MSP430F6726硬件I2C不能发送数据
2235|3
 楼主| liyuan_zhang 发表于 2014-3-8 17:22 | 显示全部楼层 |阅读模式
使用6726做主设备给从设备发送数据,从设备是ADS1113,代码如下:
#include <msp430.h>
unsigned char TXData;
unsigned char TXByteCtr;
int main(void)
    WDTCTL = WDTPW | WDTHOLD;                         // Stop WDT
    // Setup P2.0 UCB0SCL, P2.1 UCB0SDA
    P2SEL |= BIT0 | BIT1;                             // Set P2.0,P2.1 to UCB0SCL, UCB0SDA
    // Setup eUSCI_B0
    UCB0CTLW0 |= UCSWRST;                             // Enable SW reset
    UCB0CTLW0 |= UCMST | UCMODE_3 | UCSSEL_2;         // I2C Master, use SMCLK
    UCB0BRW_L = 12;                                   // fSCL = SMCLK/12 = ~100kHz
    UCB0BRW_H = 0;
    UCB0I2CSA = 0x48;                                 // Slave Address is 048h
    UCB0CTLW0 &= ~UCSWRST;                            // Clear SW reset, resume operation
    UCB0IE |= UCTXIE0;                                // Enable TX interrupt
    TXData = 0x01;                                    // Holds TX data
    while (1)
        TXByteCtr = 1;                                // Load TX byte counter
        while (UCB0CTLW0 & UCTXSTP) ;                 // Ensure stop condition got sent
        UCB0CTLW0 |= UCTR|UCTXSTT;                  // I2C TX, start condition
       // UCB0CTLW0 |=UCTXSTT;
        __bis_SR_register(LPM0_bits | GIE);           // Enter LPM0 w/ interrupts
        __no_operation();                             // Remain in LPM0 until all data
       // __delay_cycles(10000);                                              // is TX'd
        TXData++;                                     // Increment data byte
// The USCIAB0_ISR is structured such that it can be used to transmit any
// number of bytes by pre-loading TXByteCtr with the byte count.
// USCI_B0 interrupt service routine
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
    switch (__even_in_range(UCB0IV, 30))
        case USCI_NONE: break;                        // No interrupts
        case USCI_I2C_UCALIFG: break;                 // ALIFG
        case USCI_I2C_UCNACKIFG: break;               // NACKIFG
        case USCI_I2C_UCSTTIFG: break;                // STTIFG
        case USCI_I2C_UCSTPIFG: break;                // STPIFG
        case USCI_I2C_UCRXIFG3: break;                // RXIFG3
        case USCI_I2C_UCTXIFG3: break;                // TXIFG3
        case USCI_I2C_UCRXIFG2: break;                // RXIFG2
        case USCI_I2C_UCTXIFG2: break;                // TXIFG2
        case USCI_I2C_UCRXIFG1: break;                // RXIFG1
        case USCI_I2C_UCTXIFG1: break;                // TXIFG1
        case USCI_I2C_UCRXIFG0: break;                // RXIFG0
        case USCI_I2C_UCTXIFG0:                       // TXIFG0
          //  if (TXByteCtr)                            // Check TX byte counter
                UCB0TXBUF = TXData;                   // Load TX buffer
                TXByteCtr--;                          // Decrement TX byte counter
          //  else
                UCB0IFG &= ~UCTXIFG;                  // Clear USCI_B0 TX int flag
                UCB0CTL1 |= UCTXSTP;                  // I2C stop condition
                __bic_SR_register_on_exit(LPM0_bits); // Exit LPM0
            break;
        case USCI_I2C_UCBCNTIFG: break;               // CNTIFG
        case USCI_I2C_UCCLTOIFG: break;               // LTOIFG
        case USCI_I2C_UCBIT9IFG: break;               // BIT9IFG
        default: break;
问题来了,程序在 ONLINE DEBUG的时候可以从监视窗口看到数据已发送到UCB0TXBUF ,但是从波形上看只能看到发送从设备地址,没有数据,求教啊!
 楼主| liyuan_zhang 发表于 2014-3-8 17:25 | 显示全部楼层
坐等高手解答啊啊啊啊!
 楼主| liyuan_zhang 发表于 2014-3-8 17:47 | 显示全部楼层
能不能有人回答一下啊,在线等大神
dirtwillfly 发表于 2014-3-9 21:33 | 显示全部楼层
没看到使能总中断啊。建议楼主再认真调试下程序
