[STM32F1] TIM输出32kHz给RTC,RTC死循环。
1945|1
 楼主| moonriver610 发表于 2014-1-6 17:37 | 显示全部楼层 |阅读模式
RTC, kHz, TI, se, ST
因为需要个32位的计时器,计时单位要准确的1ms,所以用最便宜的办法,把F107VCT6的TIM输出脚输出给RTC的OSC32_in,32kHz的方波是看到了,可是RTC程序不知道怎么搞,各位大侠帮忙看看:
void RTC_Configuration(void)
  /* Enable PWR and BKP clocks */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
  /* Allow access to BKP Domain */
  PWR_BackupAccessCmd(ENABLE);
  /* Reset Backup Domain */
  BKP_DeInit();
  /* Enable LSE */
//   RCC_LSEConfig(RCC_LSE_ON);
  /* Wait till LSE is ready */
//   while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
  /* Select LSE as RTC Clock Source */
  RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
  /* Enable RTC Clock */
  RCC_RTCCLKCmd(ENABLE);
  /* Wait for RTC registers synchronization */
  RTC_WaitForSynchro();
  /* Wait until last write operation on RTC registers has finished */
  RTC_WaitForLastTask();
  /* Enable the RTC Second */
//   RTC_ITConfig(RTC_IT_SEC, ENABLE);
//   RTC_WaitForLastTask();
  /* Set RTC prescaler: set RTC period to 1sec */
  RTC_SetPrescaler(32-1);
        RTC_SetCounter(0x0);
程序在第一个  RTC_WaitForSynchro()处死循环。
mmuuss586 发表于 2014-4-20 22:17 | 显示全部楼层
