OK6410裸奔swi问题
2583|6
 楼主| nickyhzp 发表于 2013-7-4 15:32 | 显示全部楼层 |阅读模式
想研究一下ARM体系,决定裸奔,到了swi这一部分的时候,每次一执行swi指令,6410总是进入指令预取终止异常中,困扰了好久,求大家不吝指点
代码如下
start.s
Mode_USR        EQU     0x10
Mode_FIQ        EQU     0x11
Mode_IRQ        EQU     0x12
Mode_SVC        EQU     0x13
Mode_ABT        EQU     0x17
Mode_UND        EQU     0x1B
Mode_SYS        EQU     0x1F
UND_Stack_Size  EQU     0x00000400
SVC_Stack_Size  EQU     0x00001000
ABT_Stack_Size  EQU     0x00000400
FIQ_Stack_Size  EQU     0x00000400
IRQ_Stack_Size  EQU     0x00001000
USR_Stack_Size  EQU     0x00001000
Heap_Size       EQU     0x00010000
I_Bit           EQU     0x80            ; when I bit is set, IRQ is disabled
F_Bit           EQU     0x40            ; when F bit is set, FIQ is disabled
Stack_Top       EQU     0x52000000
WATCHDOG        EQU     0x7E004000
        IMPORT Main
;        IMPORT swi_service_func
;        IMPORT __use_no_semihosting_swi
        EXPORT SWI_Handler
        IMPORT C_SWI_Handler
        PRESERVE8
        AREA |startup|,CODE,READONLY
        ENTRY
Vector_Table
    LDR     PC, Reset_Addr
    LDR     PC, Undefined_Addr
    LDR     PC, SWI_Addr
    LDR     PC, Prefetch_Addr
    LDR     PC, Abort_Addr
    NOP                             ; Reserved vector must be remained
    LDR     PC, IRQ_Addr
        LDR     PC, FIQ_Addr
Vector_Addr_Table
Reset_Addr      DCD     Reset_Handler
Undefined_Addr  DCD     Undefined_Handler
SWI_Addr        DCD     SWI_Handler
Prefetch_Addr   DCD     Prefetch_Handler
Abort_Addr      DCD     Abort_Handler
IRQ_Addr        DCD     IRQ_Handler
FIQ_Addr        DCD     FIQ_Handler
FUN_SWI         DCD     C_SWI_Handler
; 复位地址入口
Reset_Handler
;        mrc        p15,0,r0,c1,c0,0                ;使能VIC PORT功能
;    orr r0,r0,#(1<<24)
;    mcr p15,0,r0,c1,c0,0
        LDR R0,=0x7E004000        ; WATCHDOG寄存器地址
    MOV R1,#0x0
    STR R1,[R0]                ; 写入0,禁止WATCHDOG,否则CPU会不断重启
    b       clk_init           ;时钟初始化好
    LDR     R0, =Stack_Top
    MSR     CPSR_c, #Mode_UND:OR:I_Bit:OR:F_Bit
    MOV     SP, R0
    SUB     R0, R0, #UND_Stack_Size
    MSR     CPSR_c, #Mode_ABT:OR:I_Bit:OR:F_Bit
    MOV     SP, R0
    SUB     R0, R0, #ABT_Stack_Size
    MSR     CPSR_c, #Mode_FIQ:OR:I_Bit:OR:F_Bit
    MOV     SP, R0
    SUB     R0, R0, #FIQ_Stack_Size
    MSR     CPSR_c, #Mode_IRQ:OR:I_Bit:OR:F_Bit
    MOV     SP, R0
    SUB     R0, R0, #IRQ_Stack_Size
    MSR     CPSR_c, #Mode_SVC:OR:I_Bit:OR:F_Bit
    MOV     SP, R0
        SUB     SL, SP, #SVC_Stack_Size
    MSR     CPSR_c, #Mode_USR
    MOV     SP, R0
    SUB     SL, SP, #USR_Stack_Size
    ;使能IQR中断
    ;MRS        R0,CPSR
  ;        BIC        R0,R0,#0x80
    ;MSR        CPSR_c,R0
    MSR     CPSR_c, #Mode_USR   ;intel user mode
        STMFD  sp!,{r0-r3, r12, lr} ;
        bl       Main                    ;uboot将CPU控制权交给main
        LDMFD  sp!,{r0-r3, r12, pc}^                    ;main退出后,uboot重新获取CPU控制权
Undefined_Handler
        B Undefined_Handler
T_bit EQU 0x20
SWI_Handler
        STMFD  sp!,{r0-r3, r12, lr} ; Store registers
        MOV    r1, sp                ; Set pointer to parameters
        MRS    r0, spsr              ; Get spsr
        STMFD  sp!,{r0}              ; Store spsr onto stack
        TST    r0, #T_bit            ; Occurred in Thumb state?
