发送1 2 3 4 5 6 7 8结果是00 01 00 02 00 03 00 04
1444|3
 楼主| xu0801hua 发表于 2014-3-4 11:50 | 显示全部楼层 |阅读模式
#include"reg51.h"
  #include"intrins.h"
  #define uchar unsigned char
  #define uint unsigned int
     /*Declare SFR associated with the ISP */
  sfr      IAP_DATA   =   0xE2;           //Flash data register        闪存数据寄存器
  sfr      IAP_ADDRH  =   0xE3;           //Flash address HIGH 闪存地址高
  sfr      IAP_ADDRL  =   0xE4;           //Flash address LOW  闪存地址低
  sfr      IAP_CMD    =   0xE5;           //Flash command register 闪存命令寄存器
  sfr      IAP_TRIG   =   0xE6;           //Flash command trigger  闪存命令触发
  sfr      IAP_CONTR  =   0xE7;           //Flash control register 闪存控制寄存器
  /*Define ISP/IAP/EEPROM command*/
  #define  CMD_IDLE        0x00               //Stand-By
  #define  CMD_READ        0x00               //unsigned char-Read
  #define  CMD_PROGRAM     0x02              //unsigned char-Program
  #define  CMD_ERASE       0x03               //Sector-Erase
  /*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
  //#define ENABLE_IAP      0x80             //if SYSCLK<30MHz
  //#define ENABLE_IAP      0x81             //if SYSCLK<24MHz
  //#define ENABLE_IAP      0x82             //if SYSCLK<200MHz
  #define   ENABLE_IAP      0x83             //if SYSCLK<12MHz
  //#define ENABLE_IAP      0x80             //if SYSCLK<6MHz
  #define   IAP_ADDRESS     0x0000
  /**AD特殊寄存器***/
  sfr                ADC_DATA    =0xc6;
  sfr                  ADC_LOW2          =0xbe;
  sfr                  ADC_CONTR   =0xc5;
  sfr         P1M0        =0x91;
  sfr         P1M1        =0x92;
  /***按键定义*****/
  sbit  KEY_P3_4          =P3^4;   //左边拨动开关(拨向左:P3^4==0,表示需要标定电压;否则不需要标定)
  sbit  KEY_P0_0          =P0^0;   //右边红色按钮(按下时:P0^0==0,表示开始标定电压;否则不标定)
  sbit  led=P1^1;
  void ISP_IAP_Disable();
  /***程序用到的定义****/
  uint i,j,AD_finished=0,pj=0;mj=0,x=5,su[8]={1,2,3,4,5,6,7,8},y;
  unsigned char *str=su;
  uchar num,result,di,flag;
  /**********延时函数*****************/
  void delayms(uint xms)
   for(i=xms;i>0;i--)
     for(j=110;j>0;j--);
/*********串口/定时器初始化***************/
  void init()
    TMOD=0x21;//设定T1定时器工作方式2 0010 0001
    TH1=0xfd;//T1定时器高8位赋值
    TL1=0xfd;//T1定时器低8位赋值
        TH0=0x4c;//T0定时器高8位赋值
        TL0=0x00;//T0定时器低8位赋值
    SCON=0x40;//设定串口工作方式1
    EA=1;//开中断
        TR0=1;//开启定时器T0
    TR1=1;//开启定时器T1
        ET0=1;//开定时器0中断
    ES=1;//允许串口中断
    REN=1;//允许串口接收
//函数:void UART1_Send_Char(uchar send_data)
//描述:单片机向串口发送一个字符
//参数:uchar send_data       //待发送数据
//返回:无
   void UART1_Send_Char(uchar send_data)//1.32===int 1.0//==132
   ES=0;
   SBUF=send_data;//接收数据
   while(!TI);
   TI=0;
   ES=1;
// 函数:void UART1_Send_String(uchar *str, uchar len)
