NVIC_SetPriorityGrouping 与NVIC_PriorityGroupConfig函数的区别
14329|7
 楼主| lanseshuijing 发表于 2013-9-10 17:54 | 显示全部楼层 |阅读模式
所用单片机 arm m4
其中一个函数NVIC_SetPriorityGrouping 中断优先级分组分为8组 此函数在core_cm4.h文件中代码如下
Set Priority Grouping
  This function sets the priority grouping field using the required unlock sequence.
  The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field.
  Only values from 0..7 are used.
  In case of a conflict between priority grouping and available
  priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
    \param [in]      PriorityGroup  Priority grouping field
static __INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
  uint32_t reg_value;
  uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07);               /* only values 0..7 are used          */
  reg_value  =  SCB->AIRCR;                                                   /* read old register configuration    */
  reg_value &= ~(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk);             /* clear bits to change               */
  reg_value  =  (reg_value                                 |
                ((uint32_t)0x5FA << SCB_AIRCR_VECTKEY_Pos) |
                (PriorityGroupTmp << 8));                                     /* Insert write key and priorty group */
  SCB->AIRCR =  reg_value;
另外一个函数NVIC_PriorityGroupConfig分组分成5组 在 misc.c文件中
代码如下
@brief  Configures the priority grouping: pre-emption priority and subpriority.
  * @param  NVIC_PriorityGroup: specifies the priority grouping bits length.
  *   This parameter can be one of the following values:
  *     @arg NVIC_PriorityGroup_0: 0 bits for pre-emption priority
  *                                4 bits for subpriority
  *     @arg NVIC_PriorityGroup_1: 1 bits for pre-emption priority
  *                                3 bits for subpriority
  *     @arg NVIC_PriorityGroup_2: 2 bits for pre-emption priority
  *                                2 bits for subpriority
  *     @arg NVIC_PriorityGroup_3: 3 bits for pre-emption priority
  *                                1 bits for subpriority
  *     @arg NVIC_PriorityGroup_4: 4 bits for pre-emption priority
  *                                0 bits for subpriority
  * @NOTE   When the NVIC_PriorityGroup_0 is selected, IRQ pre-emption is no more possible.
  *         The pending IRQ priority will be managed only by the subpriority.
  * @retval None
void NVIC_PriorityGroupConfig(uint32_t NVIC_PriorityGroup)
  /* Check the parameters */
  assert_param(IS_NVIC_PRIORITY_GROUP(NVIC_PriorityGroup));
/* Set the PRIGROUP[10:8] bits according to NVIC_PriorityGroup value */
  SCB->AIRCR = AIRCR_VECTKEY_MASK | NVIC_PriorityGroup;
为什么有这么两组分组方式?同样都是对SCB->AIRCR 操作啊?谁能帮忙解释一下
hkcj 发表于 2013-9-10 18:36 | 显示全部楼层
不是很了解  帮你顶一个  呼唤一下香主吧
wnwnwn 发表于 2013-12-4 10:34 | 显示全部楼层
In case of a conflict between priority grouping and available priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
我觉得这句话说明了两个函数的区别,NVIC_SetPriorityGrouping()的参数可以是0..7,但是函数会根据芯片本身的“可用优先级位”来进行设置,例如只支持0..4个分组,如果设置为5.6.7的话,就会设置成0组。不知道我的理解对不对。。
feilusia 发表于 2013-12-4 11:07 | 显示全部楼层
那是因为 M3内核允许8bit做优先级分组设置,而STM32只有4bit可以设置。
wnwnwn 发表于 2013-12-4 12:22 | 显示全部楼层
受教了!:handshake
zook0k 发表于 2014-10-24 10:41 | 显示全部楼层
喆3喆 发表于 2015-10-16 20:37 | 显示全部楼层
xuanhuanzi 发表于 2020-4-19 23:20 | 显示全部楼层
对这个不懂。
