uCOS c++不能仿真
3491|0
eng588|  楼主 | 2013-6-6 22:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下载了uCOS在STM32107上的工程,用C++编译痛过,但仿真时出现:
     User error: Base address of vector table has incorrect alignment. Vector base addr = 0x00000150
感觉是中断向量表连接时定位出现问题(c编译没问题):
#pragma language=extended
#pragma segment="CSTACK"
#ifdef __cplusplus
extern "C" {
#endif
static  void  App_NMI_ISR        (void);
static  void  App_Fault_ISR      (void);
static  void  App_BusFault_ISR   (void);
static  void  App_UsageFault_ISR (void);
static  void  App_MemFault_ISR   (void);
static  void  App_Spurious_ISR   (void);
static  void  App_Reserved_ISR   (void);
void  __iar_program_start(void);
#ifdef __cplusplus
#endif
*                                     LOCAL CONFIGURATION ERRORS
*                                  EXCEPTION / INTERRUPT VECTOR TABLE
* Note(s) : (1) The Cortex-M3 may have up to 256 external interrupts, which are the final entries in the
*               vector table.  The STM32 has 48 external interrupt vectors.
__root  const  APP_INTVECT_ELEM  __vector_table[] @ ".intvec" = {
    { .Ptr = (void *)__sfe( "CSTACK" )},                        /*  0, SP start value.                                  */
    __iar_program_start,                                        /*  1, PC start value.                                  */
    App_NMI_ISR,                                                /*  2, NMI.                                             */
    App_Fault_ISR,                                              /*  3, Hard Fault.                                      */
    App_MemFault_ISR,                                           /*  4, Memory Management.                               */
    App_BusFault_ISR,                                           /*  5, Bus Fault.                                       */
    App_UsageFault_ISR,                                         /*  6, Usage Fault.                                     */
    App_Spurious_ISR,                                           /*  7, Reserved.                                        */
    App_Spurious_ISR,                                           /*  8, Reserved.                                        */
    App_Spurious_ISR,                                           /*  9, Reserved.                                        */
    App_Spurious_ISR,                                           /* 10, Reserved.                                        */
    App_Spurious_ISR,                                           /* 11, SVCall.                                          */
    App_Spurious_ISR,                                           /* 12, Debug Monitor.                                   */
    App_Spurious_ISR,                                           /* 13, Reserved.                                        */
    OS_CPU_PendSVHandler,                                       /* 14, PendSV Handler.                                  */
    OS_CPU_SysTickHandler,                                      /* 15, uC/OS-II Tick ISR Handler.                       */
    BSP_IntHandlerWWDG,                                         /* 16, INTISR[  0]  Window Watchdog.                    */
    BSP_IntHandlerPVD,                                          /* 17, INTISR[  1]  PVD through EXTI Line Detection.    */
    BSP_IntHandlerTAMPER,                                       /* 18, INTISR[  2]  Tamper Interrupt.                   */
    BSP_IntHandlerRTC,                                          /* 19, INTISR[  3]  RTC Global Interrupt.               */
    BSP_IntHandlerFLASH,                                        /* 20, INTISR[  4]  FLASH Global Interrupt.             */
    BSP_IntHandlerRCC,                                          /* 21, INTISR[  5]  RCC Global Interrupt.               */
    BSP_IntHandlerEXTI0,                                        /* 22, INTISR[  6]  EXTI Line0 Interrupt.               */
    BSP_IntHandlerEXTI1,                                        /* 23, INTISR[  7]  EXTI Line1 Interrupt.               */
    BSP_IntHandlerEXTI2,                                        /* 24, INTISR[  8]  EXTI Line2 Interrupt.               */
