如何让应用程序直接调用bootloader的程序?
1608|0
 楼主| zzz2012 发表于 2013-5-7 20:06 | 显示全部楼层 |阅读模式
最近在看TI cortex-m3 芯片bootloader.
    export  __Vectors
__Vectors
    dcd     g_pulStack + (_STACK_SIZE * 4)  ; Offset 00: Initial stack pointer
    dcd     Reset_Handler                   ; Offset 04: Reset handler
    dcd     NmiSR + 0x20000000              ; Offset 08: NMI handler
    dcd     FaultISR + 0x20000000           ; Offset 0C: Hard fault handler
    dcd     IntDefaultHandler + 0x20000000  ; Offset 10: MPU fault handler
    dcd     IntDefaultHandler + 0x20000000  ; Offset 14: Bus fault handler
    dcd     IntDefaultHandler + 0x20000000  ; Offset 18: Usage fault handler
    dcd     0                               ; Offset 1C: Reserved
    dcd     0                               ; Offset 20: Reserved
    dcd     0                               ; Offset 24: Reserved
    dcd     0                               ; Offset 28: Reserved
    dcd     UpdateHandler                   ; Offset 2C: SVCall handler
UpdateHandler
    ; Initialize the processor.
    bl      ProcessorInit
    ; Load the stack pointer from the vector table.
    movs    r0, #0x00000000
    ldr     r0, [r0]
    mov     sp, r0
    ; Branch to the update handler.
    if      :def:_ENET_ENABLE_UPDATE
    b       UpdateBOOTP
    else
    b       Updater
    endif
通过上面的代码:发现SVCall handler直接升级应用程序的,那么应用程序如何才能执行这个SVC中断呢?
