[STM8] 固件库问题
5920|6
 楼主| s20120907 发表于 2013-5-2 21:37 | 显示全部楼层 |阅读模式
在添加固件库时,提示出错#error clnk Debug\test.lkf:1 symbol _assert_failed not defined (Debug\wy_tim6.o )
觉得问题出在  assert_param(IS_TIM6_SLAVE_MODE_OK(TIM6_SlaveMode));没明白这是什么意思?
weicz 发表于 2013-5-3 08:51 | 显示全部楼层
连接不到_assert_failed这个函数吧,是不是你的固件库版本有问题
weicz 发表于 2013-5-3 16:11 | 显示全部楼层
s20120907 发表于 2013-5-3 15:13
assert_param 这个函数在哪个h文件中
stm32f10x_conf.h中有关于他的定义
#ifdef  DEBUG
* Macro Name     : assert_param
* Description    : The assert_param macro is used for function's parameters check.
*                  It is used only if the library is compiled in DEBUG mode.
* Input          : - expr: If expr is false, it calls assert_failed function
*                    which reports the name of the source file and the source
*                    line number of the call that failed.
*                    If expr is true, it returns no value.
* Return         : None
  #define assert_param(expr) ((expr) ? (void)0 : assert_failed((u8 *)__FILE__, __LINE__))
/* Exported functions ------------------------------------------------------- */
  void assert_failed(u8* file, u32 line);
#else
  #define assert_param(expr) ((void)0)
#endif /* DEBUG */
这个文件的最开头有一段注释,你看看
/* Uncomment the line below to compile the library in DEBUG mode, this will expanse
   the "assert_param" macro in the firmware library code (see "Exported macro"
   section below) */
/*#define DEBUG    1*/
如果你不需要输出这些debug信息,你就#define DEBUG 0试试看
mmuuss586 发表于 2013-5-3 16:47 | 显示全部楼层
从网上下个程序先编译下。进行对比……
ben001 发表于 2013-12-10 18:26 | 显示全部楼层
在main.c文件的末尾添加以下的语句就可以解决了:
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
gzcc 发表于 2014-9-12 17:11 | 显示全部楼层
加上解决但是不知道为什么
