为什么我在main函数里面能够访问NVIC
1889|4
 楼主| inurl 发表于 2013-6-30 11:04 | 显示全部楼层 |阅读模式
系统上电之后不是进入了 thread mode (unprivileged) 吗?
NVIC(0xE000_E000)不是要在privileged下才能访问吗?
“The processor enters Thread mode on Reset, or as a result of an exception return.
Privileged and Unprivileged code can run in Thread mode.”
“Unprivileged execution limits or excludes access to some resources. Privileged execution has access to all resources. Handler mode is
always privileged. Thread mode can be privileged or unprivileged.”
 楼主| inurl 发表于 2013-7-19 09:17 | 显示全部楼层
linfeng24 发表于 2013-8-9 00:37 | 显示全部楼层
为什么不能访问呢?如果不能访问,那么你的中断如何管理呢?
 楼主| inurl 发表于 2013-9-10 14:53 | 显示全部楼层
应该是 进入了thread mode (privileged)
hkcj 发表于 2013-9-10 18:26 | 显示全部楼层
不懂这一块  比较头疼  楼主  顶一个   先
