[STM8] 求大神帮忙啊,总进异常中断,为什么啊?
1478|3
 楼主| xingshaobang 发表于 2014-4-7 14:50 | 显示全部楼层 |阅读模式
TI, TE, ST, IO, se
我用ST的例子建立一个工程,怎么就总是进异常中断呢?大神帮忙啊
主函数文件:
/* MAIN.C file
* Copyright (c) 2002-2005 STMicroelectronics
#include "stm8s.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define TIM4_PERIOD       124
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
__IO uint32_t TimingDelay = 0;
void Delay(__IO uint32_t nTime);
void TimingDelay_Decrement(void);
static void CLK_Config(void);
static void TIM4_Config(void);
main()
          /* Clock configuration -----------------------------------------*/
  CLK_Config();
  /* TIM4 configuration -----------------------------------------*/
  TIM4_Config();
        while (1)
                {Delay(100);};
    /* Initialization of the clock */
    /* Clock divider to HSI/1 */
    CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  /* TIM4 configuration:
   - TIM4CLK is set to 16 MHz, the TIM4 Prescaler is equal to 128 so the TIM1 counter
   clock used is 16 MHz / 128 = 125 000 Hz
  - With 125 000 Hz we can generate time base:
      max time base is 2.048 ms if TIM4_PERIOD = 255 --> (255 + 1) / 125000 = 2.048 ms
      min time base is 0.016 ms if TIM4_PERIOD = 1   --> (  1 + 1) / 125000 = 0.016 ms
  - In this example we need to generate a time base equal to 1 ms
   so TIM4_PERIOD = (0.001 * 125000 - 1) = 124 */
  /* Time base configuration */
  TIM4_TimeBaseInit(TIM4_PRESCALER_128, TIM4_PERIOD);
  /* Clear TIM4 update flag */
  TIM4_ClearFlag(TIM4_FLAG_UPDATE);
  /* Enable update interrupt */
  TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);
  /* enable interrupts */
  enableInterrupts();
  /* Enable TIM4 */
  TIM4_Cmd(ENABLE);
  if (TimingDelay != 0x00)
    TimingDelay--;
  TimingDelay = nTime;
  while (TimingDelay != 0);
总是跳到下面这个函数,为什么呢?
@far @interrupt void NonHandledInterrupt (void)
        /* in order to detect unexpected events during development,
           it is recommended to set a breakpoint on the following instruction
        return;
补充,stm8s_it.c中与TIM4中断有关部分
#ifdef STM8S903/**
  * @brief  Timer6 Update/Overflow/Trigger Interrupt routine
  * @param  None
  * @retval None
INTERRUPT_HANDLER(TIM6_UPD_OVF_TRG_IRQHandler, 23)
  /* In order to detect unexpected events during development,
     it is recommended to set a breakpoint on the following instruction.
#else /*STM8S208, STM8S207, STM8S105 or STM8S103 or STM8AF62Ax or STM8AF52Ax or STM8AF626x */
  * @brief  Timer4 Update/Overflow Interrupt routine
  * @param  None
  * @retval None
INTERRUPT_HANDLER(TIM4_UPD_OVF_IRQHandler, 23)
   TimingDelay_Decrement();
  /* Cleat Interrupt Pending bit */
  TIM4_ClearITPendingBit(TIM4_IT_UPDATE);
#endif /*STM8S903*/
TCS.rar
265.67 KB, 下载次数: 2
朝阳之光 发表于 2014-4-7 17:17 来自手机 | 显示全部楼层
直接把代码贴过来,没人会下载你的代码看的
一清如水 发表于 2014-4-7 17:35 | 显示全部楼层
打包的NB大神,帮顶
 楼主| xingshaobang 发表于 2014-4-8 15:23 | 显示全部楼层
谢谢提醒,不怎么泡坛子,不懂规矩,不好意思
