CC2500
1392|1
 楼主| zjycxmei 发表于 2013-5-1 12:57 | 显示全部楼层 |阅读模式
const RF_SETTINGS rfSettings =
0x00,
    0x0B,   // FSCTRL1   Frequency synthesizer control.
    0x00,   // FSCTRL0   Frequency synthesizer control.
    0x10,   // FREQ2     Frequency control word, high byte.
    0xA7,   // FREQ1     Frequency control word, middle byte.
    0x62,   // FREQ0     Frequency control word, low byte.
    0x2D,   // MDMCFG4   Modem configuration.
    0x3B,   // MDMCFG3   Modem configuration.
    0x73,   // MDMCFG2   Modem configuration.
    0x22,   // MDMCFG1   Modem configuration.
    0xF8,   // MDMCFG0   Modem configuration.
    0x00,   // CHANNR    Channel number.
    0x00,   // DEVIATN   Modem deviation setting (when FSK modulation is enabled).
    0xB6,   // FREND1    Front end RX configuration.
    0x10,   // FREND0    Front end RX configuration.
    0x18,   // MCSM0     Main Radio Control State Machine configuration.
    0x1D,   // FOCCFG    Frequency Offset Compensation Configuration.
    0x1C,   // BSCFG     Bit synchronization Configuration.
    0xC7,   // AGCCTRL2  AGC control.
    0x00,   // AGCCTRL1  AGC control.
    0xB2,   // AGCCTRL0  AGC control.
    0xEA,   // FSCAL3    Frequency synthesizer calibration.
    0x0A,   // FSCAL2    Frequency synthesizer calibration.
    0x00,   // FSCAL1    Frequency synthesizer calibration.
    0x11,   // FSCAL0    Frequency synthesizer calibration.
    0x59,   // FSTEST    Frequency synthesizer calibration.
    0x88,   // TEST2     Various test settings.
    0x31,   // TEST1     Various test settings.
    0x0B,   // TEST0     Various test settings.
    0x0B,   // IOCFG2    GDO2 output pin configuration.
    0x06,   // IOCFG0D   GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation.
    0x04,   // PKTCTRL1  Packet automation control.
    0x05,   // PKTCTRL0  Packet automation control.
    0x00,   // ADDR      Device address.
    0x0c    // PKTLEN    Packet length.
void main()
  WDTCTL = WDTPW + WDTHOLD;
  InitSys();
  P3DIR|=BIT0+BIT1+BIT3;
  P4DIR|=BIT0;
  P1SEL=0x00;
  P3SEL=0x00;
  CpuInit();
  POWER_UP_RESET_CC2500();
  halRfWriteRfSettings();
  VER=halSpiReadReg(CCxxx0_SYNC1);
halSpiWriteBurstReg(CCxxx0_PATABLE,PaTabel,8);
while(1)
      halSpiStrobe(CCxxx0_SIDLE);
      halRfSendPacket(txBuffer,3);
      delay(1000);
jxmzzr 发表于 2013-12-5 15:54 | 显示全部楼层
楼主直接上代码是不是有点伤人啊?帮顶下吧
