[STM8] stm8s003k3求助
1956|3
 楼主| x352174652 发表于 2013-11-25 09:18 | 显示全部楼层 |阅读模式
大家好,我写了个小程序发现现Pb5口的外部中断不能用,麻烦各位给找找原因
man.c
#include<stm8s003k3.h>
#include"typedefine.h"
#include"stm8s_it.h"
int Dis_temp[]={0x02,0x7a,0x44,0x50,0x38,0x90,0x80,0x5b, 0x00,0x10};
void Px_init(void);
void Delay(int);
void main()
EXTI_CR1=0x00;
  Px_init();
        PB_ODR=0xff;
        /*while(1)
        if(PB5_IN==0)
           PC_ODR=0x44;
void Px_init()
  //PA3初始化:输入带上拉中断
        PA3_M=0;
        PA3_CR1=1;
        PA3_CR2=1;
        /*  PB init    */
        PB7_M=0;    //PB7输入上拉带中断
        PB7_CR1=1;
        PB7_CR2=1;
        PB6_M=0;   //PB6输入上拉带中断
        PB6_CR1=1;
        PB6_CR2=1;
        PB5_M=0;   //PB5输入上拉带中断
        PB5_CR1=1;
        PB5_CR2=1;
        PB3_M=1;   //PB3-PB2为推挽输出
        PB3_CR1=1;
        PB3_CR2=0;
        PB2_M=1;
        PB2_CR1=1;
        PB2_CR2=0;
        PB1_M=1;
        PB1_CR1=1;
        PB1_CR2=0;
                   //PB0作为A/D口,设置为
        /* PC口设置为输出带上拉, */
        PC_ODR=0x00;
        PC_DDR=0xff;
        PC_CR1=0xff;
        PC_CR2=0x00;
/* PD口设置  */
  PD3_M=1; //PD3设置为输出带上拉
        PD3_CR1=1;
        PD3_CR2=1;
        PD2_M=1;  //PD2设置为输出带上拉
        PD2_CR1=1;
        PD2_CR2=1;
                  //PD1默认为Swim模式
        PD0_M=1;  //PD0设置为输出带上拉
        PD0_CR1=1;
        PD0_CR2=1;
void Delay(int a)
long int i,j;
for(i=0;i<a;i++)
        for(j=0;j<28000;j++)
                #asm
                nop
                nop
                nop
                nop
                #endasm
interrupt.c
/*        BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
*        Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
        unsigned char interrupt_instruction;
        interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
        return;
@far @interrupt void PB_Exit(void)
        PC_ODR=0x7a;
extern void _stext();    /* startup routine */
struct interrupt_vector const _vectab[] = {
        {0x82, (interrupt_handler_t)_stext}, /* reset */
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, PB_Exit}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, NonHandledInterrupt}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, NonHandledInterrupt}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, NonHandledInterrupt}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, NonHandledInterrupt}, /* irq18 */
        {0x82, NonHandledInterrupt}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 */
        {0x82, NonHandledInterrupt}, /* irq23 */
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
mmuuss586 发表于 2014-4-21 09:41 | 显示全部楼层
没看出来,自己仔细找下呗
desertsailor 发表于 2014-4-21 16:04 | 显示全部楼层
PB5是开漏输出,需要外接上拉电阻
zxc729 发表于 2014-4-21 18:23 来自手机 | 显示全部楼层
楼上正解
