介绍两本书,度年假时看.
2032|3
冰源|  楼主 | 2008-1-30 11:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
AN, RS, ST, TE, TI
1.
Designing Analog Chips
by Hans Camenzind
A comprehensive introduction to CMOS and bipolar analog IC design. The book presumes no prior knowledge of linear design, making it comprehensible to engineers with a non-analog background. The emphasis is on practical design, covering the entire field with hundreds of examples to explain the choices. Concepts are presented following the history of their discovery.
Content: 1. Devices Semiconductors, The Bipolar Transistor, The Integrated Circuit, Integrated NPN Transistors, The Case of the Lateral PNP Transistor, CMOS Transistors, The Substrate PNP Transistor, Diodes, Zener Diodes, Resistors, Capacitors, CMOS vs. Bipolar. 2. Simulation, DC Analysis, AC Analysis, Transient Analysis, Variations, Models, Diode Model, Bipolar Transistor Model, Model for the Lateral PNP Transistor, MOS Transistor Models, Resistor Models, Models for Capacitors. 3. Current Mirrors. 4. Differential Pairs. 5. Current Sources. 6. Time Out: Analog Measures, dB, RMS, Noise, Fourier Analysis, Distortion, Frequency Compensation. 7. Bandgap References. 8. Op Amps . 9. Comparators 10. Transimpedance Amplifiers 11. Timers and Oscillators . 12. Phase-Locked Loops . 13. Filters . 14. Power, Linear Regulators, Low Drop-Out Regulators, Switching Regulators, Linear Power Amplifiers, Switching Power Amplifiers. 15. A to D and D to A, The Delta-Sigma Converter. 16. Odds and Ends, Gilbert Cell, Multipliers, Peak Detectors, Rectifiers and Averaging Circuits, Thermometers, Zero-Crossing Detectors. 17. Layout.
2.
A History of Electricity and Electronics
2007, Hans Camenzind
怎么上传?
chunyang| | 2008-1-30 14:57 | 只看该作者
网站FTP
iC921| | 2008-1-30 18:17 | 只看该作者
帮顶
冰源|  楼主 | 2008-1-30 20:27 | 只看该作者
Free download books.
"Designing Analog Chips",
by Hans Camenzind,
242 pages, pdf format,
http://www.designinganalogchips.com/
"The History of Electronics - Much Ado About Almost Nothing",
by Hans Camenzind,
238 pages, pdf format,
http://www.historyofelectronics.com/
