STM32 PC6 PWM
2092|6
cym_anhui|  楼主 | 2013-7-8 11:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用PC6产生PWM,没有输出?
//    memset(&GPIO_InitStructure, 0, sizeof(GPIO_InitTypeDef));
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC,ENABLE);
                GPIO_InitStructure.GPIO_Pin = GPIO_WARM_PIN;      //PORTC.6
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIO_WARM_PORT, &GPIO_InitStructure);                 //PORTC
          GPIO_PinRemapConfig(GPIO_FullRemap_TIM3,ENABLE);
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef                   TIM_OCInitStructure;
        TIM_DeInit(TIM3);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 700;//CCR2Value;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM3,&TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
  TIM_OCInitStructure.TIM_Pulse = 900;//CR2_Val;
  TIM_OC2Init(TIM3,&TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = 1000;//CCR3_Val;
  TIM_OC3Init(TIM3,&TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = 1200;//CCR4_Val;
  TIM_OC4Init(TIM3,&TIM_OCInitStructure);
  /* TIM3 counter enable */
  TIM_ARRPreloadConfig(TIM3,ENABLE);
  /* TIM3 Main Output Enable */
  TIM_CtrlPWMOutputs(TIM3,ENABLE);
  TIM_Cmd(TIM3,ENABLE);
cym_anhui|  楼主 | 2013-7-8 11:32 | 只看该作者
各位大侠看看怎么没有输出啊
logokfu| | 2013-7-8 12:00 | 只看该作者
看了半天我也没看出来
airwill| | 2013-7-9 13:41 | 只看该作者
好象没有什么问题, 借助调试器, 进去看看 TIM3 的寄存器设置吧
trumpxp| | 2013-7-9 18:32 | 只看该作者
仔细单步调试   应该问题不大   楼主
cym_anhui|  楼主 | 2013-7-11 14:57 | 只看该作者
不行,我换了一个IO,实现了,不知道remap为什么不行
xiazhienen| | 2013-9-16 00:17 | 只看该作者
因为在读写AFIO-MAPR前应该在APB2ENR中使能AFEN位。RCC->APB2ENR|1<<0;
