[PIC®/AVR®/dsPIC®产品] PIC18单片机下载不了程序!急急急
5828|23
robert8628 发表于 2013-10-27 18:43 | 显示全部楼层
要所有VSS, VDD 及 AVSS, AVDD 都要有供電.
否則會不正常.
 楼主| shuidi_wangdan 发表于 2013-10-28 11:05 | 显示全部楼层
否則會不正常.
我用的这套东西使用了俩月了,之前一直可以下载,硬件没有问题,就是突然不能下载了,现在我重装了电脑系统,现在好了。
塞北天空的雨 发表于 2016-5-28 16:11 | 显示全部楼层
yewuyi 发表于 2013-10-15 09:52
造成连接不上的原因很多,例如:芯片型号不对、有感性或容性负载、用KIT3供电时的电流太大、连接线的顺序错 ...
叶老师,我本来也想问您kit3下载的问题,后来发现确实是自己接错了.......果真不管是什么问题,都是自己的问题。
米珠薪桂 发表于 2016-8-31 09:48 | 显示全部楼层
我也遇到同样的问题,不知道怎么解决。我用的是mplab x IDE,kit3.5,PIC18F44K22,内部晶振,
配置字如下:
//#pragma config CONFIG1H = 0x38
__CONFIG(1, FOSC_INTIO67 & PLLCFG_ON & PRICLKEN_ON & FCMEN_OFF & IESO_OFF);
//#pragma config CONFIG2L = 0x1F
__CONFIG(2, PWRTEN_OFF & BOREN_SBORDIS & BORV_190);
//#pragma config CONFIG2H = 0x3D
__CONFIG(3, WDTEN_NOSLP & WDTPS_32768);
//#pragma config CONFIG3H = 0xBF
__CONFIG(4, CCP2MX_PORTC1 & PBADEN_ON & CCP3MX_PORTB5 & HFOFST_ON & T3CMX_PORTC0 & P2BMX_PORTD2 & MCLRE_EXTMCLR);
//#pragma config CONFIG4L = 0x85
__CONFIG(5, STVREN_ON & LVP_ON & XINST_OFF);
//#pragma config CONFIG5L = 0x3
__CONFIG(6, CP0_OFF & CP1_OFF);
//#pragma config CONFIG5H = 0xC0
__CONFIG(7, CPB_OFF & CPD_OFF);
//#pragma config CONFIG6L = 0x3
__CONFIG(8, WRT0_OFF & WRT1_OFF);
//#pragma config CONFIG6H = 0xE0
__CONFIG(9, WRTC_OFF & WRTB_OFF & WRTD_OFF);
//#pragma config CONFIG7L = 0x3
__CONFIG(10, EBTR0_OFF & EBTR1_OFF);
//#pragma config CONFIG7H = 0x40
__CONFIG(11, EBTRB_OFF);
下载时出错提示如下:
Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.43.35
Firmware type..............PIC18F
Target voltage detected
Target Device ID (0x0) is an Invalid Device ID. Please check your connections to the Target Device.
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x3fff
configuration memory
Device Erased...
Programming...
program memory
Address: 0 Expected Value: 9e Received Value: 0
Failed to program device
