stm32f4 adc dma中断传送方式 问题
3836|1
 楼主| fxk416532131 发表于 2013-8-13 01:53 | 显示全部楼层 |阅读模式
void ADC_CH11_DMA_Config()     //pc1
                ADC_InitTypeDef  ADC_InitStructure;
                ADC_CommonInitTypeDef ADC_CommonInitStructure;
                DMA_InitTypeDef DMA_InitStructure;
                RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
                RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 | RCC_APB2Periph_ADC3,ENABLE);
                GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
                GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
                GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
                GPIO_Init(GPIOC,&GPIO_InitStructure);
                DMA_InitStructure.DMA_Channel = DMA_Channel_0;
                DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC_CDR_ADDRESS;
                DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)(&ADC_Converted_Value);
                DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
                DMA_InitStructure.DMA_BufferSize = 10;
                DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
                DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
                DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
                DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
                DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
                DMA_InitStructure.DMA_Priority = DMA_Priority_High;
                DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
                DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
                DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
                DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
                DMA_Init(DMA2_Stream0, &DMA_InitStructure);
                DMA_ITConfig(DMA2_Stream0,DMA_IT_TC,ENABLE);              //DMA enable
                DMA_Cmd(DMA2_Stream0, ENABLE);
                ADC_CommonInitStructure.ADC_Mode = ADC_TripleMode_Interl;
                ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
                ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
                ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
                ADC_CommonInit(&ADC_CommonInitStructure);
                ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
                ADC_InitStructure.ADC_ScanConvMode = DISABLE;
                ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
                ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
                ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
                ADC_InitStructure.ADC_NbrOfConversion = 1;
                ADC_Init(ADC1, &ADC_InitStructure);
                ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
                ADC_Init(ADC2, &ADC_InitStructure);
                ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
                ADC_Init(ADC3, &ADC_InitStructure);
                ADC_RegularChannelConfig(ADC3, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
          /* Enable DMA request after last transfer (Single-ADC mode) */
                ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
                /* Enable ADC1 DMA */
                ADC_DMACmd(ADC1, ENABLE);
                /* Enable ADC1 */
                ADC_Cmd(ADC1, ENABLE);
                ADC_Cmd(ADC2, ENABLE);
                ADC_Cmd(ADC3, ENABLE);
                ADC_SoftwareStartConv(ADC1);
这是我的配置,adc配置的是TripleMode_Intereaved,连续采集模式, dma访问方式是mode1,传送完成中断使能,为什么只能进一次中断啊,之后就进不去了? 刚接触不久,不知道有没有 写错的地方。
li_yuling2 发表于 2013-9-16 11:01 | 显示全部楼层
需要使用 ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
