UART接收问题
2598|5
 楼主| xiachu 发表于 2014-3-7 14:57 | 显示全部楼层 |阅读模式
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
// UART0中断处理程序
void
UART0IntHandler(void)
    uint32_t ui32Status;
    // 获取中断状态
    ui32Status = UARTIntStatus(UART0_BASE, true);
    // 清除中断
    UARTIntClear(UART0_BASE, ui32Status);
    GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_2, 0x1<<0);//B2管脚置0  对应RESETAB
           GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_3, 0x1<<0);//B3管脚置0 对应RESETCD
           PWMGenDisable(PWM1_BASE, PWM_GEN_2 );//禁能PWM发生器
    //禁能PWM输出状态
    PWMOutputState(PWM1_BASE, PWM_OUT_4_BIT| PWM_OUT_5_BIT, false);
  j=UARTCharGetNonBlocking(UART0_BASE);//接收串口数据
  while(UARTCharsAvail(UART0_BASE))
        // 读取UART中的字符并发送
        UARTCharPutNonBlocking(UART0_BASE,
                                   UARTCharGetNonBlocking(UART0_BASE));
    PWMPulseWidthSet(PWM1_BASE, PWM_OUT_4, j);
    PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5, j);
    //使能PWM输出状态
    PWMOutputState(PWM1_BASE, PWM_OUT_4_BIT| PWM_OUT_5_BIT, true);
    GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_2, 0x1<<2);//H2管脚置高  对应RESETAB
    GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_3, 0x1<<3);//H3管脚置高 对应RESETCD
    // 使能PWM发生器
    PWMGenEnable(PWM1_BASE, PWM_GEN_2);
// 向UART发送字符.
void
UARTSend(const uint8_t *pui8Buffer, uint32_t ui32Count)
    // 有字符需要发送就循环
    while(ui32Count--)
        // 向UART写入字符
        UARTCharPutNonBlocking(UART0_BASE, *pui8Buffer++);
//PWM初始化
int
PWMInit (void)
            // PWM不分频
            SysCtlPWMClockSet(SYSCTL_PWMDIV_1);
            GPIOPinTypeGPIOOutput(GPIO_PORTB_BASE, GPIO_PIN_2|GPIO_PIN_3);//配置2,3管脚为输出
            //配置PF0,PF1分别为M1PWM4,M1PWM5
            GPIOPinConfigure(GPIO_PF0_M1PWM4);
            GPIOPinConfigure(GPIO_PF1_M1PWM5);
            // 配置PF0,PF1为PWM的输出管脚
            GPIOPinTypePWM(GPIO_PORTF_BASE, GPIO_PIN_0|GPIO_PIN_1);
            // Configure the PWM1 to count down without synchronization.
            //配置GEN2递减计数模式不同步模式
            PWMGenConfigure(PWM1_BASE, PWM_GEN_2,
                            PWM_GEN_MODE_DOWN | PWM_GEN_MODE_NO_SYNC);
            //设置PWM周期
            PWMGenPeriodSet(PWM1_BASE, PWM_GEN_2,100);
            //设置PWM占空比
            PWMPulseWidthSet(PWM1_BASE, PWM_OUT_4, 1);
            PWMPulseWidthSet(PWM1_BASE, PWM_OUT_5, 1);
            //使能PWM输出状态
            // 使能PWM发生器
            return(0);
//UART0初始化
int UART0Int(void)
           GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
           // Configure the UART for 115,200, 8-N-1 operation.
           UARTConfigSetExpClk(UART0_BASE, SysCtlClockGet(), 115200,
                                    (UART_CONFIG_WLEN_8 | UART_CONFIG_STOP_ONE |
                                     UART_CONFIG_PAR_NONE));
           // 提示输入数据
           UARTSend((uint8_t *)"Enter text: ", 12);
           return(0);
//主函数
int
main(void)
    //设置时钟周期为16MHZ
   SysCtlClockSet(SYSCTL_SYSDIV_1 | SYSCTL_USE_OSC | SYSCTL_OSC_MAIN |
                       SYSCTL_XTAL_16MHZ);
    //使能用到的外设
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOF);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);//使能B端口,PB2、PB3分别对应RESET_AB,RESET_CD
    SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM1); //使能M1PWM外设
    // Enable processor interrupts.
    PWMInit();
    UART0Int();
    IntMasterEnable();
    // 使能UART0中断
    IntEnable(INT_UART0);
    UARTIntEnable(UART0_BASE, UART_INT_RX | UART_INT_RT);
    // 循环等待UART0中断
    while(1)
想用UART接收的数据调节占空比,没成功感觉 j=UARTCharGetNonBlocking(UART0_BASE);//接收串口数据
有问题但是不知道怎么改正
dirtwillfly 发表于 2014-3-9 21:42 | 显示全部楼层
好长的代码
dirtwillfly 发表于 2014-3-9 21:43 | 显示全部楼层
建议分段调试代码,把一个功能调通了再调另一个
yjz101 发表于 2014-5-29 13:35 来自手机 | 显示全部楼层
远程控制PWM,……
elecintop 发表于 2014-5-31 10:00 | 显示全部楼层
好长的代码。。。
1462014620 发表于 2014-7-29 23:32 | 显示全部楼层
请问我同样的配置了UART1 ,不知为何无法发送。
