用ISE出现了个警告,请哪位师兄指点下
4537|2
 楼主| 弄月书生 发表于 2007-5-10 08:55 | 显示全部楼层 |阅读模式
se, ni, COM, fm, hd
WARNING:Xst:2170&nbsp;-&nbsp;Unit&nbsp;MAOLO&nbsp;:&nbsp;the&nbsp;following&nbsp;signal(s)&nbsp;form&nbsp;a&nbsp;combinatorial&nbsp;loop:&nbsp;FMO,&nbsp;OHX4,&nbsp;OHX3.<br /><br />不知道这个警告是什么意思,更不知道怎么排除.用VHDL写的程序.
 楼主| 弄月书生 发表于 2007-5-10 09:23 | 显示全部楼层
知道意思了
我的逻辑输出反馈到了逻辑的输入,输入输出相互影响
 楼主| 弄月书生 发表于 2007-5-10 09:26 | 显示全部楼层
不过还有个警告概念比较模糊
INFO:Xst:2261&nbsp;-&nbsp;The&nbsp;FF/Latch&nbsp;&ltRSFR0/odat_0&gt&nbsp;in&nbsp;Unit&nbsp;&ltMAOLO&gt&nbsp;is&nbsp;equivalent&nbsp;to&nbsp;the&nbsp;following&nbsp;FF/Latch,&nbsp;which&nbsp;will&nbsp;be&nbsp;removed&nbsp;:&nbsp;&ltRSFR0/odat_4&gt&nbsp;<br />INFO:Xst:2261&nbsp;-&nbsp;The&nbsp;FF/Latch&nbsp;&ltRSFR8/odat_3&gt&nbsp;in&nbsp;Unit&nbsp;&ltMAOLO&gt&nbsp;is&nbsp;equivalent&nbsp;to&nbsp;the&nbsp;following&nbsp;FF/Latch,&nbsp;which&nbsp;will&nbsp;be&nbsp;removed&nbsp;:&nbsp;&ltRSFR6/odat_1&gt&nbsp;<br />INFO:Xst:2261&nbsp;-&nbsp;The&nbsp;FF/Latch&nbsp;&ltRSFR9/odat_2&gt&nbsp;in&nbsp;Unit&nbsp;&ltMAOLO&gt&nbsp;is&nbsp;equivalent&nbsp;to&nbsp;the&nbsp;following&nbsp;13&nbsp;FFs/Latches,&nbsp;which&nbsp;will&nbsp;be&nbsp;removed&nbsp;:&nbsp;&ltRSFR9/odat_3&gt&nbsp;&ltRSFR9/odat_4&gt&nbsp;&ltRSFR9/odat_5&gt&nbsp;&ltRSFR9/odat_6&gt&nbsp;&ltRSFR7/odat_3&gt&nbsp;&ltRSFR7/odat_4&gt&nbsp;&ltRSFR7/odat_5&gt&nbsp;&ltRSFR7/odat_6&gt&nbsp;&ltRSFR7/odat_7&gt&nbsp;&ltRSFR5/odat_7&gt&nbsp;&ltRSFR3/odat_5&gt&nbsp;&ltRSFR3/odat_6&gt&nbsp;&ltRSFR3/odat_7&gt&nbsp;<br />WARNING:Xst:1426&nbsp;-&nbsp;The&nbsp;value&nbsp;init&nbsp;of&nbsp;the&nbsp;FF/Latch&nbsp;RSFR9/odat_2&nbsp;hinder&nbsp;the&nbsp;constant&nbsp;cleaning&nbsp;in&nbsp;the&nbsp;block&nbsp;MAOLO.<br />&nbsp;&nbsp;&nbsp;You&nbsp;should&nbsp;achieve&nbsp;better&nbsp;results&nbsp;by&nbsp;setting&nbsp;this&nbsp;init&nbsp;to&nbsp;1.<br />请大家提点下.
