stm32移植uCOSII 操作系统
2639|1
 楼主| mochou 发表于 2013-4-26 13:31 | 显示全部楼层 |阅读模式
*                                       INITIALIZE A TASK'S STACK
* Description: This function is called by OS_Task_Create() or OSTaskCreateExt() to initialize the stack
*              frame of the task being created. This function is highly processor specific.
* Arguments  : p_task       Pointer to the task entry point address.
*              p_arg        Pointer to a user supplied data area that will be passed to the task
*                               when the task first executes.
*              p_stk_base   Pointer to the base address of the stack.
*              stk_size     Size of the stack, in number of CPU_STK elements.
*              opt          Options used to alter the behavior of OS_Task_StkInit().
*                            (see OS.H for OS_TASK_OPT_xxx).
* Returns    : Always returns the location of the new top-of-stack' once the processor registers have
*              been placed on the stack in the proper order.
* Note(s)    : 1) Interrupts are enabled when task starts executing.
*              2) All tasks run in Thread mode, using process stack.
CPU_STK  *OSTaskStkInit (OS_TASK_PTR    p_task,
                         void          *p_arg,
                         CPU_STK       *p_stk_base,
                         CPU_STK       *p_stk_limit,
                         CPU_STK_SIZE   stk_size,
                         OS_OPT         opt)
    CPU_STK  *p_stk;
    (void)opt;                                              /* Prevent compiler warning                               */
    p_stk = &p_stk_base[stk_size];                          /* Load stack pointer                                     */
                                                            /* Registers stacked as if auto-saved on exception        */
    *--p_stk = (CPU_STK)0x01000000u;                        /* xPSR                                                   */
    *--p_stk = (CPU_STK)p_task;                             /* Entry Point                                            */
    *--p_stk = (CPU_STK)OS_TaskReturn;                      /* R14 (LR)                                               */
    *--p_stk = (CPU_STK)0x12121212u;                        /* R12                                                    */
    *--p_stk = (CPU_STK)0x03030303u;                        /* R3                                                     */
    *--p_stk = (CPU_STK)0x02020202u;                        /* R2                                                     */
    *--p_stk = (CPU_STK)p_stk_limit;                        /* R1                                                     */
    *--p_stk = (CPU_STK)p_arg;                              /* R0 : argument                                          */
                                                            /* Remaining registers saved on process stack             */
    *--p_stk = (CPU_STK)0x11111111u;                        /* R11                                                    */
    *--p_stk = (CPU_STK)0x10101010u;                        /* R10                                                    */
    *--p_stk = (CPU_STK)0x09090909u;                        /* R9                                                     */
    *--p_stk = (CPU_STK)0x08080808u;                        /* R8                                                     */
    *--p_stk = (CPU_STK)0x07070707u;                        /* R7                                                     */
    *--p_stk = (CPU_STK)0x06060606u;                        /* R6                                                     */
    *--p_stk = (CPU_STK)0x05050505u;                        /* R5                                                     */
    *--p_stk = (CPU_STK)0x04040404u;                        /* R4                                                     */
    return (p_stk);
请问几个寄存器的地址是怎么来的,谢谢。
IJK 发表于 2013-4-26 13:46 | 显示全部楼层
几个寄存器的地址是怎么来的
应该说,CPU寄存器没有地址。这是只是通过压栈操作把这些值放入堆栈,在出栈时这些值会写入提示中的寄存器去。
个人签名:原理图及多层PCB设计,嵌入式程序开发(MPC5634,MPC5604,STM32,9S12,9S08,AVR,51,ARM7等),擅长汽车电子开发。联系QQ:1754281889.上海。
62
