uCOS_II消息队列的问题
1541|1
eng588|  楼主 | 2013-11-5 16:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
当发消息时,有任务在等待,则直接将消息发给任务。这样其实破坏了FIFO啊。我觉得应将消息加入队列,然后再做任务切换。以下是发送消息的代码:
#if OS_Q_POST_EN > 0u
INT8U  OSQPost (OS_EVENT  *pevent,
                void      *pmsg)
    OS_Q      *pq;
#if OS_CRITICAL_METHOD == 3u                           /* Allocate storage for CPU status register     */
    OS_CPU_SR  cpu_sr = 0u;
#endif
#if OS_ARG_CHK_EN > 0u
    if (pevent == (OS_EVENT *)0) {                     /* Validate 'pevent'                            */
        return (OS_ERR_PEVENT_NULL);
#endif
    if (pevent->OSEventType != OS_EVENT_TYPE_Q) {      /* Validate event block type                    */
        return (OS_ERR_EVENT_TYPE);
    OS_ENTER_CRITICAL();
    if (pevent->OSEventGrp != 0u) {                    /* See if any task pending on queue             */
                                                       /* Ready highest priority task waiting on event */
        (void)OS_EventTaskRdy(pevent, pmsg, OS_STAT_Q, OS_STAT_PEND_OK);
        OS_EXIT_CRITICAL();
        OS_Sched();                                    /* Find highest priority task ready to run      */
        return (OS_ERR_NONE);
    pq = (OS_Q *)pevent->OSEventPtr;                   /* Point to queue control block                 */
    if (pq->OSQEntries >= pq->OSQSize) {               /* Make sure queue is not full                  */
        OS_EXIT_CRITICAL();
        return (OS_ERR_Q_FULL);
    *pq->OSQIn++ = pmsg;                               /* Insert message into queue                    */
    pq->OSQEntries++;                                  /* Update the nbr of entries in the queue       */
    if (pq->OSQIn == pq->OSQEnd) {                     /* Wrap IN ptr if we are at end of queue        */
        pq->OSQIn = pq->OSQStart;
    OS_EXIT_CRITICAL();
#endif
eng588|  楼主 | 2013-11-5 20:44 | 只看该作者
ding
个人签名:和平時期做牛馬,戰爭時期當炮灰
82