    BSP_IntHandlerEXTI3,                                        /* 25, INTISR[  9]  EXTI Line3 Interrupt.               */
    BSP_IntHandlerEXTI4,                                        /* 26, INTISR[ 10]  EXTI Line4 Interrupt.               */
    BSP_IntHandlerDMA1_CH1,                                     /* 27, INTISR[ 11]  DMA Channel1 Global Interrupt.      */
    BSP_IntHandlerDMA1_CH2,                                     /* 28, INTISR[ 12]  DMA Channel2 Global Interrupt.      */
    BSP_IntHandlerDMA1_CH3,                                     /* 29, INTISR[ 13]  DMA Channel3 Global Interrupt.      */
    BSP_IntHandlerDMA1_CH4,                                     /* 30, INTISR[ 14]  DMA Channel4 Global Interrupt.      */
    BSP_IntHandlerDMA1_CH5,                                     /* 31, INTISR[ 15]  DMA Channel5 Global Interrupt.      */
    BSP_IntHandlerDMA1_CH6,                                     /* 32, INTISR[ 16]  DMA Channel6 Global Interrupt.      */
    BSP_IntHandlerDMA1_CH7,                                     /* 33, INTISR[ 17]  DMA Channel7 Global Interrupt.      */
    BSP_IntHandlerADC1_2,                                       /* 34, INTISR[ 18]  ADC1 & ADC2 Global Interrupt.       */
    BSP_IntHandlerCAN1_TX,                                      /* 35, INTISR[ 19]  USB High Prio / CAN TX  Interrupts. */
    BSP_IntHandlerCAN1_RX0,                                     /* 36, INTISR[ 20]  USB Low  Prio / CAN RX0 Interrupts. */
    BSP_IntHandlerCAN1_RX1,                                     /* 37, INTISR[ 21]  CAN RX1 Interrupt.                  */
    BSP_IntHandlerCAN1_SCE,                                     /* 38, INTISR[ 22]  CAN SCE Interrupt.                  */
    BSP_IntHandlerEXTI9_5,                                      /* 39, INTISR[ 23]  EXTI Line[9:5] Interrupt.           */
    BSP_IntHandlerTIM1_BRK,                                     /* 40, INTISR[ 24]  TIM1 Break  Interrupt.              */
    BSP_IntHandlerTIM1_UP,                                      /* 41, INTISR[ 25]  TIM1 Update Interrupt.              */
    BSP_IntHandlerTIM1_TRG_COM,                                 /* 42, INTISR[ 26]  TIM1 Trig & Commutation Interrupts. */
    BSP_IntHandlerTIM1_CC,                                      /* 43, INTISR[ 27]  TIM1 Capture Compare Interrupt.     */
    BSP_IntHandlerTIM2,                                         /* 44, INTISR[ 28]  TIM2 Global Interrupt.              */
    BSP_IntHandlerTIM3,                                         /* 45, INTISR[ 29]  TIM3 Global Interrupt.              */
    BSP_IntHandlerTIM4,                                         /* 46, INTISR[ 30]  TIM4 Global Interrupt.              */
    BSP_IntHandlerI2C1_EV,                                      /* 47, INTISR[ 31]  I2C1 Event  Interrupt.              */
    BSP_IntHandlerI2C1_ER,                                      /* 48, INTISR[ 32]  I2C1 Error  Interrupt.              */
    BSP_IntHandlerI2C2_EV,                                      /* 49, INTISR[ 33]  I2C2 Event  Interrupt.              */
    BSP_IntHandlerI2C2_ER,                                      /* 50, INTISR[ 34]  I2C2 Error  Interrupt.              */
    BSP_IntHandlerSPI1,                                         /* 51, INTISR[ 35]  SPI1 Global Interrupt.              */
    BSP_IntHandlerSPI2,                                         /* 52, INTISR[ 36]  SPI2 Global Interrupt.              */
    BSP_IntHandlerUSART1,                                       /* 53, INTISR[ 37]  USART1 Global Interrupt.            */
    BSP_IntHandlerUSART2,                                       /* 54, INTISR[ 38]  USART2 Global Interrupt.            */
    BSP_IntHandlerUSART3,                                       /* 55, INTISR[ 39]  USART3 Global Interrupt.            */
    BSP_IntHandlerEXTI15_10,                                    /* 56, INTISR[ 40]  EXTI Line [15:10] Interrupts.       */
    BSP_IntHandlerRTCAlarm,                                     /* 57, INTISR[ 41]  RTC Alarm EXT Line Interrupt.       */
