[STM32F1] uCOSIII uCGUI STM32 平台移植 (转)
9040|51
 楼主| lzmm 发表于 2013-11-30 22:06 | 显示全部楼层
135
136     OSSemPost(  (OS_SEM     *)&dispSem,
137                 (OS_OPT        )OS_OPT_POST_1,
138                 (OS_ERR     *)&err);
139 }
140
141
142 U32 GUI_X_GetTaskId(void)
143 {
144   return ((U32)(OSTCBCurPtr->Prio));
145 }
146
147 /*
148 *********************************************************************************************************
149 *                                        GUI_X_WaitEvent()
150 *                                        GUI_X_SignalEvent()
151 *********************************************************************************************************
152 */
153
154
155 void GUI_X_WaitEvent(void)
156 {
157     OS_ERR err;
158     CPU_TS ts;
159
160     OSSemPend(  (OS_SEM     *)&eventSem,
161                 (OS_TICK    )0,
162                 (OS_OPT        )OS_OPT_PEND_BLOCKING,
163                 (CPU_TS     *)&ts,
164                 (OS_ERR     *)&err);
165 }
166
167
168 void GUI_X_SignalEvent(void)
169 {
170     OS_ERR err;
171
172     OSSemPost(  (OS_SEM     *)&eventSem,
173                 (OS_OPT        )OS_OPT_POST_1,
174                 (OS_ERR     *)&err);
175 }
176
177 /*
178 *********************************************************************************************************
179 *                                      KEYBOARD INTERFACE FUNCTIONS
180 *
181 * Purpose: The keyboard routines are required only by some widgets.
182 *          If widgets are not used, they may be eliminated.
183 *
184 * Note(s): If uC/OS-II is used, characters typed into the log window will be placed    in the keyboard buffer.
185 *          This is a neat feature which allows you to operate your target system without having to use or
186 *          even to have a keyboard connected to it. (useful for demos !)
187 *********************************************************************************************************
188 */
189
190 static void CheckInit(void)
191 {
192     if(KeyIsInited==DEF_FALSE)
193     {
194         KeyIsInited = DEF_TRUE;
195         GUI_X_Init();
196     }
197 }
198
199
200 /*被GUI_Init()调用,用来初始化一些GUI运行之前需要用的硬件,如键盘或者鼠标之类的.如果不需要的话,可以为空*/
201 void GUI_X_Init(void)
202 {
203     OS_ERR err;
204
205     OSSemCreate(    (OS_SEM     *)&keySem,
206                     (CPU_CHAR   *)"keySem",
207                     (OS_SEM_CTR )0,
208                     (OS_ERR     *)&err   );
209 }
210
211
212 int GUI_X_GetKey(void)
213 {
214     int r;
215     r = KeyPressed;
216     CheckInit();
217     KeyPressed = 0;
218     return (r);
219 }
220
221
222 int GUI_X_WaitKey(void)
223 {
224     int  r;
225     OS_ERR err;
226     CPU_TS ts;
227
228     CheckInit();
229     if(KeyPressed==0)
230     {
231         OSSemPend(  (OS_SEM     *)&keySem,      //等待信号量
232                     (OS_TICK    )0,
233                     (OS_OPT     )OS_OPT_PEND_BLOCKING,
234                     (CPU_TS     *)&ts,
235                     (OS_ERR     *)&err);
236     }
237     r= KeyPressed;
238     KeyPressed = 0;
239     return (r);
240 }
241
242
243 void GUI_X_StoreKey(int k)
244 {
245     OS_ERR err;
246
247     KeyPressed = k;
248     OSSemPost(  (OS_SEM     *)&keySem,      //释放信号量
249                 (OS_OPT     )OS_OPT_POST_1,
250                 (OS_ERR     *)&err);
251 }
252
253 void GUI_X_Log(const char *s)
254 {
255     GUI_USE_PARA(s);
256 }
257
258 void GUI_X_Warn(const char *s)
259 {
260     GUI_USE_PARA(s);
261 }
262
263 void GUI_X_ErrorOut(const char *s)
264 {
265     GUI_USE_PARA(s);
266 }
在BSP.c文件中添加触摸板SPI接口程序。修改后如下:
 楼主| lzmm 发表于 2013-11-30 22:07 | 显示全部楼层
BSP.C
  1 /*
  2 ********************************************************************************
  3 *                                  uC/OS-III
  4 *
  5 *                              ARM Cortex-M3 Port
  6 *
  7 * File          : Config.C
  8 * Version       : V1.0
  9 * By            : 王宏强
10 *
11 * For           : Stm32f10x
12 * Mode          : Thumb2
13 * Toolchain     :
14 *                     RealView Microcontroller Development Kit (MDK)
15 *                     Keil uVision
16 * Description   : STM32F10x 内部 系统的配置
17 *
18 *                    1,系统中断优先级模式设置
19 *                    2,系统程序启动指定
20 *                    3,系统时钟计时器配置
21 *                    4,芯片引脚初始化
22 *
23 * Date          : 2012.05.22
24 *******************************************************************************/
25
26 #include "misc.h"
27 #include "stm32f10x_gpio.h"
28 #include "stm32f10x_rcc.h"
29 #include "stm32f10x_iwdg.h"
30 #include "stm32f10x_spi.h"
31 #include "bsp.h"
32
33
34 GPIO_InitTypeDef GPIO_InitStructure;
35
36 /*******************************************************************************
37 * Function Name  : GPIO_Configuration
38 * Description    : Configures the different GPIO ports.
