USART2无法调通,求助
6883|28
 楼主| 40750209 发表于 2013-8-5 16:12 | 显示全部楼层 |阅读模式
USART2无法调通,配置串口2的程序如下所示,看有没有问题,求大神指点。
usart.c文件:
#include "usart1.h"
#include <stdarg.h>
void USART1_Config(void)
        USART_InitTypeDef USART_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        /* USART2 mode config */
        USART_InitStructure.USART_BaudRate = 9600;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART2, &USART_InitStructure);
        USART_Cmd(USART2, ENABLE);
int fputc(int ch, FILE *f)
        /* 将Printf内容发往串口 */
        USART_SendData(USART2, (unsigned char) ch);
        while( USART_GetFlagStatus(USART2,USART_FLAG_TC)!= SET);
        return (ch);
static char *itoa(int value, char *string, int radix)
        int     i, d;
        int     flag = 0;
        char    *ptr = string;
        /* This implementation only works for decimal numbers. */
        if (radix != 10)
            *ptr = 0;
            return string;
        if (!value)
            *ptr++ = 0x30;
            *ptr = 0;
            return string;
        /* if this is a negative value insert the minus sign. */
        if (value < 0)
            *ptr++ = '-';
            /* Make the value positive. */
            value *= -1;
        for (i = 10000; i > 0; i /= 10)
            d = value / i;
            if (d || flag)
                *ptr++ = (char)(d + 0x30);
                value -= (d * i);
                flag = 1;
        /* Null terminate the string. */
        *ptr = 0;
        return string;
} /* NCL_Itoa */
void USART1_printf(USART_TypeDef* USARTx, uint8_t *Data,...)
        const char *s;
        int d;
        char buf[16];
        va_list ap;
        va_start(ap, Data);
        while ( *Data != 0)     // 判断是否到达字符串结束符
                if ( *Data == 0x5c )  //'\'
        switch ( *++Data )
                case 'r':        //回车符
                        USART_SendData(USARTx, 0x0d);
                        Data ++;
                break;
                case 'n':        //换行符
                        USART_SendData(USARTx, 0x0a);
                        Data ++;
                break;
                default:
                        Data ++;
                break;
        else if ( *Data == '%')
        switch ( *++Data )
                case 's':        //字符串
                        s = va_arg(ap, const char *);
        for ( ; *s; s++)
                USART_SendData(USARTx,*s);
                while( USART_GetFlagStatus(USARTx, USART_FLAG_TC) == RESET );
                Data++;
                break;
        case 'd':        //十进制
        d = va_arg(ap, int);
        itoa(d, buf, 10);
        for (s = buf; *s; s++)
        Data++;
        break;
                 default:
                                Data++;
                    break;
        } /* end of else if */
        else USART_SendData(USARTx, *Data++);
/******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
Main.c文件:
#include "stm32f10x.h"
#include "usart1.h"
int main(void)
        USART1_Config();
        printf("\r\n this is a printf demo \r\n");
        printf("\r\n 欢迎使用 \r\n");
        USART1_printf(USART2, "\r\n This is a USART1_printf demo \r\n");
        USART1_printf(USART2, "\r\n ("__DATE__ " - " __TIME__ ") \r\n");
        for(;;)
 楼主| 40750209 发表于 2013-8-5 16:17 | 显示全部楼层
printf到usart2
        /* 将Printf内容发往串口 */
//        while (!(USART1->SR & USART_FLAG_TXE));
        return (ch);
 楼主| 40750209 发表于 2013-8-5 16:19 | 显示全部楼层
使用的是STM32F103V
499734424 发表于 2013-8-5 16:38 | 显示全部楼层
wll_2012 发表于 2013-8-5 17:09 | 显示全部楼层
无法调通?遇到的问题、现象是什么呢?
万年龟 发表于 2013-8-5 18:07 | 显示全部楼层
是不是没有开启AFIO时钟呢?
cjhk 发表于 2013-8-5 18:57 | 显示全部楼层
有这个可能   楼主
菜鸟宅男 发表于 2013-8-5 19:22 | 显示全部楼层
没有remap也需要开启AFIO时钟吗?
wangyueming 发表于 2013-8-5 20:35 | 显示全部楼层
4楼正解!
 楼主| 40750209 发表于 2013-8-6 08:50 | 显示全部楼层
无法调通?遇到的问题、现象是什么呢?
我的程序输出打印字符串到PC上,用串口1可以调通,修改程序中的参数,换串口2就不行,想请教一下,哪里没配置好,还是怎么回事
 楼主| 40750209 发表于 2013-8-6 08:52 | 显示全部楼层
四楼大神什么意思?没看明白?
499734424 发表于 2013-8-6 09:07 | 显示全部楼层
都标红了
你用的是串口2
而不是1
 楼主| 40750209 发表于 2013-8-6 09:12 | 显示全部楼层
都标红了
你用的是串口2
而不是1
这句话不是被我注释掉了吗,有影响吗?
499734424 发表于 2013-8-6 09:25 | 显示全部楼层
这句话不是被我注释掉了吗,有影响吗?
我没看到注释,以为是你用串口2,却在等待串口1标志
wll_2012 发表于 2013-8-6 09:26 | 显示全部楼层
我的程序输出打印字符串到PC上,用串口1可以调通,修改程序中的参数,换串口2就不行,想请教一下,哪里没 ...
499734424 发表于 2013-8-6 09:47 | 显示全部楼层
这次仔细看了一下
输出用的是复用输出GPIO_Mode_AF_PP
应该需要开启复用时钟,LZ你试试看行不行
其他我也没发现什么问题
 楼主| 40750209 发表于 2013-8-6 09:57 | 显示全部楼层
这次仔细看了一下
我试了15楼的知道,加上开启复用时钟,还是没有效果,谢谢你啊
语句是这个:
499734424 发表于 2013-8-6 10:03 | 显示全部楼层
那问题可能不是在配置问题上,楼主,方便的话上工程,让大家全局的看看
 楼主| 40750209 发表于 2013-8-6 10:37 | 显示全部楼层
main文件和usart文件已经发上来了,求帮忙看看
499734424 发表于 2013-8-6 10:52 | 显示全部楼层
main怎么没有看到
配置系统时钟
