2812的为啥倍频不起作用
1517|4
 楼主| G21372 发表于 2013-8-25 23:06 | 显示全部楼层 |阅读模式
2812采用30MHz晶振,5倍频,时钟应是150M,但实际上倍频没有作用,时钟还是30M,请问可能的原因在哪儿。还有就是DSP2812的140脚XF_PLL的引脚应该怎么接
yangguangaisha 发表于 2013-8-25 23:14 | 显示全部楼层
倍频要在程序里倍啊。。
// This function initializes the PLLCR register.
void Init_Pll(UINT val)
   volatile Uint16 iVol;
   PllVal = (val/2);
   if (*SYSCTRL_REG_PLLCR != val)
      EALLOW;
      *SYSCTRL_REG_PLLCR = val;
      EDIS;
   // Optional: Wait for PLL to lock.
   // During this time the CPU will switch to OSCCLK/2 until the PLL is
   // stable.  Once the PLL is stable the CPU will switch to the new PLL value.
   // This switch time is 131072 CLKIN cycles as of Rev C silicon.
   // Code is not required to sit and wait for the PLL to lock.
   // However, if the code does anything that is timing critical,
   // and requires the correct clock be locked, then it is best to
   // wait until this switching has completed.
   // If this function is run from waitstated memory, then the loop count can
   // be reduced as long as the minimum switch time is still met.
   // iVol is volatile so the compiler will not optimize this loop out
   // The watchdog should be disabled before this loop, or fed within
   // the loop.
      DisableDog();
   // Wait lock cycles.
   // Note,  This loop is tuned to 0-waitstate RAM memory.  If this
   // function is run from wait-stated memory such as Flash or XINTF,
   // then the number of times through the loop can be reduced
   // accordingly.
      for(iVol= 0; iVol< ( (131072/2)/12 ); iVol++)
zhangmangui 发表于 2013-8-26 19:06 | 显示全部楼层
2812有个使能PLL的引脚   不知道你是否将此引脚连接合理
嗯 就是140引脚   应该是拉高   记得不太清楚了
你可以查查
tianli1980 发表于 2013-8-28 18:20 | 显示全部楼层
初步怀疑是没有看门狗时,DSP对PLL管脚采样不正常引起的
smilingangel 发表于 2013-8-29 00:27 | 显示全部楼层
跟楼上两位的先学习了解下的,很不错的介绍的讨论的