39 * Input          : None
40 * Output         : None
41 * Return         : None
42 *******************************************************************************/
43 void GPIO_Configuration(void)
44 {
45 #ifdef USE_STM3210B_EVAL
46     /* Enable the USART2 Pins Software Remapping */
47     GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
48 #endif
49
50     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
51                      RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
52                      RCC_APB2Periph_GPIOE, ENABLE);
53
54     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
55     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
56     GPIO_Init(GPIOA, &GPIO_InitStructure);
57     GPIO_Init(GPIOB, &GPIO_InitStructure);
58     GPIO_Init(GPIOC, &GPIO_InitStructure);
59     GPIO_Init(GPIOD, &GPIO_InitStructure);
60     GPIO_Init(GPIOE, &GPIO_InitStructure);
61
62     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
63                          RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
64                          RCC_APB2Periph_GPIOE, DISABLE);
65
66 }
67
68
69 /*******************************************************************************
70 * Function Name  : Delay
71 * Description    : Inserts a delay time.
72 * Input          : nCount: specifies the delay time length.
73 * Output         : None
74 * Return         : None
75 *******************************************************************************/
76 //void Delay(volatile CPU_INT32U nCount)
77 //{
78 //  for(; nCount != 0; nCount--);
79 //}
80
81 /*******************************************************************************
82 函 数 名:void IWDG_Init(void)
83 功能描述:看门狗初始化
84 入口参数:
85 返回参数:
86 创建时间: 2011.6.24
87 ********************************************************************************/
88 void IWDG_Init(void)
89 {
90     IWDG_WriteAccessCmd( IWDG_WriteAccess_Enable );
91     IWDG_SetPrescaler( IWDG_Prescaler_64);    //最小
92     IWDG_SetReload( 0x138);        //40KHz内部时钟 (1/40000 * 64 * 0x138 = 0.5s)
93     IWDG_WriteAccessCmd( IWDG_WriteAccess_Disable );
94     IWDG_Enable();
95     IWDG_ReloadCounter();
96 }
97
98 /*******************************************************************************
99 * Function Name :void SysTickInit(void)
100 * Description   :系统定时器时间配置
101 * Input         :
102 * Output        :
103 * Other         :时基为1ms
104 * Date          :2011.11.03  12:59:13
105 *******************************************************************************/
106 void SysTickInit(void)
107 {
108     SysTick_Config(SystemCoreClock / 1000);            //uCOS时基1ms
109 }
110
111 /*******************************************************************************
112 * Function Name :void InterruptOrder(void)
113 * Description   :中断向量,优先级
114 * Input         :
115 * Output        :
116 * Other         :
117 * Date          :2011.10.27  11:50:05
118 *******************************************************************************/
119 void NVIC_Configuration(void)
120 {
121     NVIC_PriorityGroupConfig( NVIC_PriorityGroup_4);//优先级设置  全为抢占式优先级
122 }
123
124
125 /*******************************************************************************
126 * Function Name :void SystemConfig(void)
127 * Description   :系统时间戳 初始化
128 * Input         :
129 * Output        :
130 * Other         :
131 * Date          :2012.6.15  13:14:59
132 *******************************************************************************/
133 #if (CPU_CFG_TS_TMR_EN == DEF_ENABLED)
134 void  CPU_TS_TmrInit (void)
135 {
136 }
137 #endif
138
139
140 /*******************************************************************************
141 * Function Name :void SystemConfig(void)
142 * Description   :读时间戳 计数值
143 * Input         :读到的计数值
144 * Output        :
145 * Other         :
146 * Date          :2012.6.15  13:14:59
147 *******************************************************************************/
