各位高手帮我看一看这个串行口问题啊!!是什么情况.
2447|7
 楼主| win2000_li 发表于 2007-1-22 10:40 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<string.h>
#define TBUF_SIZE 4
#define RBUF_SIZE 4
unsigned char tbuf[TBUF_SIZE];//发送缓冲区
unsigned char rbuf[RBUF_SIZE];//接收缓冲区
unsigned char r_head;
unsigned char t_head; //发送缓冲区的头计数器
unsigned char t_len;  //要发送数据的长度
unsigned char temp = 0;      //临时计数器
unsigned char remp = 0;      //临时计数器
unsigned char count;
unsigned char code Ret[4] = "00ok";
unsigned char code Err[4] = "0err";
unsigned char rxdata[6];
bit rflag;
/*******串行口初化函数**************/
void com_initialize(void)
    EA = 0;
    t_head  = 0;        //清除接收和发送缓冲区
    t_len = 0;
    PCON    = 0x00;       //SMOD = 0
    SCON    = 0xD0;       //串行口方式3,11位异步收发。允许接收,清除发送中断标志,清除接收中断村志
    T2CON   = 0x34;       //0011,0100定时器2的溢出脉冲作串口发送时钟,和接收时钟.启动定时器2
#if 1
    RCAP2H  = 0x0ff;                         //22.1184MHz 单倍速9600
    RCAP2L  = 0x0b8;
#else
    RCAP2H  = 0x0ff;                         //22.1184MHz 双倍速9600
    RCAP2L  = 0x071;
#endif
    ES=1;      //允许串行中断/
    TR2 = 1;  //启动T2
    EA = 1;
/*启动发送*/
void com_send_data(unsigned char *senddata, unsigned char len)
    unsigned char i;
    t_len = len;    //发送的长度
    for(i = 0; i < t_len; i++)
        tbuf = senddata;
    rflag = 0;
    memset(rbuf,0,4);
    TI = 1;         //开始发送
unsigned char checksum(unsigned char *puInBuf, unsigned char puInBufLen)
    unsigned char i;
    unsigned char ucRet = 0;
    for (i = 0; i <= puInBufLen-1; i++)
        ucRet ^= puInBuf;
    return(ucRet);
/*******************中断处理函数********************/
//串行口中断(完成数据的接收和发送)
void com_isr(void) interrupt 4 using 2
     if(RI)
        RI = 0;
        rbuf[r_head++]=SBUF;
        if(r_head == 4)
            rflag =1;
            r_head = 0;
        /*ch=SBUF;
          if(ch > 127)
              rbuf[count++] = ch;
            checksum = ch - 128;
          else
              rbuf[count++] = ch;
            checksum ^= ch;
            if((count == RBUF_SIZE)&&(!checksum))
                rflag = 1;
                count = 0;
    else if(TI)
        TI = 0;
        if(t_head >= t_len)
            t_head = 0;
        else
            SBUF = tbuf[t_head++];
void main(void)
    unsigned int i=10000;
    unsigned char j;
    com_initialize();
    while(1)
        if(rflag)//如果取数标志已置位,就将读到的数从串口发出
            j = !checksum(&rbuf, 4);
            switch(j)
                case 0:
                    //P1 = rbuf[1];
                    com_send_data(&Err, 4);
                    while(--i);
                break;
                case 1:
                    P1 = rbuf[1];
                    com_send_data(&Ret, 4);
                    while(--i);
                break;
                default:break;
我的这个串口程序经常出现校验不正确!并且还经常丢数据。搞了一周还是没有结论!请各位高手指点小弟一下!!!
 楼主| win2000_li 发表于 2007-1-22 10:43 | 显示全部楼层
还有!
控制的IO口状态,也不能达到控制的效果啊!!
命令格式:30 30 31 31
第一个是地址,二个是输出,三个是P1.0输出1。四个是校验和
hotpower 发表于 2007-1-22 12:47 | 显示全部楼层
有时间看看~~~
 楼主| win2000_li 发表于 2007-1-22 13:35 | 显示全部楼层
先谢谢了!!!我可能是还没有把串行口的时序搞清楚啊!
自已还要努力!!!
谢谢!!!
希望能指点一下!!!
hotpower 发表于 2007-1-22 16:41 | 显示全部楼层
估计是while(--i);搞得鬼.
将其屏蔽掉试试.//while(--i);
再:
while(--i);
先为何i没初值???(首次i=10000,其他i=0xffff)
而且while(--i);可能要丢数据,因为51的串口没有FIFO
 楼主| win2000_li 发表于 2007-1-22 17:21 | 显示全部楼层
改了的,有所改善
但是还有问题啊!
如:
    我发: 00 00 01 01 ---HEX
有时收到: 01 00 00 01 ---HEX
应该收到: 00 00 01 01 ---HEX
把设备重新上电复位后,问题就消除了。
不知为什么?是不是发送数据时,第一次只收到前三个,第二次才补上第一个,但是导致出错啊!!
不好意思!因为第一次搞串口,所以不懂,请大家指点!!!
hotpower 发表于 2007-1-22 18:01 | 显示全部楼层
这就是十六进制发送需要同步的问题
 楼主| win2000_li 发表于 2007-1-23 10:00 | 显示全部楼层
那个这问题的解决呢!?
请兄弟指点小弟一下你的思想!!!!
