Software Library\NANO100B_Series_CMSIS_BSP_EN_Rev1.00.005\Samples\Nu_LB\I2C_24LC64 这路径里不是有吗?
EEPROM_24LC64.c文件中有 void Write_24LC64(uint32_t address,uint8_t data ) 和 uint8_t Read_24LC64(uint32_t address)
还有主程序 I2C_24LC64_Main.c :
int main(void)
uint32_t i2cdata=0;
printf("+---------------------------------------------------------------------+\n");
printf("| I2C Driver Sample Code |\n");
printf("| |\n");
/* Set multi function pin for I2C0 */
GCR->PA_H_MFP = GCR->PA_H_MFP & ~(PA8_MFP_MASK|PA9_MFP_MASK) |
PA8_MFP_I2C0_SDA | PA9_MFP_I2C0_SCL;
Write_24LC64(0x00000000, 0x55);
SYS_Delay(10000); //delay for finish writting
i2cdata= Read_24LC64(0x00000000);
if(i2cdata != 0x55)
printf("EEPROM Read/Write Test fail!\n");
else
printf("EEPROM Read/Write Test pass!\n");
#ifdef USE_ASSERT
* @brief The function prints the source file name and line number where the assert_param() error
* occurs, and then stops in an infinite loop. User can add his own codes here if necessary.
* @param[in] file Source file name
* @param[in] line Line number
* @return None
void assert_error(uint8_t * file, uint32_t line)
GCR->PB_L_MFP = (GCR->PB_L_MFP & ~0x77) | (PB1_MFP_UART0_TX | PB0_MFP_UART0_RX); /* Select multi-function pin for UART0 */
CLK->APBCLK |= CLK_APBCLK_UART0_EN; /* Enable UART0 clock */
CLK->CLKDIV0 &= ~CLK_CLKDIV0_UART_MASK;
CLK->CLKSEL1 = (CLK->CLKSEL1 & ~CLK_CLKSEL1_UART_MASK) | CLK_CLKSEL1_UART_HXT; /* Select 12 Mhz XTAL */
/* Set UART to 115200,n,8,1,none */
UART0->BAUD = 0x67; /* Baud Rate:115200 for 12MHz */
UART0->TLCTL = 0x03; /* Word len is 8 bits */
printf("[%s] line %d : wrong parameters.\r\n", file, line);
/* Infinite loop */
while(1) ;
#endif
/*** (C) COPYRIGHT 2012 Nuvoton Technology Corp. ***/