148 #if (CPU_CFG_TS_TMR_EN == DEF_ENABLED)
149 CPU_TS_TMR  CPU_TS_TmrRd (void)
150 {
151     return (SysTick->VAL);
152 }
153 #endif
154
155 /*******************************************************************************
156 * Function Name :void SystemConfig(void)
157 * Description   :系统初始化
158 * Input         :
159 * Output        :
160 * Other         :
161 * Date          :2011.10.27  13:14:59
162 *******************************************************************************/
163 void BspInit(void)
164 {
165     NVIC_Configuration();    //中断优先级设置
166     GPIO_Configuration();    //端口初始化,所有端口关
167     SPI_Config();           //触摸接口初始化
168 }
169
170 void led_init(void)
171 {
172     GPIO_InitTypeDef GPIO_InitStructure;
173     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOF, ENABLE);
174     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 |  GPIO_Pin_12 | GPIO_Pin_13;
175     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
176     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
177     GPIO_Init(GPIOA, &GPIO_InitStructure);
178
179     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8;
180     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
181     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
182     GPIO_Init(GPIOF, &GPIO_InitStructure);
183 }
184
185
186
187 void led_on(CPU_INT32U n)
188 {
189     switch (n)
190     {
191         case LED_0:
192         GPIO_SetBits(GPIOD, GPIO_Pin_2);
193         break;
194         case LED_1:
195         GPIO_SetBits(GPIOD, GPIO_Pin_3);
196         break;
197         case LED_2:
198         GPIO_SetBits(GPIOD, GPIO_Pin_4);
199         break;
200         case LED_3:
201         GPIO_SetBits(GPIOF, GPIO_Pin_6);
202         break;
203         case LED_4:
204         GPIO_SetBits(GPIOF, GPIO_Pin_7);
205         break;
206         case LED_5:
207         GPIO_SetBits(GPIOF, GPIO_Pin_8);
208         break;
209         default:
210         break;
211     }
212 }
213
214
215 void led_off(CPU_INT32U n)
216 {
217     switch (n)
218     {
219         case LED_0:
220         GPIO_ResetBits(GPIOD, GPIO_Pin_2);
221         break;
222         case LED_1:
223         GPIO_ResetBits(GPIOD, GPIO_Pin_3);
224         break;
225         case LED_2:
226         GPIO_ResetBits(GPIOD, GPIO_Pin_4);
227         break;
228         case LED_3:
229         GPIO_ResetBits(GPIOF, GPIO_Pin_6);
230         break;
231         case LED_4:
232         GPIO_ResetBits(GPIOF, GPIO_Pin_7);
233         break;
234         case LED_5:
235         GPIO_ResetBits(GPIOF, GPIO_Pin_8);
236         break;
237         default:
238         break;
239     }
240 }
241 /*
242  T_CS PA4
243  SPI1_SCK PA5
244  SPI1_MISO PA6
245 SPI1_MOSI PA7
246    T_BUSY PA8
247 */
248 void SPI_Config(void)
249 {
250     GPIO_InitTypeDef  GPIO_InitStructure;
251     SPI_InitTypeDef   SPI_InitStructure;
252
253     //GPIOA Periph clock enable
254     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
255     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
256     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE,ENABLE);
257     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF,ENABLE);
258     //SPI1 Periph clock enable
259     // RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE);
260     //SPI2 Periph clock enable
261     RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI2, ENABLE ) ;
262
263     //Configure SPI2 pins: SCK, MISO and MOSI
264     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
265     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
266     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;   //复用推挽输出
267     GPIO_Init(GPIOB,&GPIO_InitStructure);
268     /*
269     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_7;
270     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
271     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;   //推挽输出
272     GPIO_Init(GPIOA,&GPIO_InitStructure);
