求高手帮忙看一下看啦一个小时都没发现错误但是调试就是
2378|8
 楼主| yaoyao1314 发表于 2013-5-2 00:39 | 显示全部楼层 |阅读模式
#include <reg52.h>
                                宏定义
//typedef  unsigned char uchar;
#define uchar unsigned char
typedef  unsigned int int16;
                        位端口定义
sbit duPort = P2^6;
sbit weiPort = P2^7;
sbit ledP0 = P1^0;
sbit ledP1 = P1^1;
sbit ledP2 = P1^2;
sbit ledp3 = P1^3;
sbit ledp4 = P1^4;
sbit ledP5 = P1^5;
                                全局变量声明
int16 T0_COUNT;
int16 ledInt = 0Xfa;
uchar led_Type = 1;
                        函数声明
void Init_Time0(void);
                        函数定义
                        初始化定时器0
void Iint_Time0(void)
        TMOD = 0X01;
        TH0 = 0X4B;
        TL0 = 0XFD;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
                                定时器0中断
void Time0_interrupt(void) interrupt 1
        T0_COUNT ++;
        TH0 = 0X4B;
        TL0 = 0XFD;
                        控制LED灯亮或者灭
void Init_Led(uchar ledLignt)
        P1 =  ledLignt;
                        控制LED灯亮或者灭
void led_Control()
        switch(led_Type)
                case 1:
                        Init_Led(0xfa);
                        if(T0_COUNT != 100)
                                return;
                        T0_COUNT = 0;
                        led_Type = 2;
                        break;
                case 2:
                        if(T0_COUNT%2==0)
                                Init_Led(0xee);
                        else
                                Init_Led(0xef);
                        if(T0_COUNT != 20)
                                return;
                        T0_COUNT = 0;
                        led_Type = 3;
                break;
                case 3:
                        Init_Led(0xf5);
                        if(T0_COUNT != 100)
                                return;
                        T0_COUNT = 0;
                        led_Type = 4;
                break;
                case 4:
                        if(T0_COUNT%2==0)
                                Init_Led(0xee);
                        else
                                Init_Led(0xef);
                        if(T0_COUNT != 20)
                                return;
                        T0_COUNT = 0;
                        led_Type = 1;
                break;
void mian(void)
        Iint_Time0();
        while(1)
                led_Control();
 楼主| yaoyao1314 发表于 2013-5-2 00:40 | 显示全部楼层
为什么跑不进switch case 里面去呢?问题补充
yklstudent 发表于 2013-5-2 06:38 | 显示全部楼层
mian???????????????
ayb_ice 发表于 2013-5-2 07:54 | 显示全部楼层
编译过了?
thanklei 发表于 2013-5-2 09:12 | 显示全部楼层
楼主的主函数名都写错了,肯定进不去。这个编译Warning应该有提示吧。
NE5532 发表于 2013-5-2 11:04 | 显示全部楼层
这就是编译不看警告提示的人。呵呵。
MCU_Jason 发表于 2013-5-2 17:44 | 显示全部楼层
525156zhh 发表于 2013-5-6 23:35 | 显示全部楼层
hopewise 发表于 2013-5-7 07:55 | 显示全部楼层
case 1:
从0开始试一下,即从case 0:
