请教香主、各位同道一个SPI通信的问题(急切)
4198|33
 楼主| angryBird 发表于 2013-10-6 21:11 | 显示全部楼层 |阅读模式
我用一块F207的开发板做master,自己做的板子(F205)做slave,两机通过SPI通信。主机使用GPIOI的pin1、2、3,分别连接从机的GPIOB的pin13、14、15,也就是CLK-CLK,MISO-MISO,MOSI-MOSI。主机发送数据,从机可以正常收到。如果从机收到数据后,也发送数据,则两边收到的数据都不对了。比如,主机连续发送50个0xff,从机在这期间发送0xa0,主机收到都是0x83,0x0b等,从机收到的0xff变成了0x0b等。
接收使用中断方式,发送没有使用中断。
SPI初始化的代码如下,主从基本一样,只是一个是master,一个是slave
static void InitSPI(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  SPI_InitTypeDef  SPI_InitStructure;
  /* Enable the SPI clock */
  SPIx_CLK_INIT(SPIx_CLK, ENABLE);
  /* Enable GPIO clocks */
  RCC_AHB1PeriphClockCmd(SPIx_GPIO_CLK, ENABLE);
  //RCC_AHB1PeriphClockCmd(SPIx_SCK_GPIO_CLK | SPIx_MISO_GPIO_CLK | SPIx_MOSI_GPIO_CLK, ENABLE);
  /* Connect PC10 to SPI3_SCK */
  GPIO_PinAFConfig(SPIx_GPIO_PORT, SPIx_SCK_SOURCE, SPIx_SCK_AF);
  /* Connect PC11 to SPI1_MOSI */
  GPIO_PinAFConfig(SPIx_GPIO_PORT, SPIx_MISO_SOURCE, SPIx_MISO_AF);
  /* Connect PC12 to SPI1_MISO */
  GPIO_PinAFConfig(SPIx_GPIO_PORT, SPIx_MOSI_SOURCE, SPIx_MOSI_AF);
  /* Configure SPI1 pins as alternate function
  * (No need to configure PA4 since NSS will be
  * managed by software) */
  GPIO_InitStructure.GPIO_Pin = SPIx_SCK_PIN | SPIx_MISO_PIN | SPIx_MOSI_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;  //GPIO_PuPd_UP
  GPIO_Init(SPIx_GPIO_PORT, &GPIO_InitStructure);
   /* SPI configuration */
  SPI_I2S_DeInit(SPIx);
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;   // SPI_CPOL_High?
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;  //把数据锁定在第一个波形.才不会漏掉最高位 //SPI_CPHA_2Edge ?
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;  // SPI_BaudRatePrescaler_256 ?
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;  //高位在前
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPIx, &SPI_InitStructure);
  /* Configure the Priority Group to 1 bit */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  //Configure the SPI interrupt priority
  NVIC_InitStructure.NVIC_IRQChannel = SPIx_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;  // 2 ???
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable the Rx buffer not empty interrupt */
  SPI_I2S_ITConfig(SPIx, SPI_I2S_IT_RXNE, ENABLE);
  /* Enable the SPI peripheral */
  SPI_Cmd(SPIx, ENABLE);
中断接收函数
void SPIx_IRQHANDLER(void)
  uint8_t n;
  /* SPI in Slave Receiver mode--------------------------------------- */
  if (SPI_I2S_GetITStatus(SPIx, SPI_I2S_IT_RXNE) == SET)
    RxBuffer[Rx_Idx++] = SPI_I2S_ReceiveData(SPIx);
    if(Rx_Idx==BUFFERSIZE)Rx_Idx=0;
slave端在主循环中发送 SpiSendByte(0xa0); 函数如下:
uint8_t SpiSendByte(uint8_t ch)
  while(SPI_I2S_GetFlagStatus(SPIx, SPI_I2S_FLAG_TXE) == RESET);
  SPI_I2S_SendData(SPIx, ch);
  for(int i=0;i<1000;i++){}
  //while (SPI_I2S_GetFlagStatus(SPIx, SPI_I2S_FLAG_RXNE) == RESET){}
  return SPI_I2S_ReceiveData(SPIx);
调试时,先启动从机,从机会在 while(SPI_I2S_GetFlagStatus(SPIx, SPI_I2S_FLAG_TXE) == RESET);停留,等待主机发送时钟过来。
然后启动主机,主机在主循环中发送50个0xff。结果,主机收到50个数据,从机也收到50个数据。但是,不幸地是,数据都是错的。泪奔啊。
请教香主,以及各位同道,这是咋回事???