273
274     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
275     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
276     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;   //上拉输入
277     GPIO_Init(GPIOA,&GPIO_InitStructure);     */
278
279     //Configure PF10 pin: TP_CS pin
280     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
281     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
282     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     //推挽输出
283     GPIO_Init(GPIOB,&GPIO_InitStructure);
284
285     //Configure PA8 pin: TP_BUSY pin
286     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
287     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
288     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;     //上拉输入
289     GPIO_Init(GPIOE,&GPIO_InitStructure);
290
291     /* Configure PE.06 as input floating For TP_IRQ*/
292     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
293     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
294     GPIO_Init(GPIOE,&GPIO_InitStructure);
295
296     // SPI1 Config
297     SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
298     SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
299     SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
300     SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
301     SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
302     SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;   //SPI_NSS_Hard
303     SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64;
304     SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
305     SPI_InitStructure.SPI_CRCPolynomial = 7;
306     SPI_Init(SPI2,&SPI_InitStructure);
307
308     // SPI1 enable
309     SPI_Cmd(SPI2,ENABLE);
310 }
311
312
313 unsigned char SPI_WriteByte(unsigned char data)
314 {
315     unsigned char Data = 0;
316
317     //Wait until the transmit buffer is empty
318     while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE)==RESET);
319     // Send the byte
320     SPI_I2S_SendData(SPI2,data);
321
322     //Wait until a data is received
323     while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_RXNE)==RESET);
324     // Get the received data
325     Data = SPI_I2S_ReceiveData(SPI2);
326
327     // Return the shifted data
328     return Data;
329 }
330 void SpiDelay(unsigned int DelayCnt)
331 {
332  unsigned int i;
333  for(i=0;i<DelayCnt;i++);
334 }
335
336 u16 TPReadX(void)
337 {
338     u16 x=0;
339     TP_CS();
340     SpiDelay(10);
341     SPI_WriteByte(0x90);
342     SpiDelay(10);
343     x=SPI_WriteByte(0x00);
344     x<<=8;
345     x+=SPI_WriteByte(0x00);
346     SpiDelay(10);
347     TP_DCS();
348     x = x>>3;
349     return (x);
350 }
351
352 u16 TPReadY(void)
353 {
354     u16 y=0;
355     TP_CS();
356     SpiDelay(10);
357     SPI_WriteByte(0xD0);
358     SpiDelay(10);
359     y=SPI_WriteByte(0x00);
360     y<<=8;
361     y+=SPI_WriteByte(0x00);
362     SpiDelay(10);
363     TP_DCS();
364     y = y>>3;
365     return (y);
366 }
向工程中添加两个stm32f10x_fsmc.c,stm32f10x_spi.c这两个文件。
好了,大部分的准备工作都好了, 再在让新建一个任务来运行Dome中的MainTask();在任务3中调用GUI_TOUCH_Exec();
1   1 /*-------------------------------------------------------------------------
  2   2
  3   3                             软件主体
  4   4
  5   5
  6   6 -------------------------------------------------------------------------*/
  7   7
  8   8 #include "bsp.h"
  9   9 #include "App.h"
10  10
11  11 extern void MainTask(void);
12  12 extern void GUI_TOUCH_Exec(void);
13  13
14  14 static  OS_TCB      taskStartTCB;
15  15 static  CPU_STK     taskStartStk[STARTUP_TASK_STK_SIZE];         //启动任务的程序空间
16  16
17  17 static  OS_TCB      task1TCB;
18  18 static  CPU_STK     task1Stk[TASK1_STK_SIZE];
19  19
20  20 static  OS_TCB      task2TCB;
21  21 static  CPU_STK     task2Stk[TASK2_STK_SIZE];
22  22
23  23 static  OS_TCB      task3TCB;
24  24 static  CPU_STK     task3Stk[TASK3_STK_SIZE];