//描述:单片机向串口发送一个字符串
//参数:uchar *str        //待发送数据
//            uchar len        //字符串长度
//返回:无
    uchar z;
        for(z=0;z<len;z++)
         UART1_Send_Char(*(str+z));
  /*********AD函数**************/
  void AD_init()
   P1M0=0x80;P1M1=0x00;
   ADC_DATA=0;
   ADC_CONTR=0xe0;//1110 0000开启启动电源和选择转换速度
   delayms(60);
  /*****AD转换函数*********/
  uint getAD()
   uchar AD_finished=0;
   ADC_CONTR|=0x07; //1110 0000 | 1111 1111 或上AD口的值
   ADC_CONTR|=0x08;//0000 1000启动AD电源
   while(AD_finished==0)//等待A/D转换结束
   (AD_finished=(ADC_CONTR&0x10));//0000 1000 & 0001 0000 =0000 0000查询ADC_FLAG位是否置1
        ADC_CONTR=0Xf7;//1111 0111//关闭启动位
   return ADC_DATA;        //值返回给高8位
      /*********定时中断***********/
  void T0_time() interrupt 1
   TH0=0x4c;
   TL0=0x00;
   num++;
    if(num>=20)
    num=0;
    pj=1;
/****关闭ISP,IAP功能*******/
   IAP_CONTR=0x00;//Close IAP function关闭控制寄存器
   IAP_CMD  =0x00;//clear command to standby清除命令备用
   IAP_TRIG =0x00;//Clear trigger register
   IAP_ADDRH=0x00;//Data ptr point to non-EEPROM area
   IAP_ADDRL=0x00;//Clear IAP address to prevent misuse
  /**向EEPROM16位地址写入8位数据**/
  void IapProgramINT8U(unsigned int add,unsigned char dat)
   IAP_CONTR=ENABLE_IAP;//Open IAP function,and set wait time 打开IAP功能,设置Flash操作等待时间
   IAP_CMD=0x02;//对用户的应用程序Flash区及数据Flash区编程
  // my_unTemp16.un_temp16 = add;
   IAP_ADDRH=add>>8/*my_unTemp16.un_temp8[0]*/;     //设置目标单元地址的高8位地址
   IAP_ADDRL=add/*my_unTemp16.un_temp8[1]*/;       //设置目标单元地址的低8位地址
   IAP_DATA=dat; //写入数据准备
   IAP_TRIG=0x46;//Send trigger command1 (0x46)
   IAP_TRIG=0xb9;//Send trigger command1 (0xb9)
   _nop_();        //延时一个机器周期
   ISP_IAP_Disable();  //关闭IAP,ISP功能
  /********读出值***********/
   unsigned char IapReadINT8U(unsigned int add)
    unsigned char dat;
   IAP_DATA=0x00;
   IAP_CONTR=ENABLE_IAP;    // 打开IAP功能,设置Flash操作等待时间
   IAP_CMD  =0x01;     // 对用户的应用程序Flash区及数据Flash区字节读
   IAP_TRIG =0x46;                 //触发ISP_IAP命令字节1(0x46)
   IAP_TRIG =0xb9;                 //触发ISP_IAP命令字节2(0xb9)
    _nop_();         //延时一个机器周期
   dat=IAP_DATA;      //读出数据准备
   return dat;          //返回给函数
  /**扇区擦除**/
  void IapEraseSector(unsigned int add)
   IAP_CONTR = ENABLE_IAP;//打开IAP功能,设置Flash操作等待时间
   IAP_CMD   = 0x03;//对用户的应用程序Flash区及数据Flash区擦出
   //my_unTemp16.un_temp16 = addr;
   _nop_();         //延时一个机械周期
   ISP_IAP_Disable();//关闭IAP/ISP
/**主函数***/
    void main()
   init();
   while(1)
        UART1_Send_String(str,8);
NE5532 发表于 2014-3-4 13:09 | 显示全部楼层
把其他程序都删了,只调发送部分。
Ketose 发表于 2014-3-4 13:37 | 显示全部楼层
51单片机,int是两个字节!
评分
参与人数 1威望 +5 收起 理由
cjseng + 5 很给力!
查看全部评分
airwill 发表于 2014-3-4 15:51 | 显示全部楼层
应该是数据类型问题, ASC 码还是二进制码的问题
