两个压力检测通道怎样求差好?
2016|3
 楼主| andyany 发表于 2013-8-14 12:59 | 显示全部楼层 |阅读模式
两个通道共地。
用示波器探头的正负极分别接两个通道的正极,噪声振幅为1V。
分别用两个探头把两路压力信号接入示波器,然后相减,所得信号噪声振幅为0.2V。
都这样吗?为什么?
谢谢!
mcudyd 发表于 2013-8-16 14:44 | 显示全部楼层
用两个探头分别测量两通道,然后相减就行吧,很多示波器都支持这功能的
 楼主| andyany 发表于 2013-8-17 12:18 | 显示全部楼层
I did before you said, and told at the 1st floor.
You are so funny.
mcudyd 发表于 2013-8-17 17:25 | 显示全部楼层
You are so funny.
Although you have known that it was ok why you asked it? I gave you confirmation and agreement but the other guys did not gave you any ideas, so you are funny too.