25  25
26  26 static  OS_TCB      dispTCB;
27  27 static  CPU_STK     dispStk[TASK4_STK_SIZE];
28  28
29  29 static  volatile    OS_SEM taskSem;
30  30
31  31
32  32
33  33 /*******************************************************************************
34  34 * Function Name :void TaskStart(void)
35  35 * Description   :任务启动
36  36 * Input         :
37  37 * Output        :
38  38 * Other         :
39  39 * Date          :2012.04.18  11:48:23
40  40 *******************************************************************************/
41  41 static void TaskStart(void)
42  42 {
43  43     OS_ERR         err;
44  44
45  45     led_init();
46  46     SysTickInit();
47  47
48  48
49  49     OSTaskCreate(   (OS_TCB     *)&task1TCB,
50  50                     (CPU_CHAR   *)"Task1",
51  51                     (OS_TASK_PTR)Task1,
52  52                     (void       *)0,
53  53                     (OS_PRIO    )TASK1_PRIO,
54  54                     (CPU_STK    *)&task1Stk[0],
55  55                     (CPU_STK_SIZE)TASK1_STK_SIZE / 10,
56  56                     (CPU_STK_SIZE)TASK1_STK_SIZE,
57  57                     (OS_MSG_QTY )0,
58  58                     (OS_TICK    )0,
59  59                     (void       *)0,
60  60                     (OS_OPT     )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
61  61                     (OS_ERR     *)&err);
62  62
63  63     OSTaskCreate(   (OS_TCB     *)&task2TCB,
64  64                     (CPU_CHAR   *)"Task2",
65  65                     (OS_TASK_PTR)Task2,
66  66                     (void       *)0,
67  67                     (OS_PRIO    ) TASK2_PRIO,
68  68                     (CPU_STK    *)&task2Stk[0],
69  69                     (CPU_STK_SIZE)TASK2_STK_SIZE / 10,
70  70                     (CPU_STK_SIZE)TASK2_STK_SIZE,
71  71                     (OS_MSG_QTY )0,
72  72                     (OS_TICK    )0,
73  73                     (void       *)0,
74  74                     (OS_OPT     )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
75  75                     (OS_ERR     *)&err);
76  76
77  77
78  78     OSTaskCreate(   (OS_TCB     *)&task3TCB,
79  79                     (CPU_CHAR   *)"Task3",
80  80                     (OS_TASK_PTR)Task3,
81  81                     (void       *)0,
82  82                     (OS_PRIO    )TASK3_PRIO,
83  83                     (CPU_STK    *)&task3Stk[0],
84  84                     (CPU_STK_SIZE)TASK3_STK_SIZE / 10,
85  85                     (CPU_STK_SIZE)TASK3_STK_SIZE,
86  86                     (OS_MSG_QTY )0,
87  87                     (OS_TICK    )0,
88  88                     (void       *)0,
89  89                     (OS_OPT     )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
90  90                     (OS_ERR     *)&err);
91  91
92  92      OSTaskCreate(  (OS_TCB     *)&dispTCB,
93  93                     (CPU_CHAR   *)"LCD display",
94  94                     (OS_TASK_PTR)MainTask,
95  95                     (void       *)0,
96  96                     (OS_PRIO    )Disp_PRIO,
97  97                     (CPU_STK    *)&dispStk[0],
98  98                     (CPU_STK_SIZE)TASK4_STK_SIZE / 10,
99  99                     (CPU_STK_SIZE)TASK4_STK_SIZE,
100 100                     (OS_MSG_QTY )0,
101 101                     (OS_TICK    )0,
102 102                     (void       *)0,
103 103                     (OS_OPT     )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
104 104                     (OS_ERR     *)&err);
105 105
106 106     OSSemCreate(    (OS_SEM     *)&taskSem,
107 107                     (CPU_CHAR   *)"taskSem",
108 108                     (OS_SEM_CTR )0,
109 109                     (OS_ERR     *)err);
110 110
111 111     OSTaskDel(      (OS_TCB     *)&taskStartTCB,
112 112                     (OS_ERR     *)&err);
113 113 }
114 114
 楼主| lzmm 发表于 2013-11-30 22:08 | 显示全部楼层
115 115 static void Task1(void *p_arg)
116 116 {
117 117     OS_ERR err;
