hardfire 发表于 2013-4-24 09:34 | 显示全部楼层
securecrt 不收费啊。
支持下。
 楼主| nextkey 发表于 2013-4-25 12:25 | 显示全部楼层
securecrt 不收费啊。
支持下。
只能说明你用的盗版,其他啥也说明不了,嘿嘿;
看官网介绍:http://www.vandyke.com/products/securecrt/index.html
只有30天免费试用期;
另刚发现也有LINUX版、MAC版。
 楼主| nextkey 发表于 2013-4-25 12:30 | 显示全部楼层
看官网介绍:http://www.vandyke.com/products/securecrt ...
secureCRT及相关组件的价格,还是蛮高的。
http://www.vandyke.com/purchase/direct/index.html
hardfire 发表于 2013-4-25 13:53 | 显示全部楼层
evilangell 发表于 2013-4-27 12:52 | 显示全部楼层
不错,挺漂亮的,能提供代码下载吗?
dong_abc 发表于 2013-5-9 05:52 | 显示全部楼层
一直用minicom
开发者_test 发表于 2013-5-9 07:37 | 显示全部楼层
非常好,不过又多了一份工作量,实际上,从现有的开源基础上做写贡献多好
dirtwillfly 发表于 2013-5-9 09:53 | 显示全部楼层
好工具啊,貌似很强大
baigame 发表于 2014-4-7 10:35 | 显示全部楼层
好工具啊,貌似很强大
