怎么跳出void zz()子程序
3716|21
 楼主| meimiao88 发表于 2013-12-17 16:24 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include<math.h>
#define uchar unsigned char
#define uint unsigned int
sbit left_f = P2^4;    //a左前
sbit left_b = P2^5;
sbit right_f = P2^6;   //a右前
sbit right_b = P2^7;
sbit c1 =P3^0;         //a右后
sbit c2 =P3^1;
sbit d1 =P3^2;         //a左后
sbit d2=P3^3;
unsigned int y;
unsigned char temp;
sbit  huidu_3=P1^3;
sbit  huidu_4=P1^4;
sbit  huidu_5=P1^5;
sbit  huidu_6=P1^6;
sbit  huidu_7=P1^7;
sbit  huidu_8=P1^0;
sbit  huidu_9=P1^1;
sbit  huidu_10=P1^2;
uchar count = 0;
void zz();
void init()
        TH0 = (65535-10)/256;
        TL0 = (65535-10)%256;
        TMOD = 0x01;
        TR0 = 1;
        ET0 = 1;
        EA = 1;
void Timer0_int()interrupt 1 //定时器中断计数
        count ++;
        if(count >= 100)
        {count = 0; }
void dianji_a(uchar speed)
        if(count <= speed)           //count计数变量
                left_f = 1;
                left_b = 0;
        else
                left_f = 1;
                left_b = 1;
void dianji_b(uchar speed)          //同上
        if(count<= speed)
                right_f =0;
                right_b = 1;
        else
                right_f = 1;
                right_b = 1;
void dianji_c(uchar speed)
                c1 = 0;
                c2 = 1;
        else
                c1= 1;
                c2 = 1;
void dianji_d(uchar speed)
                d1 = 1;
                d2 =0;
        else
        d1= 1;
        d2 = 1;
void bdianji_a(uchar speed)
                left_f = 0;
                left_b = 1;
        else
                left_f = 1;
                left_b = 1;
void bdianji_b(uchar speed)          //同上
        if(count<= speed)
                right_f =1;
                right_b = 0;
        else
                right_f = 1;
                right_b = 1;
void bdianji_c(uchar speed)
                c1 = 1;
                c2 = 0;
        else
                c1= 1;
                c2 = 1;
void bdianji_d(uchar speed)
                d1 = 0;
                d2 =1;
        else
        d1= 1;
        d2 = 1;
void contorlA()
        temp = P1;
if(temp==0xc0)
    dianji_a(20);
    dianji_b(20);
    dianji_c(20);
    dianji_d(20);
else if(temp==0x60)
    dianji_a(40);
    dianji_b(5);
    dianji_c(5);
    dianji_d(40);
  else if(temp==0x81)
    dianji_a(3);
    dianji_b(50);
    dianji_c(50);
    dianji_d(3);
else if(temp==0x20)//5
    dianji_a(50);
    dianji_b(3);
    dianji_c(3);
    dianji_d(50);
else if(temp==0x01)//8
    dianji_a(5);
    dianji_b(50);
    dianji_c(50);
    dianji_d(5);
else if(temp==0x02)//9
    dianji_a(0);
    dianji_b(50);
    dianji_c(50);
    dianji_d(0);
else if(temp==0x10)//4
    dianji_a(50);
    dianji_b(0);
    dianji_c(0);
    dianji_d(50);
else if(temp==0xf8)
   for(y=0;y<600;y++)
    dianji_a(50);
    bdianji_b(35);
    bdianji_c(35);
    dianji_d(50);
else if (temp==0x78)//3456
for(y=0;y<500;y++)
    dianji_a(50);
    bdianji_b(35);
    bdianji_c(35);
    dianji_d(50);
else if(temp==0xc7|temp==0x87)//678910
   zz();
else
      dianji_a(5);
      dianji_b(5);
      dianji_c(5);
      dianji_d(5);
void zz()
  temp=P1;
while(temp!=0xc0)
    bdianji_a(35);
    dianji_b(50);
    dianji_c(50);
    bdianji_d(35);
    if(temp==0xc0)
          contorlA;
void main()
   init();
   while(1)
      contorlA();
ayb_ice 发表于 2013-12-17 16:26 | 显示全部楼层
huangxz 发表于 2013-12-17 17:02 | 显示全部楼层
temp == 0xc0不就出去了吗
 楼主| meimiao88 发表于 2013-12-17 17:14 | 显示全部楼层
temp == 0xc0不就出去了吗
试过  不行的   break我也试过
ningling_21 发表于 2013-12-17 17:20 | 显示全部楼层
temp = 0xc0;
加到while()循环里面的最后
huangxz 发表于 2013-12-17 17:56 | 显示全部楼层
试过  不行的   break我也试过
兄弟,讲笑话吧,这可是c的基本语法,如果出不去,那你程序堆栈可能出问题了。
 楼主| meimiao88 发表于 2013-12-17 19:22 | 显示全部楼层
兄弟,讲笑话吧,这可是c的基本语法,如果出不去,那你程序堆栈可能出问题了。 ...
真不开玩笑   程序是没问题的  你说是不是嵌入太深吗
 楼主| meimiao88 发表于 2013-12-17 19:30 | 显示全部楼层
temp = 0xc0;
加到while()循环里面的最后
这个就失去我的本意了
dirtwillfly 发表于 2013-12-17 20:03 | 显示全部楼层
额,好多else if,而且没对齐~~
看着好累,难道不能用个switch case~~
gegezaixiao 发表于 2013-12-17 21:22 | 显示全部楼层
单独调试这个ZZ函数,另外你这个函数名称取得
rocdove 发表于 2013-12-17 21:24 | 显示全部楼层
楼主代码,需要整理下,不太规范。想跳出去可以,就是想知道你想什么情况下跳出
huangxz 发表于 2013-12-17 22:43 | 显示全部楼层
temp是由P1赋值的,你可以软件仿真一下啊
MakeBetter 发表于 2013-12-17 22:58 | 显示全部楼层
你看清楚了:|   和 || 符号的区别
以上语句最好写成:
if((temp==0xc7) || (temp==0x87))//678910
banalmaster 发表于 2013-12-17 23:57 | 显示全部楼层
你写的zz()函数确实退不出去。
将    if(temp==0xc0)
      contorlA;
放到while循环外面,然后加return或break试试。
天凉好个秋 发表于 2013-12-18 07:17 | 显示全部楼层
当然不能跳出去,因为循环中 temp 没有重新赋值
一语中的。另外就是得确保P1会出现0xc0的状态  发表于 2013-12-18 09:32
ningling_21 发表于 2013-12-18 10:12 | 显示全部楼层
这个就失去我的本意了
那本意是什么呢?
不改变temp 就能跳出去?
 楼主| meimiao88 发表于 2013-12-18 16:13 | 显示全部楼层
那本意是什么呢?
不改变temp 就能跳出去?
这是个小车的程序   我想让它转弯   当检测到灰度67的时候 进入寻线
 楼主| meimiao88 发表于 2013-12-18 16:14 | 显示全部楼层
你写的zz()函数确实退不出去。
将    if(temp==0xc0)
这个也试过了 兄弟
lzlz70707 发表于 2013-12-18 16:22 | 显示全部楼层
while里面应该继续对temp赋值才对
循环体里面加一句temp=P1 当P1为0xC0就出去了
 楼主| meimiao88 发表于 2013-12-18 18:34 | 显示全部楼层
楼主代码,需要整理下,不太规范。想跳出去可以,就是想知道你想什么情况下跳出 ...