        LDRNEH r0, [lr,#-2]          ; Yes: Load halfword and...
        BICNE  r0, r0, #0xFF00        ; ...extract comment field
        LDREQ  r0, [lr,#-4]          ; No: Load word and...
        BICEQ  r0, r0, #0xFF000000    ; ...extract comment field          ; r0 now contains SWI number         ; r1 now contains pointer to stacked registers
        LDR    PC, FUN_SWI          ; Call main part of handler
        LDMFD  sp!,{r0}              ; Get spsr from stack
        MSR    spsr_cf, r0            ; Restore spsr
        LDMFD  sp!,{r0-r3, r12, pc}^ ; Restore registers and return
Prefetch_Handler
        B Prefetch_Handler
Abort_Handler
        B Abort_Handler
IRQ_Handler
        B IRQ_Handler
FIQ_Handler
        B FIQ_Handler
;clock
ELFIN_WATCHDOG_BASE  EQU   0x7e004000
ELFIN_CLOCK_POWER_BASE EQU   0x7e00f000
OTHERS_OFFSET       EQU   0x900
APLL_LOCK_OFFSET    EQU   0x00
MPLL_LOCK_OFFSET    EQU   0x04
EPLL_LOCK_OFFSET    EQU   0x08
CLK_DIV2_OFFSET     EQU   0x28
CLK_DIV0_OFFSET     EQU   0x20
Startup_PCLKdiv     EQU   3
Startup_HCLKx2div   EQU   1
Startup_HCLKdiv     EQU   1
Startup_MPLLdiv     EQU   1
Startup_APLLdiv     EQU   1
CLK_DIV_VAL         EQU   ((Startup_PCLKdiv<<12)|(Startup_HCLKx2div<<9)|(Startup_HCLKdiv<<8)|(Startup_MPLLdiv<<4)|Startup_APLLdiv)
APLL_MDIV           EQU   266
APLL_PDIV           EQU   3
APLL_SDIV           EQU   1
APLL_VAL            EQU   ((1<<31 | APLL_MDIV<<16 | APLL_PDIV<<8 | APLL_SDIV))
APLL_CON_OFFSET     EQU   0x0c
MPLL_CON_OFFSET     EQU   0x10
EPLL_CON0_OFFSET    EQU   0x14
EPLL_CON1_OFFSET    EQU   0x18
CLK_SRC_OFFSET      EQU   0x1c
MPLL_MDIV           EQU   266
MPLL_PDIV           EQU   3
MPLL_SDIV           EQU   1
MPLL_VAL            EQU   ((1<<31 | MPLL_MDIV<<16 | MPLL_PDIV<<8 | MPLL_SDIV))
clk_init
    ldr r0, =ELFIN_CLOCK_POWER_BASE ;0x7e00f000
     ldr r1, [r0, #OTHERS_OFFSET]
     mov r2, #0x40
     orr r1, r1, r2
     str r1, [r0, #OTHERS_OFFSET]
     nop
     nop
     nop
     nop
     nop
     ldr r2, =0x80
     orr r1, r1, r2
check_syncack
     ldr r2, =0xf00
     and r1, r1, r2
     cmp r1, #0xf00
     bne check_syncack
     mov r1, #0xff00
     orr r1, r1, #0xff
     str r1, [r0, #APLL_LOCK_OFFSET]
     str r1, [r0, #MPLL_LOCK_OFFSET]
     str r1, [r0, #EPLL_LOCK_OFFSET]
     ldr    r1, [r0, #CLK_DIV2_OFFSET]
     bic r1, r1, #0x70000
     orr r1, r1, #0x30000
     str r1, [r0, #CLK_DIV2_OFFSET]
     ldr    r1, [r0, #CLK_DIV0_OFFSET] ;Set Clock Divider
     bic r1, r1, #0x30000
     bic r1, r1, #0xff00
     bic r1, r1, #0xff
     ldr r2, =CLK_DIV_VAL
     orr r1, r1, r2
     str r1, [r0, #CLK_DIV0_OFFSET]
     ldr r1, =APLL_VAL
     str r1, [r0, #APLL_CON_OFFSET]
     ldr r1, =MPLL_VAL
     str r1, [r0, #MPLL_CON_OFFSET]
     ldr r1, =0x80200203   ;FOUT of EPLL is 96MHz
     str r1, [r0, #EPLL_CON0_OFFSET]
     ldr r1, =0x0
     str r1, [r0, #EPLL_CON1_OFFSET]
     ldr r1, [r0, #CLK_SRC_OFFSET] ;APLL, MPLL, EPLL select to Fout
     ldr r2, =0x2007
     orr r1, r1, r2
     str r1, [r0, #CLK_SRC_OFFSET]
     ;wait at least 200us to stablize all clock
     mov r1, #0x10000
    subs r1, r1, #1
     bne %B1
     ;Synchronization for VIC port
     orr r1, r1, #0x20
     mov pc,lr
    END
main.c
//#include <uboot.h>
#include <printf.h>
#define rGPMCON (*(volatile unsigned *)(0x7F008820))
#define rGPMDAT (*(volatile unsigned *)(0x7F008824))
#define rGPMPUD (*(volatile unsigned *)(0x7F008828))
struct four_results
