【开源】FPGA竞赛实战系列套件资料(外挂模块可达10多块)
7519|46
 楼主| navalguy001 发表于 2014-8-8 20:01 | 显示全部楼层
2014年TI杯电子设计竞赛推荐芯片列表:
电源类        MOSFET驱动器        TPS28225DR        8-Pin High Frequency 4-Amp Sink Synchronous MOSFET Driver
                UCC27211DDAR        120V Boot, 4A Peak, High Frequency High-Side Low-Side Driver
        降压开关电源,MOS管内置        TPS54340DDAR        42 V Input, 3.5 A, Step-Down DC/DC Converter with Eco-mode™
                TPS56528DDAR        4.5V to 18V Input, 5-A Synchronous Step-Down Converter with Advanced Eco-mode™
        降压线性电源        TPS7A1601QDGNRQ1        Automotive Catalog 60V, 5-µA Iq, 100-mA, Low-Dropout Voltage Regulator with Enable and Power Good
        降压线性电源        TPS7A4001DGNR        100V Input, 50mA, Single Output Low-Dropout Linear Regulator
        升压开关电源,MOS管外置        TPS40210DGQR        Wide Input Range Current Mode Boost Controller
        MOS管        CSD19535KCS        100V, N-Channel NexFET™ Power MOSFET
        电流检测芯片        INA210AIDCKR        Voltage Output, High/Low-Side Measurement, Bi-Directional Zero-Drift Series Current Shunt Monitor
                INA282AIDR        Wide Common Mode Range, Bidirectional, High Accuracy Current Shunt Monitor
高速放大器        电流反馈        THS3201D        1.8GHz Current Feedback Amplifier
                LMH6703MF/NOPB        1.2 GHz, Low Distortion Op Amp with Shutdown
                OPA2695ID        Dual, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable
        差分输入压控增益放大器        VCA821ID        Wideband, > 40dB Adjust Range, Linear in dB Variable Gain Amplifier
        全差分放大器        LMH6552MA/NOPB        1.5 GHz Fully Differential Amplifier
        电压反馈        OPA842IDR        Wideband, Low Distortion, Unity Gain Stable, Voltage Feedback Operational Amplifier
        5V 电压反馈        OPA2356AIDR        2.5V, 200MHz GBW, CMOS Dual Op Amp
精密ADC/DAC        Delta-Sigma        ADS1118IDGSR        16-Bit ADC with Integrated MUX, PGA, Temperature Sensor, Oscillator, and Reference
        Multiplying DAC, R-2R        DAC7811IDGSR        12-Bit, Serial Input, Multiplying Digital to Analog Converter
        R-String DAC        DAC8571IDGKR        Low-Power Rail-To-Rail Output 16-Bit I2C Input DAC
        3V 参考源        REF3330AIDBZR        30ppm/C Drift, 3.9uA, SOT23-3, SC70-3 Voltage Reference
精密放大器        5V CMOS 仪表放大器        INA333AIDGKR        Low Power, Precision Instrumentation Amplifier
        36V 仪表放大器        INA826AID        Precision, 200-μA Supply Current, 36-V Supply Instrumentation Amplifier
        36V 精密放大器        OPA192IDR        High Voltage, Rail-to-Rail Input/Output,Precision Op Amps,GBW = 10MHz
        5V CMOS 放大器        OPA2320AIDGKR        Precision, 20MHz, 0.9pA Ib, RRIO, CMOS Operational Amplifier
        5V CMOS 放大器        OPA2330AIDR        1.8V, 35µA, microPower, Precision, Zero Drift CMOS Op Amp
        5V CMOS 放大器        OPA2376AIDR        Precision, Low Noise, Low Quiescent Current Operational Amplifier
音频功放        D类25W功放        TPA3112D1PWPR        25-W Filter-Free Mono Class-D Audio Amplifier with SpeakerGuard™ (TPA3112)
其他        高速比较器        TLV3501AIDR        4.5ns Rail-to-Rail, High Speed Comparator in Microsized Packages
        1bit 数字缓冲器        SN74AUP1G07DBVR        Low-Power Single Buffer/Driver with Open-Drain Outputs
        5V 2选一模拟开关        TS5A3159DBVR        1-Ohm SPDT Analog Switch
        5V 单通道模拟开关        TS5A3166DBVR
        12V 单通道模拟开关        TS12A4515DR
 楼主| navalguy001 发表于 2014-8-29 20:00 | 显示全部楼层
2014 年 山东省 TI 杯电子设计竞赛 基本仪器和主要元器件清单
基本仪器和主要元器件清单
1、基本仪器清单
100M示波器  低频毫伏表  单相电能测试仪(2A)   100VA隔离变压器
4路示波器(≥60MHZ)  数字频率计   功率因数表(≥2A)
四位半数字万用表   60M数字示波器
2、主要元器件清单
TI元器件    显示器件  MP3   滑动电阻(≥30W)  电阻(5Ω/16W)
  肺活量传感器     称重压力传感器(≥180kg)
                                                              全国大学生电子竞赛山东赛区组委会
        2014.8.29
liumpc 发表于 2014-11-23 09:58 来自手机 | 显示全部楼层
好好拜读
rongjinzhuo 发表于 2015-6-18 21:22 | 显示全部楼层
那都有你的广告,,不过,还是值得学习的
liulwn 发表于 2015-7-4 23:49 | 显示全部楼层
学习一下
yhsy1002 发表于 2015-7-8 18:13 | 显示全部楼层
原来是几年前的东东啊
yxycdz 发表于 2015-7-11 16:18 | 显示全部楼层
谢谢分享