118 118
119 119     while (1)
120 120     {
121 121         led_on(LED_4);
122 122         OSTimeDly(  (OS_TICK    )200,
123 123                     (OS_OPT     )OS_OPT_TIME_DLY,
124 124                     (OS_ERR     *)&err);
125 125
126 126         led_off(LED_4);
127 127         OSTimeDly(  (OS_TICK    )200,
128 128                     (OS_OPT     )OS_OPT_TIME_DLY,
129 129                     (OS_ERR     *)&err);
130 130
131 131         OSSemPost(  (OS_SEM     *)&taskSem,
132 132                     (OS_OPT     )OS_OPT_POST_ALL,
133 133                     (OS_ERR     *)&err);
134 134     }
135 135 }
136 136
137 137 static void Task2(void *p_arg)
138 138 {
139 139     OS_ERR err;
140 140
141 141     while (1)
142 142     {
143 143         led_on(LED_5);
144 144         OSSemPend(  (OS_SEM     *)&taskSem,
145 145                     (OS_TICK    )10000,
146 146                     (OS_OPT     )OS_OPT_PEND_BLOCKING,
147 147                     (CPU_TS     *)0,
148 148                     (OS_ERR     *)&err);
149 149
150 150         led_off(LED_5);
151 151         OSSemPend(  (OS_SEM     *)&taskSem,
152 152                     (OS_TICK    )10000,
153 153                     (OS_OPT     )OS_OPT_PEND_BLOCKING,
154 154                     (CPU_TS     *)0,
155 155                     (OS_ERR     *)&err);
156 156     }
157 157 }
158 158
159 159 static void Task3(void *p_arg)
160 160 {
161 161     OS_ERR err;
162 162     static int tasCon = 0;
163 163     while (1)
164 164     {
165 165         GUI_TOUCH_Exec();
166 166         OSTimeDly(  (OS_TICK    )10,
167 167                     (OS_OPT     )OS_OPT_TIME_DLY,
168 168                     (OS_ERR     *)&err);
169 169
170 170         OSTimeDly(  (OS_TICK    )10,
171 171                     (OS_OPT     )OS_OPT_TIME_DLY,
172 172                     (OS_ERR     *)&err);
173 173
174 174         if ((tasCon++ % 50) < 25)
175 175             led_on(LED_3);
176 176         else
177 177             led_off(LED_3);
178 178     }
179 179 }
180 180
181 181
182 182 void KernelMain(void)
183 183 {
184 184     OS_ERR err;
185 185
186 186     CPU_Init();
187 187     OSInit(         (OS_ERR        *)&err);
188 188
189 189     OSTaskCreate(   (OS_TCB     *)&taskStartTCB,
190 190                     (CPU_CHAR   *)"Task Start",
191 191                     (OS_TASK_PTR)TaskStart,
192 192                     (void       *)0,
193 193                     (OS_PRIO    ) STARTUP_TASK_PRIO,
194 194                     (CPU_STK    *)&taskStartStk[0],
195 195                     (CPU_STK_SIZE)STARTUP_TASK_STK_SIZE / 10,
196 196                     (CPU_STK_SIZE)STARTUP_TASK_STK_SIZE,
197 197                     (OS_MSG_QTY )0,
198 198                     (OS_TICK    )0,
199 199                     (void       *)0,
200 200                     (OS_OPT     )(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR),
201 201                     (OS_ERR     *)&err);
202 202
203 203     OSStart(        (OS_ERR        *)&err);
204 204 }
设定优先级 和分配空间。任务3分配350个字节,MainTask分配500个字节
优先级设定触摸版 比MainTask()高就可以了。
需要注意一个问题,GUI中用到了获取获取时基计数器的值。而时基计数器是在优先级为10的任务中进行刷新的。所以必需把         MainTask()任务的优先级比10优先级低。
         还有一个解决办法:修改时基计数器任务的优先级,在uCOS-III\uCOS-III文件os_cfg_app.h
OS_CFG_TMR_TASK_PRIO
OS_CFG_TICK_TASK_PRIO
到此就可以进行编译了。
几分钟的等待,下载~~~
每次编译的时间实在是太长了。这样咱们把源代码生成库,再进行编译。如下图:
图11
再编译生成
到Obj文件夹下到Project.lib 找到,改下名子GUI3_98.lib
把工程中的uCGUI/lib里的所有文件删除,用GUI3_98.lib替换。
再切换回来
图13
 楼主| lzmm 发表于 2013-11-30 22:09 | 显示全部楼层
图12
再编译, 是不是非常快了。
注意:在对LCD配置变更时,需要重新制作.lib库。
以下两个连接是编译完成后的工程。
FWLib3.5+uCOSIII3.03+uCGUI3.98(源文件版).rar
http://pan.baidu.com/share/link?shareid=25616&uk=118334538
FWLib3.5+uCOSIII3.03+uCGUI3.98(库形式版).rar
http://pan.baidu.com/share/link?shareid=25619&uk=118334538
总结:
在移植的过程中主要讲述了三点
    三个LCD的驱动函数。
    GUI程序在uCOS-III优先级的选择。
    GUI库的制作。
好了,就这些了,后期还会慢慢更新最新版。希望以上对新学习uCGUI的朋友有所帮助。
下面传几个Dome的照片。
 楼主| lzmm 发表于 2013-11-30 22:10 | 显示全部楼层
黄小俊 发表于 2013-12-1 16:24 | 显示全部楼层
好复杂啊。