谢谢
 楼主| angryBird 发表于 2013-10-6 21:12 | 显示全部楼层
spi相关定义:
#define SPIx_GPIO_PORT                 GPIOB  //me
#define SPIx_GPIO_CLK                  RCC_AHB1Periph_GPIOB  //me
#define SPIx                           SPI2
#define SPIx_CLK                       RCC_APB1Periph_SPI2
#define SPIx_CLK_INIT                  RCC_APB1PeriphClockCmd
#define SPIx_IRQn                      SPI2_IRQn
#define SPIx_IRQHANDLER                SPI2_IRQHandler
#define SPIx_SCK_PIN                   GPIO_Pin_13
#define SPIx_SCK_GPIO_PORT             GPIOB
#define SPIx_SCK_GPIO_CLK              RCC_AHB1Periph_GPIOB
#define SPIx_SCK_SOURCE                GPIO_PinSource13
#define SPIx_SCK_AF                    GPIO_AF_SPI2
#define SPIx_MISO_PIN                  GPIO_Pin_14
#define SPIx_MISO_GPIO_PORT            GPIOB
#define SPIx_MISO_GPIO_CLK             RCC_AHB1Periph_GPIOB
#define SPIx_MISO_SOURCE               GPIO_PinSource14
#define SPIx_MISO_AF                   GPIO_AF_SPI2
#define SPIx_MOSI_PIN                  GPIO_Pin_15
#define SPIx_MOSI_GPIO_PORT            GPIOB
#define SPIx_MOSI_GPIO_CLK             RCC_AHB1Periph_GPIOB
#define SPIx_MOSI_SOURCE               GPIO_PinSource15
#define SPIx_MOSI_AF                   GPIO_AF_SPI2
feilusia 发表于 2013-10-6 21:25 | 显示全部楼层
你说的“如果从机收到数据后,也发送数据”是什么意思?
从机不能主动发送数据,只能主机发送数据的同时发送数据。
 楼主| angryBird 发表于 2013-10-6 21:31 | 显示全部楼层
从机不能主动发送数据,只能主机发送数据的同时发 ...
主机开始循环发送50个数据,从机收到第一个后,也开始发送数据。按理说,从机发送的第一个数据,主机在发送第二个数据或者后面某一个数据时,会收到从机发送的这个数据。
feilusia 发表于 2013-10-6 21:34 | 显示全部楼层
主机开始循环发送50个数据,从机收到第一个后,也开始发送数据。按理说,从机发送的第一个数据,主机在发 ...
应该是你主机发送速度过快了,主机是否有等到接收到数据才继续发送?
 楼主| angryBird 发表于 2013-10-6 21:39 | 显示全部楼层
主机每发送一个数据(0xff),就会中断收到一个数据啊。如果从机只收不发,主机收到的是0xff。
我现在调试一下试试看
 楼主| angryBird 发表于 2013-10-6 21:43 | 显示全部楼层
试了,不行。主机主循环代码:
while (1)
    if(loop>=500)continue;
    if(first==1){
      first = 0;
      SpiMasterSendByte(0xff);
    if(Rx_Idx>0){
      LCD_UsrLog("master get data---\n");
      if(RxBuffer[Rx_Idx-1]!=0xff)SpiMasterSendByte(0xff);
 楼主| angryBird 发表于 2013-10-6 21:51 | 显示全部楼层
master.JPG 以上是主机收到的数据,应该是0xa0就对了
slave.JPG 这儿是从机收到的数据,应该是0xff就对了
feilusia 发表于 2013-10-6 22:05 | 显示全部楼层
你从机都知道用while去判断,主机为什么不用while去判断有没有收到数据呢。网上不是有很多收发一体的函数吗,去搜来看看吧。
 楼主| angryBird 发表于 2013-10-6 22:08 | 显示全部楼层
你从机都知道用while去判断,主机为什么不用while去判断有没有收到数据呢。网上不是有很多收发一体的函数吗 ...
用了
 楼主| angryBird 发表于 2013-10-6 22:10 | 显示全部楼层
无论怎么用数据都是乱的
 楼主| angryBird 发表于 2013-10-6 22:17 | 显示全部楼层
只要从机不发数据,收到的都对,无论从收到第几个数据发送,两边都乱套
 楼主| angryBird 发表于 2013-10-6 23:02 | 显示全部楼层
void SPI_I2S_SendData(SPI_TypeDef* SPIx, uint16_t Data)
  /* Check the parameters */
  assert_param(IS_SPI_ALL_PERIPH(SPIx));
  /* Write in the DR register the data to be sent */
  SPIx->DR = Data;
收到数据0xff后,寄存器  SPIx->DR 的值是0xff,但是在发送0xa0,执行完上述函数后,SPIx->DR 的值还是0xff,为什么不是0xa0 ???
qditer 发表于 2013-10-6 23:17 | 显示全部楼层
看看这个
  1. static uint8_t SPI1_SendByte(uint8_t byte)
  3.         SPI_I2S_ReceiveData(SPI1);
  4.         SPI_I2S_SendData(SPI1, byte);
  5.         while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
  6.         while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
  7.         return SPI_I2S_ReceiveData(SPI1);
  8. }
290399937 发表于 2013-10-7 08:46 来自手机 | 显示全部楼层
发送的时候!同时应该也是接收的 发一个位 收一个位!一位一位!主从机2个寄存器数据互换
hkcj 发表于 2013-10-7 10:23 | 显示全部楼层
呼唤香主   这一块   懂得不多
easy_tm 发表于 2013-10-7 13:52 | 显示全部楼层
16楼正解!根据你的代码架构,你的从机发送数据的代码是在while loop中的,显然不行。建议你可以先测试在从机的中断服务函数里面接收并发送数据
 楼主| angryBird 发表于 2013-10-7 20:05 | 显示全部楼层
16楼正解!根据你的代码架构,你的从机发送数据的代码是在while loop中的,显然不行。建议你可以先测试在从 ...
这个办法昨晚也试过了,在接收中断函数里面,没收到一个字节,发送一个字节。还是乱码了。
 楼主| angryBird 发表于 2013-10-7 20:07 | 显示全部楼层
9点后继续奋战。。。