        int a;
        int b;
        int c;
        int d;
__swi(0) int multiply_two(int, int);
__swi(1) int add_two(int, int);
__swi(2) int add_multiply_two(int, int, int, int);
__swi(3) __value_in_regs struct four_results     many_operations(int, int, int, int);
void msDelay(int time)
        volatile unsigned int i,j;
        for(i = 0; i < 200000; i++)
                for(j=0; j<time; j++);
void GPIO_Init(void)
        rGPMCON = 0x11111;
        rGPMPUD = 0x00;
        rGPMDAT = 0X1F;
void LedTest(void)
        volatile unsigned int i;
        unsigned char count=0;
        while (1)
                for(i=0; i<4; i++)
                        rGPMDAT = ~(1<<i);
                        msDelay(10);
                count++;
                if(count>3)
                return;
unsigned Install_Handler( unsigned routine, unsigned *vector )
        unsigned vec, old_vec;
        vec = (routine - (unsigned)vector - 8) >> 2;
        if (vec & 0xff000000)
                printf("Handler greater than 32MBytes from vector");
        vec = 0xea000000 | vec;    /**//* OR in 'branch always' code */
        old_vec = *vector;
        *vector = vec;
        return (old_vec);
unsigned *swi_vec = (unsigned *)0x08;
extern void SWI_Handler(void);
void C_SWI_Handler( int swi_num, int *regs )
        switch( swi_num )
                case    0:
                regs[0] = regs[0] * regs[1];       break;
                case    1:
                regs[0] = regs[0] + regs[1];       break;
                case    2:
                regs[0] = (regs[0] * regs[1]) + (regs[2] * regs[3]);       break;
                case    3:
                        int w, x, y, z;
                        w = regs[0];
                        x = regs[1];
                        y = regs[2];
                        z = regs[3];
                        regs[0] = w + x + y + z;
                        regs[1] = w - x - y - z;
                        regs[2] = w * x * y * z;
                        regs[3] =(w + x) * (y - z);
                break;
void Main(void)
/*        int result1, result2;
        struct four_results res_3;
        Install_Handler( (unsigned) SWI_Handler, swi_vec );
        printf("result1 = multiply_two( 2, 4 ) = %d ", result1 = multiply_two( 2, 4 ));
        printf("result2 = multiply_two( 3, 6 ) = %d ", result2 = multiply_two( 3, 6 ));
        printf("add_two( result1, result2 ) = %d ", add_two( result1, result2 ));
        printf("add_multiply_two( 2, 4, 3, 6 ) = %d ", add_multiply_two( 2, 4, 3, 6 ));
        res_3 = many_operations( 12, 4, 3, 1 );
        printf("res_3.a = %d ", res_3.a );
        printf("res_3.b = %d ", res_3.b );
        printf("res_3.c = %d ", res_3.c );
        printf("res_3.d = %d ", res_3.d );
        GPIO_Init();
        printf("hello world\n");
        LedTest();*/
        __asm("swi 0");
开发环境本来是arm-linux-gcc的,后来linux下不好调试,转到了RVDS 2.2,**费了好大的劲,请大家指点……
 楼主| nickyhzp 发表于 2013-7-4 15:35 | 显示全部楼层
执行swi之后,总是进入Abort_Handler这个模式,uboot那里是以前在linux上用的,转移到RVDS 2.2后,代码没清理,一直保留了
幻影长矛手 发表于 2013-7-4 15:40 | 显示全部楼层
这么专业的问题问问飞凌的技术服务比较好。
 楼主| nickyhzp 发表于 2013-7-5 08:31 | 显示全部楼层
飞凌迟迟不给回复,总感觉他们好像把板子卖出去后就事不关己似的
and 发表于 2013-7-5 10:09 | 显示全部楼层
这一句的LDR,是不是应该改用 BL或者BLX 什么的?
 楼主| nickyhzp 发表于 2013-7-8 09:49 | 显示全部楼层
这一句的LDR,是不是应该改用 BL或者BLX 什 ...
bl跳转指令有空间限制,ldr也可以跳转,并且没有空间限制!现在的问题是执行 swi之后,根本就没进入swi中断向量中,直接进入的数据预取错误里面
群龙舞十方 发表于 2013-7-10 09:01 | 显示全部楼层
去飞凌技术论坛上问问,让他们给段可运行的代码先试试。