    BSP_IntHandlerUSBWakeUp,                                    /* 58, INTISR[ 42]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 59, INTISR[ 43]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 60, INTISR[ 44]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 61, INTISR[ 45]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 62, INTISR[ 46]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 63, INTISR[ 47]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 64, INTISR[ 48]  USB Wakeup from Suspend EXTI Int.   */
    App_Reserved_ISR,                                           /* 65, INTISR[ 49]  USB Wakeup from Suspend EXTI Int.   */
    BSP_IntHandlerTIM5,                                         /* 66, INTISR[ 50]  TIM5 global Interrupt.              */
    BSP_IntHandlerSPI3,                                         /* 67, INTISR[ 51]  SPI3 global Interrupt.              */
    BSP_IntHandlerUSART4,                                       /* 68, INTISR[ 52]  UART4 global Interrupt.             */
    BSP_IntHandlerUSART5,                                       /* 69, INTISR[ 53]  UART5 global Interrupt.             */
    BSP_IntHandlerTIM6,                                         /* 70, INTISR[ 54]  TIM6 global Interrupt.              */
    BSP_IntHandlerTIM7,                                         /* 71, INTISR[ 55]  TIM7 global Interrupt.              */
    BSP_IntHandlerDMA2_CH1,                                     /* 72, INTISR[ 56]  DMA2 Channel 1 global Interrupt.    */
    BSP_IntHandlerDMA2_CH2,                                     /* 73, INTISR[ 57]  DMA2 Channel 2 global Interrupt.    */
    BSP_IntHandlerDMA2_CH3,                                     /* 74, INTISR[ 58]  DMA2 Channel 3 global Interrupt.    */
    BSP_IntHandlerDMA2_CH4,                                     /* 75, INTISR[ 59]  DMA2 Channel 4 global Interrupt.    */
    BSP_IntHandlerDMA2_CH5,                                     /* 76, INTISR[ 60]  DMA2 Channel 5 global Interrupt.    */
    BSP_IntHandlerETH,                                          /* 77, INTISR[ 61]  ETH global Interrupt.               */
    BSP_IntHandlerETHWakeup,                                    /* 78, INTISR[ 62]  ETH WakeUp from EXTI line Int.      */
    BSP_IntHandlerCAN2_TX,                                      /* 79, INTISR[ 63]  CAN2 TX Interrupts.                 */
    BSP_IntHandlerCAN2_RX0,                                     /* 80, INTISR[ 64]  CAN2 RX0 Interrupts.                */
    BSP_IntHandlerCAN2_RX1,                                     /* 81, INTISR[ 65]  CAN2 RX1 Interrupt.                 */
    BSP_IntHandlerCAN2_SCE,                                     /* 82, INTISR[ 66]  CAN2 SCE Interrupt.                 */
    BSP_IntHandlerOTG,                                          /* 83, INTISR[ 67]  OTG global Interrupt.               */
*                                            App_NMI_ISR()
* Description : Handle Non-Maskable Interrupt (NMI).
* Argument(s) : none.
* Return(s)   : none.
* Caller(s)   : This is an ISR.
* Note(s)     : (1) Since the NMI is not being used, this serves merely as a catch for a spurious
*                   exception.
    while (DEF_TRUE) {
*                                             App_Fault_ISR()
* Description : Handle hard fault.
* Return(s)   : none.
* Note(s)     : none.
    while (DEF_TRUE) {
*                                           App_BusFault_ISR()
* Description : Handle bus fault.
* Return(s)   : none.
* Note(s)     : none.
    while (DEF_TRUE) {
*                                          App_UsageFault_ISR()
* Description : Handle usage fault.
* Return(s)   : none.
* Note(s)     : none.
    while (DEF_TRUE) {
*                                           App_MemFault_ISR()
* Description : Handle memory fault.
* Return(s)   : none.
* Note(s)     : none.
    while (DEF_TRUE) {
*                                           App_Spurious_ISR()
* Description : Handle spurious interrupt.
* Return(s)   : none.
* Note(s)     : none.
    while (DEF_TRUE) {
*                                           App_Reserved_ISR()
* Description : Reserved interrupt vector place holder.
* Return(s)   : none.
* Note(s)     : none.
个人签名:和平時期做牛馬,戰爭時期當炮灰
82
