[Quartus] OFDM程序编译报错
1685|0
 楼主| daixi520 发表于 2014-3-13 17:18 | 显示全部楼层 |阅读模式
   我用Megacore建了IFFT,可是编译时总报错说:“VHDL Use Clause error at IFFTcore.vhd(35): design library "fft_lib" does not contain primary unit "fft_pack_fft_110”,我在安装文件C:\altera\11.0\ip\altera\fft\lib里找到fft_pack_fft_110.vhd,那这个库要怎么改?
   程序如下:
library IEEE;
use IEEE.std_logic_1164.all;
library fft_lib;
use fft_lib.fft_pack_fft_110.all;
ENTITY IFFTcore IS
        PORT (
                clk        : IN STD_LOGIC;
                reset_n        : IN STD_LOGIC;
                inverse        : IN STD_LOGIC;
                sink_valid        : IN STD_LOGIC;
                sink_sop        : IN STD_LOGIC;
                sink_eop        : IN STD_LOGIC;
                sink_real        : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
                sink_imag        : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
                sink_error        : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
                source_ready        : IN STD_LOGIC;
                sink_ready        : OUT STD_LOGIC;
                source_error        : OUT STD_LOGIC_VECTOR (1 DOWNTO 0);
                source_sop        : OUT STD_LOGIC;
                source_eop        : OUT STD_LOGIC;
                source_valid        : OUT STD_LOGIC;
                source_exp        : OUT STD_LOGIC_VECTOR (5 DOWNTO 0);
                source_real        : OUT STD_LOGIC_VECTOR (9 DOWNTO 0);
                source_imag        : OUT STD_LOGIC_VECTOR (9 DOWNTO 0)
END IFFTcore;
ARCHITECTURE SYN OF IFFTcore IS
        COMPONENT asj_fft_si_se_so_b_fft_110
        GENERIC (
                nps        : NATURAL;
                bfp        : NATURAL;
                nume        : NATURAL;
                mpr        : NATURAL;
                twr        : NATURAL;
                bpr        : NATURAL;
                bpb        : NATURAL;
                fpr        : NATURAL;
                mram        : NATURAL;
                m512        : NATURAL;
                mult_type        : NATURAL;
                mult_imp        : NATURAL;
                dsp_arch        : NATURAL;
                srr        : STRING;
                rfs1        : STRING;
                rfs2        : STRING;
                rfs3        : STRING;
                rfc1        : STRING;
                rfc2        : STRING;
                rfc3        : STRING
        PORT (
                clk        : IN STD_LOGIC;
        END COMPONENT;
BEGIN
        asj_fft_si_se_so_b_fft_110_inst : asj_fft_si_se_so_b_fft_110
        GENERIC MAP (
                nps => 64,
                bfp => 1,
                nume => 1,
                mpr => 10,
                twr => 10,
                bpr => 16,
                bpb => 4,
                fpr => 4,
                mram => 0,
                m512 => 0,
                mult_type => 0,
                mult_imp => 0,
                dsp_arch => 0,
                srr => "AUTO_SHIFT_REGISTER_RECOGNITION=OFF",
                rfs1 => "IFFTcore_1n64sin.hex",
                rfs2 => "IFFTcore_2n64sin.hex",
                rfs3 => "IFFTcore_3n64sin.hex",
                rfc1 => "IFFTcore_1n64cos.hex",
                rfc2 => "IFFTcore_2n64cos.hex",
                rfc3 => "IFFTcore_3n64cos.hex"
        PORT MAP (
                clk  =>  clk,
                reset_n  =>  reset_n,
                inverse  =>  inverse,
                sink_valid  =>  sink_valid,
                sink_sop  =>  sink_sop,
                sink_eop  =>  sink_eop,
                sink_real  =>  sink_real,
                sink_imag  =>  sink_imag,
                sink_ready  =>  sink_ready,
                sink_error  =>  sink_error,
                source_error  =>  source_error,
                source_ready  =>  source_ready,
                source_sop  =>  source_sop,
                source_eop  =>  source_eop,
                source_valid  =>  source_valid,
                source_exp  =>  source_exp,
                source_real  =>  source_real,
                source_imag  =>  source_imag
END SYN;
